Old 26th February 2013, 09:00   #1
Mr.Boss's Avatar
Thanked: 2,548 Times
Thumbs up Solved! Fiat Linea Front Suspension Noise
My 2009 Linea MJD Emotion covered 54k km. From 40k km I could hear some abnormal noise from the Front LH Suspension when ever I drive over road patches or small potholes. Magnitude started increasing day-by-day.
During 45k service we suspected Link Rod being the culprit and changed both LH & RH link rods. Noise reduced a bit.
In 50k km noise started again. I suspected the elastic pads, bit could not open the suspension for past 2 months as I was mostly out of station or bundled with heavy work.
Last weekend taken the car to my regular mechanic and removed the LH strut assembly.
On removing we found that the strut to body mounting hole dia is bit larger than required.
Explored the whole garage and found some plastic washers (mechanic said it is used in some car gear lever mounting or gear shift cable)
Inserted the washer in hole and its perfect. Grease packed the elastic pads, fitted back the assembly and went for a short TD in bad roads, to my surprise noise disappeared.
Total cost: 1200 INR (Including wheel alignment, water wash, interior cleaning, all fluid top-up, front LH brake cleaning, labor)
Mr.Boss is offline   (10) Thanks Reply With Quote
Old 26th February 2013, 10:00   #2
Viju's Avatar
Thanked: 1,694 Times
Default re: Solved! Fiat Linea Front Suspension Noise
Thanks for that post and the pictures. My 2010 Ritz ZXi is just shy of the 20,000 km mark and I am find the ride very unsettled and nauseating. It is not too noisy though. Suspecting the bushes, I asked the MASS to change all the suspension bushes. But they being wiser, said the bushes are just 'weak' and would last another 5,000 km. If changing the bushes and linkages does not help matters, I will see if mine is a similar case to yours. Thanks anyway!
Viju is offline   Reply With Quote
Old 26th February 2013, 10:34   #3
Sankar's Avatar
Thanked: 4,657 Times
The plastic (looks like nylon) washer is quite thick and should last a while. Any idea why the holes on the strut tower is much larger than the studs passing through them? I find that strange, the hole should be just large enough for the studs to pas through. Were there any sleeve on the stud which is missing?
One more thing... The strut tower hole is oval, is the strut top oval too? Are the holes that you put wasters in round or oval? I'm thinking whether that much clearance was provided there in the holes to provide some scope of adjustment.
Old 26th February 2013, 18:02   #4
Mr.Boss's Avatar
Default Re: Solved! Fiat Linea Front Suspension Noise
No idea dude
No, I don't think so. Even the same issue is reported in other forum too.
Its a round washer
Mr.Boss is offline   Reply With Quote
Old 9th March 2013, 14:13   #5
Thanked: 19 Times
Identical problem in my Linea. It is Feb 2009 and 45k kms done. Which city are you from? I am from Mumbai.
Prash is offline   Reply With Quote
Old 10th March 2013, 10:55   #6
Mr.Boss's Avatar
I'm from Chennai. Do you get noise from Front LH only?
Old 10th March 2013, 23:28   #7
gemithomas's Avatar
Thanked: 138 Times
Thanks a lot for posting. I'm sure this would help quite a few owners.
Old 10th March 2013, 23:38   #8
Thanked: 1,068 Times
Can you please tell me what kind of noise it was? Was it a metal sound or something else? I'm getting some noise from my Punto's LH suspension for the past few months. It's a bit difficult to describe the noise, it's not metal rubbing against metal, but more like plastic/rubber against metal. I guess it could be the same issue as your's.
StarrySky is offline   Reply With Quote
Old 11th March 2013, 10:47   #9
Thanked: 19 Times
Yes Mr.Boss, its only from the LHS of the front end of the car. I had gone for a change in the front left lower arm and the left suspension in two different phases and the sound stopped for few months/drives. It again got audible after some time. Specifically it increases with the more number of continues hours of drive and more when the road is bad in shape. But once the car is not driven for even a day it fades away and will again come after long drives.
Old 12th March 2013, 09:42   #10
Mr.Boss's Avatar
It's not a metal to metal rubbing noise, but something close to khatkhat when driven over potholes or road patches.
I faced exactly the same issue. There won't be much noise when the car is idle for a week, but after driving few km I could clearly hear that.
Mr.Boss is offline   (1) Thanks Reply With Quote
Old 12th March 2013, 09:59   #11
ACM
ACM's Avatar
Thanked: 2,892 Times
That is one of the oddest problems and ofcourse solutions hence. Am sure that a washer, cover or something that should have been present is missing from either the manufacturing process or earlier suspension work. No doubt a helpful solution but would suggest that others too check if indeed they have a larger than required strut to body mounting hole with no washer / nylon bit to fill the dia difference.
ACM is offline   Reply With Quote
Old 12th March 2013, 11:19   #12
Thanked: 19 Times
All said and done what is the remedy to it. I am not as knowledgeable as you guys and nor I am in Chennai that i can personally meet Mr.Boss. Need help in this matter asap.
Old 25th July 2013, 17:55   #13
harryms's Avatar
Thanked: 24 Times
I too face the same issue from front suspension. Need to check the suspension. one question, is this issue only in front left suspension, what about the right side suspension?
thanks
harryms is offline   Reply With Quote
Old 25th July 2013, 18:10   #14
Biraj's Avatar
Thanked: 1,135 Times
I am also facing a similar issue. My car makes a weird noise from the front left that FASS hasn't been able to diagnose yet. I have described it in detail in my ownership thread
I have a request for you Would you please read the description related to the noise and confirm if it is similar to what you used to face. I am just hoping that I have found the solution because getting rid of that noise is much better than learning to live with it.
Biraj is online now   Reply With Quote
Old 26th July 2013, 15:29   #15
Mr.Boss's Avatar
Not sure about the reason, but in most of the cases (from other forum too) the issue reported is only on the LH side.
If FASS couldn't diagnose the issue, you can give a try with this solution. Please be informed, it worked out for me, but in case of my friend who had similar noise issue it doesn't work.
Mr.Boss is offline   (2) Thanks Reply With Quote
OHC Suspension Problem EDIT : Solved! KSM-Vtec Technical Stuff 101 13th January 2014 21:08
Fiat Linea front arm rest for Fiat Punto NSK123 Modifications & Accessories 47 15th April 2013 23:34
Jarring noise front brand new left front speaker skrules In-Car Entertainment 13 26th December 2011 10:53
Strange Noise from LHS front suspension Swift viana Technical Stuff 33 26th July 2010 00:35
Strange humming noise from my Safari(EDIT: Solved, window was open hence the noise) himanshugoswami Technical Stuff 14 14th May 2008 15:00
