Old 20th March 2013, 14:37   #16
dgupta's Avatar
Thanked: 65 Times
Default Re: What to do if remote key fob fails and vehicle is equipped with Start-Stop button
Originally Posted by thoma View Post
Additionally, there is a copper (I guess) coil winding going through the periphery of the fob.
This coil enables you to start the car using induction when you touch the start stop button using your key. The start/stop button houses the other half of the induction loop, when you touch the button using the fob, a loop is closed and enough energy is generated in the fob to transmit its codes.
Almost all manufacturers use either "induction charging" or a "hidden slot to insert key" to bail the driver out of a flat battery situation. Anyone has come across a different technology used for this ?
dgupta is offline   (2) Thanks Reply With Quote
Old 21st March 2013, 17:23   #17
Prowler's Avatar
Thanked: 305 Times
Correction. There is a workaround for this.
2) Though the intelligent key is termed water resistant, it is mentioned that wetting may damage the key! Do not bend, drop or strike the key against another object. Do not use a magnet holder.
3) The key may not properly work below temperature of -10 degree C. Do not place the key for extended time where temperature exceed 60 degree C (I guess we should read that do not leave the key on the dash).
Magnet doesn't affect the key fob. Water surely can mess up the internal electronics. I once dropped my keys in a puddle of water. The red light did not light up when I pressed any key. I had to change the battery and clean the inner PCB with alcohol to get it working.
Here is a page about Car security in key fobs
Prowler is offline   Reply With Quote
Old 21st March 2013, 19:44   #18
thoma's Avatar
Thanked: 1,112 Times
Didn't go through the link provided, but from my school days, I remember that an external magnet indeed affect an induction coil. We are talking about the intelligent key fob for a vehicle is equipped with Start-Stop button; not the usual remote key fob for which I've never seen a coil inside it.
Moreover, my suggestions are a straight lift from the Nissan owner's manual.
thoma is offline   Reply With Quote
Old 27th May 2014, 14:35   #19
Thanked: 145 Times
Default Keyless Engine Start/Stop - Is it safe?
In cars with a keyless start/stop button, the engine cranks only when the button is pressed with the clutch disengaged. Without pressing the clutch pedal, only the accessories would be powered. Now what if the switch gets stuck and the car thinks that the engine is to be cranked, whereas the user just wants the radio? That would mean the car would start in gear!
What kind of mechanism is incorporated to prevent this from happening?
This question arises after reading the thread: Hyundai Santa Fe recall: For replacing the stop lamp switch
amolbh is offline   Reply With Quote
Old 28th May 2014, 16:22   #20
Thanked: 103,639 Times
Default Re: Keyless Engine Start/Stop - Is it safe?
Not really. Even if the switch gets stuck, you need to press either the clutch or the brake pedal (depending from car to car) for the engine to crank.
I don't know of any OEM keyless go that cranks the engine without clutch / brake pedal input.
Old 28th May 2014, 18:07   #21
Thanked: 145 Times
No sir, I mean what if the switch/sensor which monitors whether the clutch pedal is depressed or not, gets stuck. Like this scenario:
A defective stop lamp switch could result in the brake lamps not illuminating at all, cruise control not cancelling out and the AT gear lever being stuck in "P". I'm assuming that it basically doesn't recognise that the brake pedal has been pressed
Old 28th May 2014, 18:32   #22
fazonater1911's Avatar
Thanked: 52 Times
I can speak for LandRovers and Jags
If proper action is taken and both fobs are used periodically, above situations can be avoided completely.
Do both the fobs have to be used alternatively and periodically to prevent battery discharge?
fazonater1911 is online now   Reply With Quote
Old 30th May 2014, 19:23   #23
dgupta's Avatar
Thanked: 65 Times
Using both key fobs will not prevent their batteries from losing charge. When a key fob is used, the system checks the battery charge state and notifies the driver if it is low.
dgupta is offline   (1) Thanks Reply With Quote
Old 4th June 2014, 18:32   #24
Thanked: 52 Times
I am not sure if my Grand i10 has a low battery in Keyfob indicator. Is there any way to check?
