Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al).
Thread Tools
Old 4th August 2006, 18:10   #61 (permalink)
black12rr's Avatar
Guys if you dont link someones post ignore it or skip ,why do you have to warn or ask him not to repeat that . Finetunning is doing what he loves and hes glad to share it .If you guys dont liek it , skip his posts . I dont understand , there are thousands of post ,that does not mean you guys read all of them , take it liek that and skip posts.Finetunning carry on.
black12rr is offline   Reply With Quote
Old 8th August 2006, 00:49   #62 (permalink)
Kaizer Sozay's Avatar
Default A good Machine Shop For shaving the head
Originally Posted by janeckozzy
somender singh is not a mechanic.. hes at an altogether diff level.. spent the better half o my college days in his garage.. manna.. pure manna... crazy arse racer, rd 350, tz 350,, score of tuned an blown yezdis, yamahas... drool.. former wild child.. still pretty wild actually.. and a god with engines... have sat in is indica an have seen him drive it in 4th.. no gear change and no slippin d clutch.. check im out on his web site somender-singh.com.. meet im if u can an he'll blow ur mind
Meet him i would love to, But i have been talking to the gentleman for the past few weeks and am totally awestuck by his brilliance.
I am totally convinced on this groove idea.
now am just on the lookout for a good machine shop in mumbai which will shave the engine head precisely . & a lot of prayers so that everything goes right.
I am trying to attempt this on my Zen Mpfi Engine once i get a couple of days leave.
Guys any inputs nows the time!!!
__________________
"The greatest trick the devil ever pulled was convincing the world he didn't exist ."
Kaizer Sozay is offline   Reply With Quote
Old 8th August 2006, 01:23   #63 (permalink)
v1p3r's Avatar
Just to play safe, I would suggest you go to chor bazaar and pick up another Zen MPFI head, in case the results are not up to your expectations. I mean no disrespect to Mr Singh, but this sort of thing will seriously jeopardize your warranty.
__________________
"We Could Fly So High
Let Our Spirits Never Die..."
- Michael Joseph Jackson
Rest in peace.
v1p3r is online now   Reply With Quote
Old 8th August 2006, 21:01   #64 (permalink)
My car dosent have any warranty.
The basic premise is that i have to shave the head by 0.7 mm.
then make a small incision like groove that isint even very deep.
then fit the head back & get the timing belt tightened & the tappet setting right.
My mechanic is well versed with the settings, but only looking for some one who will do a good job shaving the head so the surface is totally flat & there are no uneven sections.
__________________
Old 9th August 2006, 00:53   #65 (permalink)
v1p3r's Avatar
Try PMing someone like Nitroxx or Ford Rocam or Viper in your city. They can put you onto someone.
__________________
Rest in peace.
Old 17th August 2006, 23:38   #66 (permalink)
Default The journey begins...
After being hooked on to the acteone high.
I am now taking the plunge and getting my zen grooved on 23rd. found my self a machine shop to shave the head. & have convinced my mechanic to help me in this..
Will be assisted my Finetuning & am praying that all goes well.
I will post a very detailed report along with a ton of photographs if all goes well.
I i fail i will kill myself
__________________
Old 26th August 2006, 00:04   #67 (permalink)
Default My Grooved Zen
What’s it like to realize that all you have learnt about driving is to be rewritten in a span of 72 hours.
I have been driving my Zen for the past few years, Over that period of time I have changed the following things in order to get a Better Smoother drive.
I started of with a better set of tubeless tyres. Moved on to a K& N stock Filter &then finally to a set of Free flow exhaust system.. Yes all these mods helped in an increase in power. Up until I was introduced to a topic called Grooves. And how there is this guy in Mysore called Somender Singh Who has made some grooves in the engine head that creates some kind of turbulence.
Thanks to Team-BHP I was able to collect a lot of information on this topic & get in touch with Finetuning who has been gutsy enough to get this done on his Esteem. After a lot of Reading on the topic I called up Mr Singh, He was extremely helpful & guided me on how to go about doing these grooves on my car ( Mind you he does hold a Patent on this). Yes he does offer this service at his workshop in Mysore but I was not able to travel that distance.
The Project Spanning 72 hours started out on 23rd morning with the assistance of fellow Team Bhpians Finetuning & Janeckozzy & One very Reluctant Mechanic called Jayram.
As Per Mr Somender Singhs instructions we got the following things done
1) Engine head opened up
2) Head shaved on a Surface grinder
3) 8 Grooves Made on the head
4) Head fitted back
The following are my observations today evening.
a) The engine is very quiet & very little vibration.
b) Engine temperature a little bit lower as per the gauge.
