Old 28th March 2013, 08:07   #121
a4anurag's Avatar
Thanked: 10,305 Times
Default Re: fun2drive - Free Performance & Diagnostic App from Bosch
Adding a few more screen shots of the Torque app working on my car.
Cruising at 80 kmph
Name:  Cruising at 80 kmph.jpg
Cruising at 100 kmph
Name:  Cruising at 100 kmph.jpg
Kpl (Average)
Mass Air Flow while cruising at 100 kmph
Name:  MAF  100kmph.jpg
Anurag.
a4anurag is offline   (1) Thanks Reply With Quote
Old 28th March 2013, 10:47   #122
Dodge_Viper's Avatar
Thanked: 423 Times
Anyone with Nissan Micra can help me with OBD port location. It seems hidden somewhere .
Dodge_Viper is offline   Reply With Quote
Old 30th March 2013, 15:41   #123
planet_rocker's Avatar
Thanked: 358 Times
Fiat Palios get a 3pin connector.
Fiat Connector details: socket_location_fiat_ad.pdf
Dedicated Thread on Fiat Palio Scan tools: http://www.team-bhp.com/forum/techni...u-scanner.html (Reliable Fiat ECU scanner)
another link: http://www.myfiatworld.in/showthread...-1-2-nv-Petrol
planet_rocker is offline   (1) Thanks Reply With Quote
Old 30th March 2013, 19:22   #124
jkdas's Avatar
Thanked: 1,261 Times
Tried Torque on Safari and sadly it didn't work. Fun2Drive didn't even work in Alto! Seems it OBD's don't work with Suzuki's in general.
I also tried OBD Car Doctor on Safari which worked fine. Have posted details here
http://www.team-bhp.com/forum/techni...ml#post3080762 (Cracking the Da Vinci "TATA Safari 2.2l" ECU Code)
Old 8th April 2013, 12:33   #125
Thanked: 105 Times
Delphi has partnered with Verizon to release a similar product:
http://www.autoblog.com/2013/04/06/v...-sale-for-250/
Though not sure about its availability in India!
MotoNanu is offline   Reply With Quote
Old 8th April 2013, 14:53   #126
f1fan's Avatar
Thanked: 41 Times
Folks - Would this work on a Nov 2008 Swift Dzire VDi?
f1fan is offline   Reply With Quote
Old 8th April 2013, 15:26   #127
Desmosedici's Avatar
Thanked: 402 Times
I think all Maruti Suzuki vehicles post 2010 have OBD 2 and all those pre 2010 MS vehicles wont connect with these applications (read somewhere). I read in some forum about a 2010 Gypsy getting connected. Since mine is a 2010 gypsy, i plan to buy the ELM connector and try it soon enough.
Desmosedici is online now   Reply With Quote
Old 11th April 2013, 13:25   #128
a4anurag's Avatar
These OBD II connectors will work on vehicles that were made after 2009
You can get yourself a ELM 327 Vgate Mini v2.1 Bluetooth scanner that costs 1500 (incl Shipping) from ebay.in.
It works like a charm in my Ritz VDi (2010 model)
Anurag.
Old 11th April 2013, 15:15   #129
Arun.K's Avatar
Thanked: 47 Times
Anyone knows whether 2009 Vista is OBD-II compliant? It does have a 16 pin socket, but nothing mentioned about OBD-II.
Hi Anurag, any extra features in ELM 327 V2.1 compared to V1.5?
Arun.K is offline   Reply With Quote
Old 11th April 2013, 17:01   #130
Thanked: 402 Times
Anurag.
Thanks Anurag. Checked out the product on Ebay. It mentions V2.1 and most others are offering V1.5. Will order this and report back soon.
Old 11th April 2013, 18:34   #131
a4anurag's Avatar
Hi Arun!
I guess your Vista will be OBD II compliant as you have a 16 pin socket.
I have no idea about the difference in v1.5 and v 2.1. I just use the v2.1 thing.
Anurag.
Old 14th April 2013, 21:57   #132
tharian's Avatar
Thanked: 1,927 Times
Used Torque on my Figo 1.2 as well as the old Verna VGt. Must say its quite addictive to watch the readings at the same time learning and gaining knowledge on what each reading means and if its normal etc.
Only wish I had a bigger screen that could be mounted on the dash which will be equivalant to all the physical meters some modded cars have.
Was fun to watch the turbo boost reading on the Verna. Went upto 20 psi in one of the turbo kicks.
tharian is offline   Reply With Quote
Old 14th April 2013, 23:00   #133
a4anurag's Avatar
What is the highest boost reading you got and at what RPM in your verna? Can you post a screenshot of the boost gauge?
Addiction is such that sometimes we tend to drive like a maniac to see those gauges work. I use it when I am a passenger mostly and not while I am driving.
I got the highest boost reading of 18.9 psi but mine is a FGT (1.3 DDiS).
Cheers,
Anurag.
Old 14th April 2013, 23:55   #134
Columbus_500's Avatar
Thanked: 55 Times
Hey Guys.. Anyone tried these for an XUV 500 W8? I am wondering if it would be OBD or OBD II.
Also, just saw a link for an OBD adapter.
http://dx.com/p/obdii-bluetooth-car-...e-dc-12v-42825
Would you guys recommend this device and also the site to order from for my XUV? Thanks in advance!
Columbus_500 is offline   Reply With Quote
Old 15th April 2013, 00:46   #135
a4anurag's Avatar
XUV 5-O-O is a New vehicle it will be OBD-II compliant.
Get a scanner tool from Ebay.in website. It is better and is shipped faster.
Anurag.
VCDS (Vag-Com Diagnostic System) for VW & Skoda - Discussion Thread robimahanta Technical Stuff 473 17th January 2017 07:44
Technical and diagnostic Guide: Hyundai's HVAC systems sidindica Technical Stuff 54 20th May 2016 13:04
Bosch launches Android app to measure NVH Whiplash7 Technical Stuff 4 16th October 2014 19:59
Affordable ODB Display & Diagnostic Tools (eg. GReddy Informeter, ELM 327, etc) dot Modifications & Accessories 33 12th March 2013 22:44
Android based Engine Perfomance/Diagnostic Tool SudhanshuSD Technical Stuff 3 2nd December 2010 16:10
