Old 9th February 2013, 08:19   #16
vb-san's Avatar
Thanked: 4,658 Times
Default Re: Nissan-Renault 1.5L DCi : Difference between the 68, 85 & 110 PS variants
Is there any difference (in specification) between the 110ps DCi in the Fluence and Duster?
vb-san is offline   Reply With Quote
Old 9th February 2013, 10:14   #17
ampere's Avatar
Thanked: 9,127 Times
I think the 110 version which was updated for Fluence was recently re-tuned. Fluence as a result has almost no lag, as per what I heard.
I am not sure if the same state of tune finds itself into Duster. Maybe if yes, that may be the reason, most recent owners of the 110 Duster,
are not seeing any lag.
Old 9th February 2013, 15:38   #18
devarshi84's Avatar
Thanked: 119 Times
Ok, so is it possible to mod the Verito with 110ps config and the 6-speed box by just replacing with VGT charger and the gearbox?
or the Scala/Sunny or Micra/Pulse for that matter?
devarshi84 is offline   Reply With Quote
Old 9th February 2013, 16:39   #19
Thanked: 103,726 Times
^ Among other things, you'll need the turbo, ECM, gearbox, intercooler and upgraded radiator. Some other components (fuel pump, injectors, intake, exhaust, manifolds, pipes, brackets etc.) may or may not be required.
If & when you are able to source these parts from Renault-Nissan, the bill would easily run over 2.5 - 3.0 lakh rupees.
Better to get a power box or remap & accept the Logan for what it is
GTO is offline   (1) Thanks Reply With Quote
Old 10th February 2013, 10:16   #20
devarshi84's Avatar
Thanked: 119 Times
I do not own a Logan. I was tempted by the idea of a powerful diesel car which is cheap to maintain and has basic electricals.
Old 10th February 2013, 11:07   #21
rajeev k's Avatar
Thanked: 1,750 Times
Originally Posted by thoma View Post
One more vehicle sports the DCi, the Evalia!
The Ashok Leyland Stile will also sport this engine.
The specs are similar but the one in Evalia has higher torque figure of 200 Nm at 200 rpm compared to the Stile's 167 Nm at the same rpm. The Stile delivers a maximum power output of 65bhp at 4000rom whereas the Evalia delivers only 63bhp at 3750 rpm.
I initially thought that the Leyland LCV Dost also shares the same engine but it is different and that too a three pot 58bhp one capable of developing maximum torque of 157 Nm at 1650 - 2400 rpm.
rajeev k is offline   Reply With Quote
Old 10th February 2013, 17:04   #22
Thanked: 11 Times
AFAIK, Evalia has 85bhp@ 3750rpm engine, similar to Duster 85PS specs.
Ashok Leyland Stile has 65 bhp@ 4000rpm engine, similar to Micra DCi specs.
Power Freak is offline   (1) Thanks Reply With Quote
Old 12th February 2013, 18:20   #23
Thanked: 364 Times
Ampere - This info is from reading all over the place, and some presumptions so take with a pinch of salt.
I think the India Duster engine is one variant previous to the the new Fluence engine and the Duster engines they are shipping to UK, which are all euro 5
The latest variant supports ESP and has a DPF. Also the turbo kicks in at 1800RPM instead of 2200 RPM. The new euro 5 variant also has 90bhp instead of 85bhp.
I think the India duster has been tuned compared to the early demo version, but the turbo still kicks in at around 2200rpm, so its not the newer version.
raul is offline   Reply With Quote
Old 12th February 2013, 19:50   #24
ampere's Avatar
I am aware of it Raul. I just thought if they had quietly changed, based what I read about owners mentioning, how the 110 surprisingly does not show any lag compared to the one folks test-drove.
Old 18th February 2013, 23:04   #25
thoma's Avatar
Thanked: 1,112 Times
As now we are on the K9K, does anybody know what exactly is the clattering noise produced by the engine while pressing the accelerator? The one, like on an old 1.4 TDCi Ford motor? Otherwise, on coasting in gear, it is just the thrum from the cylinder. Is it just the diesel clatter? Which component makes this noise - injector / valves or tappet / timing belt? I hear this lesser on a Sunny than on a Micra.
thoma is offline   Reply With Quote
Old 19th February 2013, 07:45   #26
headers's Avatar
Thanked: 464 Times
The Final drives will be different
Old 31st March 2014, 14:46   #27
eatdust's Avatar
Thanked: 19 Times
Here is a micra with 1.6l engine and an intercoolerName:  1393679_792812540734223_2096925608_n.jpg
eatdust is offline   Reply With Quote
First Drive: Renault Pulse 1.5 DCI sidindica Test-Drives & Initial Ownership Reports 33 27th February 2015 12:35
Difference between a KIKI & Mico fuel pump on Nissan SD 25 engine joe3tom 4x4 Technical 12 17th April 2014 15:04
Renault Pulse Diesel vs Nissan Micra DCi girishglg Hatchbacks 45 21st February 2014 11:35
My Renault Scala - Metallic Blue - RXz Dci fesar79 Test-Drives & Initial Ownership Reports 30 2nd June 2013 12:59
Flip Flop between Bajaj Auto & Renault Nissan on small car RemingtonSteele The Indian Car Scene 6 16th July 2011 11:19
