Old 26th July 2013, 17:18   #16
harryms's Avatar
Thanked: 24 Times
Default Re: Solved! Fiat Linea Front Suspension Noise
thank you for the reply. i think i will be able to resolve the sound issue in the suspension.
harryms is offline   Reply With Quote
Old 1st August 2013, 21:17   #17
me@fiat's Avatar
Thanked: 63 Times
Guys would really like to know if the Punto and Linea 1.3 share the same suspension setup? If not what is the difference between both?
Can we fit Linea suspensions to Punt and vice-versa?
me@fiat is offline   Reply With Quote
Old 3rd August 2013, 12:57   #18
Mr.Boss's Avatar
Thanked: 2,548 Times
I hope the part numbers are different between Punto & Linea.
But technically the Front suspension setup can be same for Punto & Linea, but rear should be different (considering the weight difference)
Mr.Boss is offline   (1) Thanks Reply With Quote
Old 3rd August 2013, 20:54   #19
me@fiat's Avatar
Thanked: 63 Times
Thanks Mr. Boss,
I tried to find this out one of the FASS said both are same just the mountings are different. Where as other two said they are not sure about it. as they never tried to do it. So as of now it's still unanswered Q for me.
Old 3rd August 2013, 23:28   #20
Mr.Boss's Avatar
Mountings are exactly same for Punto & Linea
Old 4th August 2013, 12:25   #21
me@fiat's Avatar
Thanked: 63 Times
so, i think both the setups are same. Just the parts number are diff and we can switch Linea <---> Punto suspensions!!!
Old 30th December 2013, 18:30   #22
Speed Pujari's Avatar
Thanked: 389 Times
I am also getting some noise on my T-Jet. I cannot make it if it is from suspense or steering column or whether it is LHS or RHS. The sound is similar to when a heavy person sits slowly on an old charpai or chair, u get a kind of tak-tak-kad-kad-kad kinda sound. I get that sound while engine braking or when the car goes over potholes at dead slow speeds, the more careful I am on pothole the more prominent the noise is. I never get that sound while sudden braking.
I am yet to give the car to Vecto motors, but during the last service they could not diagnose the issue neither they could reproduce the sound.
Any guesses where the sound is coming from?
Speed Pujari is offline   Reply With Quote
Old 31st December 2013, 11:44   #23
harryms's Avatar
Thanked: 24 Times
Friend, I am also having this sound in my Linea but this sound is from the LHS front window glass. I dont know why this happens but the sound is there from the window glass when the vehicle tilts when it goes through uneven surface or through a pot hole. The suspension noise is little different from this, that happens only when we jump a pot hole. Just don't slide the window fully and check if there is sound for testing it. This is how I isolated the issue.
Old 31st December 2013, 14:11   #24
Thanked: 389 Times
Thanks for info and it is really weird. So do u hear the sound once the window is down? Sometimes I feel that the sound comes from somewhere inside the dashboard. But yeah, need to perform the test you have suggested.
Old 7th January 2014, 01:51   #25
harryms's Avatar
Thanked: 24 Times
I don't hear the sound when the glass is rolled down. I hope you will be able to isolate this issue.
Old 7th January 2014, 22:32   #26
Thanked: 25 Times
I don't know whether there is any possibility of your problem of noise being similar to mine, nevertheless I will just bring out my experience. I had a similar problem in my T-Jet and I was not able to identify the exact problem. The noise would be from front or rear or left or right, but mostly from rear. I suspected suspension problem and thought of difficult time ahead as some people have had in many cases. I requested Fiat service to pick up my car and analyse it carefully on a lonely stretch of road where there was no other noise.
After two hours the SA called up and said there was no problem with the car and noise was all because of the rubber mud flap rubbing against the ground. I asked him to replace the rubber mud flap with the moulded mud flap and then do a longish test drive on potholed roads and confirm the problem was resolved. After he confirmed, I collected the car and it's been two months and no problem at all.
skm1967 is offline   Reply With Quote
OHC Suspension Problem EDIT : Solved! KSM-Vtec Technical Stuff 101 13th January 2014 21:08
Fiat Linea front arm rest for Fiat Punto NSK123 Modifications & Accessories 47 15th April 2013 23:34
Jarring noise front brand new left front speaker skrules In-Car Entertainment 13 26th December 2011 10:53
Strange Noise from LHS front suspension Swift viana Technical Stuff 33 26th July 2010 00:35
Strange humming noise from my Safari(EDIT: Solved, window was open hence the noise) himanshugoswami Technical Stuff 14 14th May 2008 15:00