But by far the most startling experience is that I change gears without increasing the revs in my car. When I reached 40 KMPH I put the car into 4th gear & took my leg off the accelerator pedal. The car kept slowing down till it reached 15KMPH at this speed there was no knocking or shuddering from the engine. At this point I gently pressed the accelerator pedal (No Half Clutch my leg was on the floor board) The car picked up speed no stalling from the engine……. The car climbed to 60 effortlessly.
I drove a total of 25 Kms today The torque that the engine throws out is awesome.
I drove down in slow to very slow moving traffic in 4th & 5th gear
I have had to Change the Way I Drive, My gear shifting entirely.
My Learning curve just got re-written.
Mr Singh Rocks!!!!
__________________
Old 26th August 2006, 16:31   #68 (permalink)
Dear Kaizer Sozay,
Its been a gr8 project to be completed so successfully......with grooves now your engine is most turbulant one from combustion point of view.....this will have so many benefits....as u will drive more u will realise the potential of grooves....not only FE will increase but there is a gr8 amount of twisting force ur machine is generating on wheel compared to the stock machine......your spark plug will be much cleaner....your engine oil will also be clean compared to past...engine temparature will be down at least by 10%....exhaust will be also clean..........keep driving & enjoy new avatar of car....
Enjoy............
finetuning is offline   Reply With Quote
Old 26th August 2006, 22:35   #69 (permalink)
Mpower's Avatar
Congrats Kaizer. Can you tell us how much depth you shaved the head using grinder.
Also did you have to use a new head gasket and head bolts after you are done.
__________________
The difference between the men and the boys....................is the speed of their toys.
Old 27th August 2006, 00:36   #70 (permalink)
Each Engine head has to be shaved to a different specification, Mr Singh instucted me to shave off a total of 0.7mm as i have an MPFI Zen.
I got 0.5 mm shaved off on the Surface Grinder & a susbequent 0.2 mm done in the Lapping process.
Yes All the gaskets (Inlet, Exhaust, Headgaskets , O rings) all replaced with original MGP spares. also note that some of these gaskets are SGP so get your hands on proper spares before you start it.
__________________
Old 27th August 2006, 02:08   #71 (permalink)
BUSA's Avatar
Kaizer Sozay Nice to hear everything went well. It would be nice if in the coming future you could share the mileage with us which definately is going to be much more then now since your driving style has totally changed. Also did you find any difference in flat out performance, 0 -100kmph, quarter miles, etc.
__________________
Got Bhp? Team-Bhp.com
Old 27th August 2006, 10:03   #72 (permalink)
Default Direct Drive
Yes even i feel that the FE is bound to increase.
To share a bit with you. Mr Singh has asked me to shift gears in the following manner.
From a Dead stop 1st then after the car moving to above 10Kmph move directly to 3rd. & likewise 2nd to 4th in slow moving traffic.
I tried this yesterday evening driving through heavy traffic on linking road works amazing.
Nope not done any 0-100's as the roads in bombay are potholed like crazy.
__________________
Old 27th August 2006, 13:26   #73 (permalink)
BUSA's Avatar
Thanks Kaizer. Does making grooves in the engine affect flat out performance or top end. I am sure your car has better lower end now but has it compromised in anyway with the top end? Is there any effective BHP gain, i feel there should be since more torque = faster 0 - 100.
__________________
Old 27th August 2006, 13:54   #74 (permalink)
Quite true there is a marked improvement throught the entire power band.
Im am certain the top end speed had also improved, because between 40 to 100 there is a very quick acceleration curve.
__________________
Old 28th August 2006, 00:38   #75 (permalink)
There is definitely improvement in 0-100......in my case I noticed in very short stretch I was able to touch 100 on W.E.highway compared to earlier...so is with low end torque......i think its because of driving in higher gear our car gives better FE....this may be one of reason......
Enjoy...........
Thread Tools
Max kmpl , and how to achieve it TURBOSAM Technical Stuff 199 25th November 2008 15:39
4 kmpl palio 1.6???? HELP!!! sajeeth Technical Stuff 66 6th October 2008 21:11
F.E. =150 Kmpl !! DCEite Shifting gears 12 30th March 2008 15:53
How to get 15+kmpl from a baleno ? Read on !!!! mclaren1885 Technical Stuff 133 19th May 2007 02:21
Grooved Maruti 1000 finetuning Technical Stuff 13 7th April 2007 02:38
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
