| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| BHPian | I have been observing from the time i owned it (OHC Vtec 1.5) that.. during backing up (reverse gear) the car drains most of the fuel.. I have been a mute but helpless. The way it gobbles up fuel is enormous which should in the fuel meter.. i really dont understant what is happening.. Moreover .. I dont accelerate while doing the reverse... and since i know this problem i avoid as must reverse as possible.. help!!!!
__________________ VTEC - an Asset |
| | #2 (permalink) |
| Distinguished - BHPian ![]() | Fill up your tank, drive as u would normally do (till it reaches "E"), fill it up again and see how much fuel has been consumed w.r.t the distance covered. I don't think you'l see a drop in this case. Never judge your FE by looking at your fuel meter. Shan2nu
__________________ VTEC flyby - youtube.com/watch?v=1AhWJlVRPqE |
| | #3 (permalink) | |
| BHPian | Quote:
I had a feeling what FE i used to get in normal gears.. and totally reverse happened in reverse gear.. Does this happen to all u guys having OHC 1.5 vtec..or atleast noticed that when u were using the reverse gear..????
__________________ VTEC - an Asset | |
| | #4 (permalink) |
| Team-BHP Support ![]() | [quote=four_tire]I have been observing from the time i owned it (OHC Vtec 1.5) that.. during backing up (reverse gear) the car drains most of the fuel.. QUOTE] Try driving in forward gear which the car is meant to. Reverse gear ratio's are similar to 1st gear. Am really interested to see how you drive a significant amount of your journey in reverse to cause this ?
__________________ I love the whoosh, but i miss the bellowing |
| | #5 (permalink) | |
| BHPian | Quote:
__________________ Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind. - Dr Seuss | |
| | #6 (permalink) |
| Senior - BHPian Join Date: Feb 2005 Location: Chennai
| Shan2nu - Fill up the tank till the gun auto ejects, drive for 500 kms & refill the tank till the gun auto ejects. Note down the amount of fuel you fill up & divide it by 500 (the kms that has been run). Do it thrice, average up and get the mileage. This is what I do. It is very difficult to mark the same level at empty position as it leads to a big difference. why there is a change in your title - ![]() four tire - How long do u drive in the reverse to see a sharp drop on the fuel indicator Last edited by Surprise : 11th May 2006 at 11:23. |
| | #8 (permalink) | |
| BHPian | Quote:
I only use the REVERSE GEAR when removing it from my garage in my house.. that means a 20 ft maximum.. But to So by this time the needle would have dropped down significantly around 3 points I only operate the brake / clutch pedal which reversing the car... AJMAT: I only use the reverse gear normally to either park the car or remove from parking.. the total time used here will be 15 seconds .. worst 45 seconds .. Since the parking inside my garage is only 20 ft and now bends or curves ..
__________________ VTEC - an Asset Last edited by four_tire : 11th May 2006 at 14:24. | |
| | #9 (permalink) | |
| BHPian | Quote:
1. does my fuel show full when i filled fully .. [yes] 2. if the needle drops down below zero... abruptly... [NO] So he said its completely normal.. and nothing to worry ![]()
| | #10 (permalink) | |
| Team-BHP Support ![]() | Quote:
__________________ I love the whoosh, but i miss the bellowing | |
| | #11 (permalink) | |
| BHPian | Quote:
In my earlier post there is a correction... it is "no curves/ bends" and not "now curves/bends"
| | #12 (permalink) | |
| BHPian | Quote:
but i tell my OHC vtec is bad in reverse gear and when driven in a snail pace traffic... What a bad luck.. i am in bangalore at this moment of life.. driving a good horse in an ugly battlefield..
| | #13 (permalink) | |
| Distinguished - BHPian ![]() | Quote:
Shan2nu
__________________ VTEC flyby - youtube.com/watch?v=1AhWJlVRPqE | |
| | #14 (permalink) | |
| BHPian Join Date: May 2006 Location: Somewhere
| Quote:
Very simple thing u can do here,first open your tank cap and see does it produce any cacum or not,just see it is not faulty.two,I suspect fuel gauge once again and if there is something wrong in it such reading is possible,Other ppl have given their inputs so try and let us know.I hope nothing is seriously wrong in your case,dont worry. In my old fiat I had silimar kind of probe though it had a mechanical fuel gauge and that gauge had a hole in its float.Many times when I used to break my car it used to jump like a bar girl ! Last edited by ECM : 11th May 2006 at 20:03. | |
| Thread Tools | |
Similar Threads | ||||
| OHC Vtec Owners - Problems Areas, Fuel Efficiency and Max Speed ? | vishnuvijay | Technical Stuff | 52 | 15th July 2008 12:16 |
| OHC Vtec | malcolm | Modifications & Accessories | 81 | 18th February 2008 14:22 |
| Ohc 1.5 Vs Ohc Vtec | narayan | Technical Stuff | 85 | 19th February 2007 21:56 |
| NHC-Vtec or OHC Vtec..which is a better buy? | sunith | Sedans | 4 | 2nd May 2006 21:25 |
| Wanted: OHC VTEC or OHC 1.5 | adit1329 | Shifting gears | 4 | 16th March 2006 17:39 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
help!!!!
