Old 16th May 2009, 17:28   #256
nishantgandhi's Avatar
Thanked: 151 Times
Originally Posted by Raccoon View Post
You haven't mentioned if other things were working - power windows, music system, lights, etc?? Just check all this if you dont have a multimeter, etc...
Yes other things that you mentioned are working perfectly fine.
I called the BatMobile service of Exide yesterday. They checked my battery with a hydrometer and found that there was no water in any of the cells. Partly my fault, as I should have checked it. And partly my service center's fault, since I had given the car for servicing 2-3 months ago and I had assumed that they would take care.
Anyways, we filled battery water and also checked the cranking voltage at start up. Its giving out 6.5-7.5 volts on start up, as against 11.5 volts that is required. So I guess its time for a battery change!
Called up dealers and got quotes. Surprisingly, all three preferred brands i.e. Amaron Pro, Tata Green Titanium and Bosch Silver cost almost the same i.e. Rs 4,800-4,900 post discount and buy back of old battery. Warranty terms are also the same i.e. 30+30 months (First 30 months is free replacement and next 30 months is replacement with pro-rata depreciation).
Confused as to which battery to go for? Some dealers say that Amaron after sales is not good. Some tell me that Tata Batteries have leakage problems. Bosch seems to have no negative reviews so far, but I am still a bit inclined towards Amaron. Please advise.
nishantgandhi is offline   Reply With Quote
Old 16th May 2009, 17:37   #257
Raccoon's Avatar
Thanked: 105 Times
If you let the plates be exposed to air, then your battery is doomed.
Anyway, I'd tell you the same again - go for Amaron or BOSCH. You may have heard of less negatives about BOSCH as they currently have a pretty small market share.
Is the BOSCH battery totally sealed btw? Don't belive dealers when they say maintainence free. For me maintainence free = totally sealed. Should have no filler caps. Its a different technology, btw.
Why risk leakage problems and maintainence hassles with Tata??
Old 16th May 2009, 17:53   #258
Thanked: 151 Times
Yes, all three batteries are factory sealed. As I have been told, no battery brand is totally maintainence free in practice. Some require topping up once a year, some 3-4 months.
The one that you are mentioning are maybe the more expensive ones like Optima Yellow/Red top. Ofcourse, they also cost double (or more) compared to the models listed above.
Old 16th May 2009, 18:25   #259
TRAUMASURG's Avatar
It is a very interesting thread.There is a lot of different opinions.there are few posts which mentioned that all the batteries are same.IMHO,thay are not.There are different batteries for different use in automotive industry.what you need is a good quality battery.These days the newer cars has so much electronics that drains the battery constantly.if you live in a cold climate region ,one definetely needs a battery with good CCA i.e. cold cranking ampere.at least 980 or more.If the battery runs down below certain voltage,the battery dies very quickly.The good brand are optima,odyssey,interstate(available in US).
i have the following vehicles at home .1987 mer benz 300SDL,1988 mer benz 560Sl,2003 MB SL55AMG,G500,C3204MATIC,2008 F430SPIDER, for daily use in the summer i drive sl55 and on weekends if weather is good i take out my f430sp,or 560sl or the diesel, in winter i use g500 .my wife uses c320.as a daily driver..What i have done is that since i am not using my fleet on a daily basis ,i attach a trickle charger /battery maintainer,check out ..Batterytender.com - Home of All Your Charging Needs to all the cars when they are not in use so the batteries are all in top condition...i have 90k miles on my g500 ,40k miles on sl55 still with original batteries
TRAUMASURG is offline   Reply With Quote
Old 16th May 2009, 20:32   #260
Raccoon's Avatar
Thanked: 105 Times
MOST IMPORTANT - Don't belive what you are told. Just see the battery personally.
You get totally sealed batts from Amaron at least. Price will be a higher, but it should not be much. Please confirm this... or hopefully others here with more recent info will help.
Btw, unless you know already, BOSCH battries are said to be made by Amaron. Though that does not necessarily mean they are same.
Btw, when I mean sealed, it means TOTALLY sealed. No opening to put anything in or take anything out. So no leakage. If the battery has any filler caps its *NOT* sealed. That means at least the Tata green is definitely not sealed. The term "factory sealed" is not quite applicable here, btw.
