Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al).
Thread Tools
Old 29th August 2006, 10:10   #76 (permalink)
Kaizer Sozay's Avatar
Default 15 KMPH in 4th Gear
Hi please find an image of my Zen doing just 15KMPH in the 4th Gear
__________________
"The greatest trick the devil ever pulled was convincing the world he didn't exist ."
Kaizer Sozay is offline   Reply With Quote
Old 29th August 2006, 17:57   #77 (permalink)
hi Kaizer sozay/ finetuning,
I am interested in getting the heads of my ohc 1.5 grooved in Delhi. Please advise how to go about it. I have been regularly using acetone. I do not have any experiance of opening up engine heads.
amit mohan is offline   Reply With Quote
Old 29th August 2006, 19:23   #78 (permalink)
yogi1771's Avatar
hi kaizer what was the total amount u spent doing this
yogi1771 is offline   Reply With Quote
Old 29th August 2006, 23:06   #79 (permalink)
Dear amit mohan,
The basic requirement is to find a very good mechanic who has knowledge of engine & workshop.......u need to open engine head....need to remove some metal by surface grinding to increase ur compresson ratio(most probably 1 mm but depends on engine)....then need to make groove.....we have taken photo of grooves....I think kaizer sozay will share it....u need to replace many gaskets once head is opened......when fitting u need to check ignition timing....
Meanwhile do visit www.somender-singh.com for more information...
Enjoy....
finetuning is offline   Reply With Quote
Old 30th August 2006, 02:37   #80 (permalink)
Default Costs
The spare pare were original MGP & some parts for the mpfi zen are SGP so the total cost for spares came to 3400 Rs. The head shaving cost me 200Rs. The files for the grooves cost me 100 Rs.
My mechanic charged me only 1000Rs for a 3 day job but i feel thats very cheap as he is my regular guy. Total Costing 4700 Rs
__________________
Old 1st September 2006, 11:45   #81 (permalink)
dear amit,
firstly doing this will void your warranty and i am very certain that no honda workshop will do this kind of work for you.
Find yourself a local mechanic who is competent enough to open and close engine heads.
Also look for a machine shop that has a surface grinder.
Try and mail mr singh for the amount to whcih the ohc haead has to be shaved.
I will post the pics in the next few days
__________________
Old 2nd September 2006, 20:20   #82 (permalink)
Default The PUC Report!!!
A PUC Report in a way vaildates the change in performance of the engine.
I got the PUC done today on a PUC machine called ULTRA-TEC the readings are as follows (Both the readings are from the same machine at the same petrol pump)
Reading ----- Today----- 1 Year Ago
CO: ----- 0.326% Vol -----1.459% Vol
CO2:----- 12.19%vol ------11.49% Vol
HC: ----- 135PPM Vol----- 234PPM Vol
O2: ----- 0.00% Vol -----3.24% Vol
Lamda: ----- 0.982 -----1.113
AFR: ----- 14.43 -----16.36
I do not know what these readouts like Lambda & AFR are but every reading shows a significant Drop
The Permissible limit for CO is 3% The reading now is 1/10th of that All I can gather from this is that the Engine is Much More Enviormentally Friendly.
This is only possible if the combustion process is Complete & there is no Un burnt fuel being thrown out from the exhaust,
Also There is a lot of water being thrown out from the tail pipe.
__________________
Old 2nd September 2006, 23:46   #83 (permalink)
elf
elf's Avatar
Anybody done this on a Lancer yet, or would I be the first one?
Also, correct me if I''m wrong, but couldn't one attribute the increased power to the shaved head?
Am really interested in this for the torque gains, but want to clear doubts before chopping / shaving bits off my engine head.
And yes, I've already read the entire Somender Singh website (http://www.somender-singh.com/), so please don't send me any more links. Thanks.
elf is offline   Reply With Quote
Old 3rd September 2006, 02:13   #84 (permalink)
Yes you are right the shaved head would definetly result in more power but the Better Burn that is purely a result of the grooves.
Sorry dude not aware of anyone who has done it on a lancer. i was bold enough to gamble doing this on my zen.
__________________
Old 3rd September 2006, 03:44   #85 (permalink)
rohitbagai's Avatar
I am quite impressed with the grooves theory.. But..I have one confusion though…so please help….As far as I know…The ECM monitors the temperature of the engine and modify the mixture accordingly. If we start a cold engine the mixture is rich and as soon as the engine reaches its optimum temperatures the mixture gets leaner. In this thread some of you have mentioned that the temperatures at which the grooved engine runs is lower than the stock engine. So does the ECM read it and give a richer fuel mixture? If it does so it will lead to lower fuel efficiency…correct me if I am wrong?
rohitbagai is offline   Reply With Quote
Old 3rd September 2006, 12:11   #86 (permalink)
Well when i was doing this i had disconected the battery so the ECM has gotten Reset,
I am almost down on my 1st tankfull & i have been driving with a heavy foot, & My FE is approx 11 Kmph in really bad bombay traffic ( as for the past week i have been stuck on 3 ocassions in crazy jams with the Ganesh chatruti immersions) with the AC on.
So i can definetly say that my FE hasnt Dipped.
__________________
Old 3rd September 2006, 15:05   #87 (permalink)
Whenever we open an engine head for modification like grooves....we need to perform some more work to support it to enhance the benefit....we know that raising the compression is good method to increase the power......I increade my compression to 10:1 ........grooves gives direct path to squish area where no combustion or little combustion takes place because of its design.....this way we get fuel burning efficiently without waste.....this result in increase in FE.....
Enjoy.....
Old 3rd September 2006, 15:56   #88 (permalink)
rohitbagai's Avatar
Enjoy.....
I agree with the efficiency. But yours is carb. engine right? We can manually adjust the fuel mixture here. But what about engines with ECM? Normal temp. of grooved engine is around 40% less(acc. to previous posts) ...it will lead ECM to through in' richer fuel mixture?
Old 3rd September 2006, 17:32   #89 (permalink)
No its an MPFI, The temp diff is minimal in my car, but in finetunings Carb esteem its very noticeable.
yes you are right if the temp dips the thermostat will comand the ECM to throw more fuel resulting in lesser FE.
__________________
Old 4th September 2006, 00:26   #90 (permalink)
Mpower's Avatar
know that raising the compression is good method to increase the power......I increade my compression to 10:1 ........grooves .....
Can you let me know how you are calculating the new compression ratio. I am planning to inc the comp on my OHC and need to know how much material to remove and its effect on the compression.
__________________
The difference between the men and the boys....................is the speed of their toys.
Thread Tools
Max kmpl , and how to achieve it TURBOSAM Technical Stuff 199 25th November 2008 15:39
4 kmpl palio 1.6???? HELP!!! sajeeth Technical Stuff 66 6th October 2008 21:11
F.E. =150 Kmpl !! DCEite Shifting gears 12 30th March 2008 15:53
How to get 15+kmpl from a baleno ? Read on !!!! mclaren1885 Technical Stuff 133 19th May 2007 02:21
Grooved Maruti 1000 finetuning Technical Stuff 13 7th April 2007 02:38
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