Old 3rd October 2014, 20:26   #25
aboveallkaran's Avatar
Thanked: 9 Times
The best remedy to this, which even i follow is to keep a spare battery in the car. In case the one installed in key fob goes dead, you can replace it instantaneously.
aboveallkaran is offline   Reply With Quote
Old 29th October 2015, 21:59   #26
Turbo_Torq's Avatar
Thanked: 67 Times
Default Re: What to do if remote key fob fails and vehicle is equipped with Start-Stop button?
Apologies for bumping this thread but in the event that the Start/Stop button malfunctions or totally dies out, are there any alternatives to start the engine without having the security system arm itself and immobilise the car?
Turbo_Torq is offline   Reply With Quote
Old 15th December 2016, 11:07   #27
k2max6's Avatar
Thanked: 130 Times
I have a 2014 Verna SX O. When i reach the car and try to open the car with door entry switch the car doesn't open. If i use the remote ,same case. After a minute or two the car opens and the key also works. I guess the car takes some time to detect the key?
After the car opens once after that everything works normallly and i can lock and unlock the car a number of times or use the door switch. Doesnt seem like a battery issue does it?
How long does the smart key fob battery last generally ?
My car is not used much and keeps parked for 7-10 days and after this period the first time i use it the above happens,does it have something to do with this.
I havent tried the other key,will do so.
Edit- Also the led on the key fob is not working.
k2max6 is offline   Reply With Quote
Old 15th December 2016, 12:17   #28
k2max6's Avatar
Thanked: 130 Times
Update - After an hour i went to the parking to check the key fob aand it is unlocking the car from decent distance.Without any delays.
Old 27th February 2017, 00:14   #29
MSA
Wanted to share my experience. I have a W-10 XUV with the start=stop button and a couple of weeks ago, the key didn't work on two trys but it did on third and naturally, I started panicking. After going through this thread, opened the manual and thought I'd share what the XUV manual said.
Interestingly, the XUV manual makes a mention of a weak signal strength or a weak light indicator as a sign that the battery needs to be replaced. The dealer during servicing also confirmed that there is no indicator for a weak battery and it's only based on user experience.
While I'm sure most users are careful, for the benefit of those would like to read a bit - the link to the XUV manual is here:
http://www.mahindraxuv500.com/pdf/owners_manual.pdf
Section 7.5 at page 87 onwards will be helpful - useful tips including replacing battery.
However, while the manual talks of a green light, i have never notice a green light.
One useful suggestion from Mahindra Dealer was - at 2 - 3 years you should not have any problem at all. IF at all you want to do something, consider keeping a spare battery.
A very simple suggestion but something I considered. So I went to buy a spare battery - but the accessories store in South Delhi didn't have it - and said - 2 - 3 years, you don't need a spare!
A combination of a well-maintained key and possibly smart tactics of a spare battery should hopefully see you do fine!
MSA
MSA is offline   Reply With Quote
Old 31st January 2018, 17:34   #30
torque.steer's Avatar
Thanked: 7 Times
In my Baleno Alpha even if there is no battery in the fob, you can simply put to key fob on the start stop button and press it to start the vehicle.
torque.steer is offline   Reply With Quote
Key remote fob - Battery drain raveesh_k Technical Stuff 17 22nd April 2018 12:02
Duplicate Keys, Remote Key OBD Programming : Key Master (Andheri, Mumbai) frankmehta Mumbai 30 24th June 2017 19:00
DIY - Car Key Button Repair pcpranav DIY - Do it yourself 24 28th November 2015 10:16
Wishlist of Features for your Remote / Key Fob Warwithwheels Technical Stuff 9 7th January 2013 19:28
Button start and Horn problem amtak Motorbikes 3 23rd August 2010 12:20