Old 16th May 2009, 20:46   #261
Ricky_63's Avatar
Thanked: 394 Times
AMARON by far is the safest bet. I have used it on numerous vehicles & never faced a problem.
Old 16th May 2009, 20:52   #262
Thanked: 160 Times
Amaron
Exide
These two brands are safer to be used in our vehicles.
gowda79 is offline   Reply With Quote
Old 17th May 2009, 01:29   #263
Raccoon's Avatar
Thanked: 105 Times
Thumbs down Anything is Better than EXIDE!!!
Exide is the *unsafest* to use. Likely to leak and will very likely die soon. Gosh, I hate it so much, I don't even tire saying this... lol!!!
Old 17th May 2009, 09:41   #264
can any suggest a battery for UNO diesel - would prefer Amaron - I am lost in the DINs AHs.
randy is offline   Reply With Quote
Old 17th May 2009, 10:29   #265
Ricky_63's Avatar
Thanked: 394 Times
Originally Posted by gowda79 View Post
Amaron
Exide
I beg to differ. Exide quality is pathetic. It packs up usually just post one year. That is just post warranty period.
Old 17th May 2009, 11:46   #266
Roy.S's Avatar
Thanked: 111 Times
The result being that this wretched, despicable battery corroded the paint and metal parts around it.....
I have had exactly the same experience with the same bike and battery in the late 90s. Why they would keep producing such an inferior product even a decade later is beyond me.
My '03 M800 came with a SF battery which I hated. It packed up after 27 months. I replaced it with an basic green Amaron which gave me no trouble at all till I sold the car 2 yrs later.
My Swift came with an Amaron. This seems to be the best choice at the moment, though I have heard good things about Bosch.
Roy.S is online now   Reply With Quote
Old 17th May 2009, 15:15   #267
Raccoon's Avatar
Thanked: 105 Times
^^^The answer is simple - because it sells!!! A LOT of people still think Exide is the best. Exide also seems to have the most dealers... so its easiest to get. I guess they are now just basking in the glory of yesteryears... and doing it profitably.
It seems quite clear now that they deliberately design their batterys to fail just after the warranty period. If you are very lucky it will JUST fail... just have a thanksgiving prayer that it didn't destroy your car or bike's interiors before it kicked the bucket.
Old 17th May 2009, 16:06   #268
with Raccoon. I will go with Amaron any day!! I had it installed in my bikes and earlier cars. I had not issues with this brand so far. Though I use to check the batteries whenever I leave my vehicle for service.
hariharanea is offline   Reply With Quote
Old 18th May 2009, 11:24   #269
gpa
gpa's Avatar
Thanked: 282 Times
Default Amaron Dealer in Bangalore
Hi guys,
My Santro's battery needs replacement. It was an OEM Exide that's lasted 54,000+ kms and 4 years+.
Of late, cold craking has become a little laborious, with a strained feeling when being craked. I put this down to the age of the battery.
As I plan to replace it with an Amaron, I need your inputs on a good dealer here in Bangalore where I can change it. Have seen a few Exide shops stock Amaron, but the boxes were faded which meant they had old stock and hence I steered clear of them.
Need your inputs on where I can find a good dealer in Bangalore for Amaron.
Thanks in advance,
gpa
Old 18th May 2009, 13:20   #270
Thanked: 151 Times
Can someone post details of Amaron dealer for Mumbai? Preferably Dadar/Chembur?
Car battery life - How long did your battery last? shuvc Technical Stuff 919 20th July 2018 11:02
Battery dealer installs 3-wheeler battery in my car!! Now what? Soumyajit9 Technical Stuff 29 19th December 2016 11:06
PICS: SF Sonic Battery Factory. Detailed report on the making of a Car Battery S2!!! Technical Stuff 29 16th April 2016 11:39
Which is the Best Brand of Petrol for your car? arunkumar_rec Technical Stuff 36 29th July 2014 21:29
Battery needs replacement. Which brand? clipto333 In-Car Entertainment 73 23rd December 2011 15:53
