Thread Tools
Old 12th May 2006, 00:58   #1 (permalink)
humyum's Avatar
Default 800 woes AGAIN
Guys..i must say..the problems with my car..never end..tired of it ...somethin or the other keeps commin up.. the alternator is the problem now..my car run 62000 km ...carbureted 1998 model maruti 800..after the fire thing was over..nd the car was being serviced as well..the service station guy told me the alternator was supplyin less current than it was supposed to supply....it was supplyin 13.07 volts without him cleaning or anythin with no load..nd with load it was 12.69....he said that old maruti 800 carburated model had problems of supplying less current..the problem is solved with the mpfi 800.. he said he ll clean the terminals of the alternator..took his word..nd when went to take delivery of the car...he said alternator is fine nd he had cleaned the terminals..took his word for it ...
Then some days back..searched the net for the alternator voltage output nd to my ..the output shown everywhere was around 14.5 with no load..nd 13.8 with load..had also pm'ed mridul..one of the new users on t-bhp..as had read his post regarding the alternator output nd stuff..got his reply..sayin the alternator is supplyin less current nd the maruti guys were not right in what they said ...he gave me his friends number who works in amron...he also confirmed the voltage is low..
Went to a battery fellow..nd asked him to check the voltage..nd the voltage shown there was 13.8 with no load..nd with all the load of headlight,ac/blower..the voltage was 12.8..
Just to confirm the reading went to another battery fellow nd again to my the reading shown by his meter was 13 .4 with no load..nd with load of headlight/ac/blower..it dropped to an alarming 11.90..
Dint know which one to belive..so took a normal electricians meter which my friend had..nd checked the output..it showed 13.7 at no load..which drastically dropped to 12 volts with all the load..
Now i am very confused..which reading to believe..all this was checked by connecting the possitive nd negative terminal of the meters to the battery..nd all the reading were at idle rpm..
Guys please suggest what should i do...nd one more thing..i have never got any starting..headlight dimming or any kind of problems with the car ever..i have an excide..battery in my car..
__________________
Life is a lemon and i want my money back!!!!
Old 12th May 2006, 11:26   #2 (permalink)
wolfinstein's Avatar
Humyum Bhai...! Don;t get so worried...! Its normal for an alteranator to have certain operating range..If the difference is not great that means its doing just fine...!
All electronic meters have different resistance capcit...so their will be a difference in readings in most of them...Since however I will suggest you to trust your Maruti Dealer's equipment.
There appears to be no problem with your electricals now, No surges, No fuse blown, No dimming...So No Worry...! Its all fine..!
The Only advisable thing you can do, to get the though out of your head is, to get the alternator cleaned, with time, there is lot of dust and carbon which deposits inside the motor windings causing low performance and low current- You can get this cleaned at any good Maruti Workshop or a good electrical motor works..somewhat like those which repair and do motor re-windings for Water Pumps...!
Changing a battery is a only a temporary solution, if the alternator is really producing low current then the battery will not sustain the charge for long...So don't worry Your Exide is the most dependable battery you can find...!
regards
__________________
" When was the last time, You did something for the first time "
wolfinstein is offline   Reply With Quote
Old 12th May 2006, 17:42   #3 (permalink)
Even I have a 1998 model, I guess they do have this alternator problem for this model. I am very much cautious when driving on load. I either switch off my AC or my music system in the night coz I can't switch off the headlamps :-). Even I got my car checked at the maruti service center and they say its all normal but on rainy days in the night I can feel the power supplied is less when engine is on full load.
I think I will ask the service guy if we can upgrade the alternator.
Hey HumYum, did you get your alternator cleaned like Wolfinstien said? let me know if u got it done. I will also ask them to clean it in my next service and see if the performance increases.
*thanks*
RoaringEngine is offline   Reply With Quote
Old 12th May 2006, 20:50   #4 (permalink)
humyum's Avatar
hey dude..got the alternator opened..serviced..nd replaced parts like cutout,carbon brush nd one more thing sorry forgot what it was..all this set me back by 1100 bucks(all original tvs lucas original parts)....nd plus 200 bucks for mechanics labour..nd voila..checked the output..it was showin 14.42 at no load..nd at full load of headlight ac/blower ..it was still showin 13.7..got 90/100 headlight bulbs ..so must be sucking more power...roaring engine i think go to ur trusted mechanic..nd have him open the alternator nd replace the necessary parts..the alternator will be back as new...about the higher capacity alternator...that will cost a bomb dude..
__________________
Old 12th May 2006, 23:10   #5 (permalink)
HumYum..! So I hope it was well spent 1300 rupees..or maybe just the old saying " a stich in time saves nine "..! Were the replaced parts worn out or dirty or what, could you post pictures of the parts, I would really love to see what makes an alternator besides the magnet and copper windings..!
BTW the Engine does not take any power from the Alternator..! The engine on the contary develops power to run the alternator using its Belt...! It does'nt sound like that there is any problem with the alternator giving you the right amount of power, An alternator will give different readings at different load levels.
And Yes for the costing..! The Alternator is infact a very costly OE to replace- Labour cost is meagre considering the part cost, Last what I knew the Alternator for my ex-uno was around 18000/- and currently for a lancer its around 20-25000/-..! OEM companies are TVS-Lucas,Denso..Any more..?? TVS Lucas is the OEM I have seen mostly...!
regards
__________________
Old 13th May 2006, 00:35   #6 (permalink)
humyum's Avatar
wolfinstein dude..i meant roaring engine the user..roaring engine....i ll post u some pictures of the worn out parts soon..yeah man it was a well spent 1300 bucks..the parts were worn out...he said.. nd the mechanic said they need servicing every 25000 km(the alternator)..as per his sayin..dont know how true it is ...my alternator was never opened until today..i ll post the pics of the parts soon..The new alternator of maruti 800 costs 2500..
__________________
Old 14th May 2006, 01:44   #7 (permalink)
pramodkumar's Avatar
Hey humyum Bro
Get a pooja done on your car its really unfortunate that these things are happening to you. If i am correct the last 2-3 months were not that lucky for your car get a pooja done.
Old 14th May 2006, 10:16   #8 (permalink)
humyum's Avatar
Pramod..already got the pooja done..had gone to shrirdi..with my family..nd that time got it done..hopefully all the problems are sorted out now..(touchwood)..
__________________
Thread Tools
Maruti 800 STD & 800 DX..pros & cons ? shapath Technical Stuff 5 15th February 2008 12:13
Battery woes!? rocksterraghu Ask the Gurus 20 7th January 2008 23:10
Honda Woes Torque-ative Long-Term Ownership Reviews 10 28th November 2007 10:27
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459
