Old 3rd March 2007, 20:25   #136
Hi Absar,,
If you have a good known mechanic then can get job done.....your mechanic need to open engine head.....if you have confidence doing little filing work then can do it yourself......
Here is what you need to do...
1)Open Engine head...
2)Take head to machine shop & remove just 1 mm precisely from head surface...
3)Clean head surface & mark boundaries with head gasket as shown else in this thread....
4)With the help of a small trianguler file start making groove pointed towards spark plug area...grooves must be pointed at both end.....width may be 2to 3 mm & 2 to 3 mm deep.....end of groove on flat head surface must be few mm away from marked surface.....
5)Head to be fitted &if needed can change timing belt.....
6)If yours mpfi car then need to open negative battery terminal during such work.....
7)If everything is fine then its ready to roar......feel the difference at low as well as at high end....
If you have auto machine shop nearby then it can be quickly done else needs two days....
Wait for Somender Singhs reply else can call him...he will guide you...
Enjoy....
finetuning is offline   Reply With Quote
Old 3rd March 2007, 21:00   #137
Hello finetuning, thank you so much for the instructions. I will try to wait for Mr.Somender Singh's reply or else I will try to go ahead with the instructions you've given. I did find one good mechanic and I'm very close to finding a machine shop that will shave the surface of the engine head. And what about those parts that have to be purchased? Some posts were there that new parts have to be put in like gaskets etc..?
Btw , I've been wondering.. If I have a grooved engine, will Ford not agree to service it or make up a conflict cos the engine has been grooved..? The car isn't having a warranty. I hate the warranty anyway.
By chance, after grooving will the top speed reduce?
Absar is offline   Reply With Quote
Old 4th March 2007, 19:32   #138
Kaizer Sozay's Avatar
Originally Posted by Absar View Post
Hello? This thread gone silent now..? I mailed Mr.Singh and I'm waiting for his reply regarding the grooving steps. I'm actually a bit impatient to do it for my Ikon 1.6. Btw, does this grooving job take a long time liek 3 - 4 days including the head removal, shaving, polishing/lapping, grooving and fixing the head back or is it possible in a single day? I might be travelling on a 800+ km trip next week (7/3/07-9/3/07) and I want to do it with a grooved engine.
You can find the images here of the process when i did it on my car.
http://www.team-bhp.com/forum/techni...-5-kmpl-3.html (My Grooved Esteem FE is 14.5 Kmpl)
One day would be a very tight squeeze coz it takes atleast 2-3 hours to open the head. I wouldnt advise you to rush your mechanic to do the job hurriedly as it requires a lot of precision. A little extra twist ca ncreate a major problem.
Kaizer Sozay is offline   Reply With Quote
Old 5th March 2007, 14:10   #139
Hello. I got a reply from Mr.Singh.
His mail was:
Thank Q ! AM,
There is enough and more on the net ~ Do a google search for Somender Singh ~ You will see it all !
Me doing it will be time consuming & expensieve ? Read " Silent Power " in my website ~ Under ~ My Thinking New ! You will understand it better !
All the best !
sing !!!
So I referred that page he mentioned.. http://somender-singh.com/content/view/99/52/
And it is mentioned that it is going to cost around Rs.13-14,000. Is it really going to cost that much? Kaizer did it on his zen, and that's a maruti, so the spares would be priced less. But I want to do it on my Ford, and aren't Ford spares way high in terms of price? I'm confused now. I kept a budget for 5k for this grooving. Is it going to exceed that 5k???
Old 5th March 2007, 16:46   #140
The cost of shaving the head is hardly 500rs, The file for making the groove is just 50rs.
The main costs is of the gaskets and oil seals. And the cost of the mechanic as it is a very labour intensive job.
Old 5th March 2007, 20:34   #141
Aha! Well, what are the spares to be collected prior to grooving? I mean for the car. Gaskets..inlet,exhaust,headgaskets,O range , oil seals? This is all to be collected?
Old 6th March 2007, 11:07   #142
Speak to your mechanic, you will need a head gasket also inlet and exhaust gasket, then some o rings. the totat spares costed me around 4500
Old 6th March 2007, 19:28   #143
Ah okay Kaizer. Will check up with my mechanic. I hope I dont have to pay so much. However, the 6 months service is due on the 18th of this month. I think I will have it serviced first and then will do the grooving.
Old 8th April 2007, 21:31   #144
archat68's Avatar
Thanked: 290 Times
i think i'll go for a grooving for my '99 Carb Zen. how much to shave for the carb zen?
archat68 is offline   Reply With Quote
Old 9th April 2007, 18:58   #145
Shaving the head hardly costs 500rs.
Old 16th April 2007, 02:00   #146
Thanked: 20 Times
Can it be done on a palio 1.6 ltr engine.
swathyd is offline   Reply With Quote
Old 17th April 2007, 01:10   #147
Hi swathy,
Grooves can be done on any cars having some flat surface on engine head....now most of engine manufacturer have more or less same design so I expect "Quench Pad' or flat surface to be there on almost every engine.....also benefits are not limited to old generation 2 valve per cylinder cars...infact this can be done on any IC engine...
Enjoy.....
Old 25th April 2007, 02:23   #148
Planning to groove 2 Bikes next week.....Pulsar 150 and Fiero F2......both bike treated with boric acid & showing superb power ....both bikes bottom end torque is excellent.Also Pulsar 150 is returning consistantly 60+ (actually 62) FE consistantly...
I expect more power & rise in FE after grooving.
Enjoy....
Old 25th April 2007, 12:55   #149
Ravi Yadav's Avatar
Hi Finetuning,
Planning to groove my m800. How should i proceed .Should i use the same procedure you explained to Absar.
Ravi Yadav is offline   Reply With Quote
Old 26th April 2007, 12:50   #150
Hi Ravi,
Good to see you taking interest in grooves....you can follow simple instructions or can pm me for more details......I will help you to get it done on your machine...
Enjoy..
2003 Palio S10 EDIT: 71K KM Update | Engine Grooved khan_sultan Long-Term Ownership Reviews 184 31st August 2015 12:30
santro xing xp 9 kmpl ..help freakr Technical Stuff 41 24th December 2012 18:58
4 kmpl palio 1.6???? HELP!!! sajeeth Technical Stuff 66 6th October 2008 20:11
F.E. =150 Kmpl !! DCEite Shifting gears 12 30th March 2008 14:53
Grooved Maruti 1000 finetuning Technical Stuff 13 7th April 2007 01:38
