Old 1st July 2015, 17:41   #31
Thanked: 13 Times
Default Re: Diesel engine stalls when the fuel level is low
So your fuel gauge was showing 1/4 and you could still fill in 42.5 liters? It means your fuel gauge is faulty. Get the float checked.
Sorry for confusion but seems you have mixed up me with thread owner. I never mentioned fuel gauge at all. It was at zero only for sometime.
Now that you have mentioned it, let me ask -is it ok for the fuel gauge to suddenly drop to zero from about 1/8th level? This has been the case with me all through 4 years of owning the Punto?
modisan is offline   Reply With Quote
Old 1st July 2015, 18:09   #32
Thanked: 14,604 Times
No ways there will be sudden drop in the gauge from anywhere in the marking zones.
Sometimes there are fluctuations in the gauge due to undulations etc but no sudden drop should be observed.
Get the Float and gauge checked once.
Old 1st July 2015, 18:32   #33
paragsachania's Avatar
Thanked: 12,343 Times
The float is a mechanical device while the rest of the system is pure electronic including the resistors at the Fuel Tank Sending unit. Based on the position of the float, the circuit allows/resists the amount of current passed through it to the Fuel guage needle which in turn shows the reading accordingly.
A sudden drop would only mean a malfunctioning sender unit- Could be bad ground, intermittent connections.
All this while there is still a possibility that the float may still be functioning normally but the circuit is not.
I would first check the contact points at the fuel tank area which are more susceptible to damage/wear than the wiring behind the Instrument cluster.
paragsachania is offline   Reply With Quote
Old 2nd July 2015, 11:42   #34
Thanked: 13 Times
Thanks Anurag and Parag: I feel like I have been used to this 'drop' towards last 5-15% of fuel tank across my WagonR, Swift, Current Chevy and Fiat. Will get the current ones checked.
Hyundai Santro Xing: Engine shakes and stalls ricky_speed Technical Stuff 11 13th September 2013 09:09
Karizma engine stalls deehunk Motorbikes 13 29th March 2013 14:04
Questions about fuel consumption at engine level nukeblitz Technical Stuff 19 5th August 2012 23:09
Engine stalls after running for long with AC on avenger1976 Technical Stuff 12 11th March 2012 10:31
Engine Stalls and shuts down during de clutch ONLY with GAS TANK FULL in Accent darthvader5000 Technical Stuff 20 7th May 2009 19:59
