Thread Tools
Old 18th May 2006, 14:06   #1 (permalink)
Default wobbling after changing punctured tire
Hi
I had my stepney put in place of the Right Front Tyre today because of a puncture..
After the replacement....The car felt wobbly at speeds above 60 kmph while driving...
I had the rim checked again, checked the tyre pressure - 30 psi..Everything looked OK.
At speeds below 60 kmph the car drives smoothly, but at speeds above that even on Straight roads , it feels wobbly - I feel the wobble in the steering wheel & the brakes & accelerator...
I had my Wheel alignment & balancing done 1500kms back.
Should I go for the balancing & alignment again ? or any other thing ?
__________________
kya !! sab theek hai ???
paharino1 is offline   Reply With Quote
Old 18th May 2006, 15:14   #2 (permalink)
aZa
aZa's Avatar
Yep i dont think ur stepney is balanced ... since ur alignment and balancing was with the "punctured" tyre i think u shud go in for balancing and alignment or just get ur punctured tyre repaired and fit it back in place and keep the stepney as a stepney.
__________________
-[ " If the ride is more fly, then you must buy. " - Snoop Dogg ]-
Old 19th May 2006, 03:59   #3 (permalink)
panky12345's Avatar
Infractions: 0/1 (4)
agree with aza, go in for a tyre balancing + alignment. i was in a similar situation, got the tyre REFITTED (good mechanic) + alignment + balancing... and yoppy, it was gone. most probably its poor/wrong fitment of the tyre to the rim that causes this problem.
__________________
SINGH IS KINNNNNNNG..
Old 19th May 2006, 18:43   #4 (permalink)
2fast4u's Avatar
just check ur tyre wall to see if the circular line closest to the rim is having a 2 to 5 mm distance. should be even both sides. if NOT then thats ur problem get it aligned even our anna tyrewala will do that for u.
__________________
332kmph 1999 unrestricted GSXR1300R
ROYAL ENFIELD MACHISMO 1992
636
RB20DET NISSAN
2fast4u is offline   Reply With Quote
Thread Tools
Wobbling tyre recshenoy Tyre & Alloy wheel Section 2 8th August 2008 01:21
Fiat Petra - punctured silenser (do I need to worry ?) mchulet Technical Stuff 4 14th December 2007 17:28
Your experiences - Punctured Tyre ravradha Street Experiences 29 15th January 2007 19:00
Wobbling Problems humyum Technical Stuff 0 1st March 2006 18:05
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
