Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al).
Thread Tools
Old 1st January 2007, 22:59   #121 (permalink)
Mpower's Avatar
Originally Posted by finetuning View Post
Dear revvedup,
we need to change timing belt because we are removing metal from the surface of engine head...........old belt might not be as effective with surfaced head.....
But change to what...a smaller belt or just a fresh new stock belt. As long as the belt is in good condition, it should matter as long as you can adjust the tension to the correct spec.
I think you should change the cylinder head bolts, because they are torqued to yield (usually) and cannot be reused.
__________________
The difference between the men and the boys....................is the speed of their toys.
Old 1st January 2007, 23:11   #122 (permalink)
Diesel engine normally operate at higher compression ratios & ignition is automatic hence may be its difficult for groove to impart benefits.......
Also if we can find good amount of increase in torque then theoretically HP must increase.........but not tested so far......
For timing belt if adjustable tension is not sufficient then we need to change timing belt.......in my case I found it advisable to replace....also with different car there is different amount of material to be removed from surface so in some car we might need not change it...also I think changing head bolt is good measure for tighter fitting with right torque......
Enjoy....
finetuning is offline   Reply With Quote
Old 15th February 2007, 12:26   #123 (permalink)
vezj420's Avatar
Hey guys....I have a question on post-grooving torque:
When Kaizer and Finetuning mentioned that they are able to drop to low speeds even in higher gears (i.e. 20 kph in 4th) without knocking, does this mean that the engine rpm is also at or above idling speed?
I haven't gotten my engine grooved yet (running into schedule problems, you see), but I have got my Ikon 1.6 to run at 20-ish kph in 4th without knocking. However, the engine rpm sinks to 500! Is this the case in a grooved engine? I would think not.....
By the way, finetuning, my vehicle would not have been able to do even that (above) without acetone! so props again to you, man, for the evangelization!
__________________
Speed, it seems to me, provides the one genuinely modern pleasure.
- Aldous Huxley
vezj420 is offline   Reply With Quote
Old 15th February 2007, 14:04   #124 (permalink)
Hi vezj420,
Infact I can drive my car at 4th leaving pedal with 4 persons......normally on 4th gear we cant drive with full load at idle speed....suppose after touching speed of 40 on 4th gear we lift acce.pedal then slowly it comes down to say 20 or so when we get knocking..jerks and car engine stops..means engine torque is not sufficient enough to carry load at 4th gear at very less rpm.....
Driving at 20 on 4th is the indicator of plenty of torque at said rpm......this is a boon in city traffic....we can travell on 3rd throught including nicely carved bumps....in no way stock car can perform like this....at idle speed normal air fuel mixture is not sufficient to produce enough torque to behave in this manner but with grooves there is great amount of turbulence in both compression as well as power stroke(mixing air & fuel in most efficient manner) hence with same amount of air fuel engine produces more power which is capable of driving efficiently in city traffic....
If your car doesnt knock at 20 kmph on 4th gear then its producing excellent torque.....try this with 4 persons.....with grooves you can then travell at 15 or perhaps 10 or 5 kmph on 4th gear.....this seems unbeleivable but is very much true.....keep using excellent acetone in right amount....
Enjoy....
Old 15th February 2007, 20:14   #125 (permalink)
flipsyde's Avatar
anyone in chennai who has tried the grooving on their cars pls PM me. I am one step away from doing it and i sure could use some advice..... and probably a ride in ur car.
__________________
An architect's most useful tools are an eraser at the drafting board, and a wrecking bar at the site - Frank Lloyd Wright
flipsyde is offline   Reply With Quote
Old 15th February 2007, 22:49   #126 (permalink)
vezj420's Avatar
Hi vezj420,
FT, u got me there! I got to 20 in 4th with only me in the car, and I guess I was on the threshold of knocking.....rpm had sunk to 500, but interesting thing was the car was moving without jerking!
u still didnt answer my main query though - when u get to low speeds like 20 in hi gears like 4th, what rpm does your engine stay at? is it right around idling speed or does it sink below that?
__________________
- Aldous Huxley
Old 16th February 2007, 00:08   #127 (permalink)
Kaizer Sozay's Avatar
My Zen idling rpm is around 700 without ac. even on 4th gear the rpm is around 900-1000.
does this ans the question?
__________________
"The greatest trick the devil ever pulled was convincing the world he didn't exist ."
Kaizer Sozay is offline   Reply With Quote
Old 16th February 2007, 12:45   #128 (permalink)
vezj420's Avatar
yes, it does....thanks Kaizer!
__________________
- Aldous Huxley
Old 16th February 2007, 13:47   #129 (permalink)
Hi vezj420,
My car doesnt have rpm meter but I feel its not going below idle rpm on 4th.....it must be around 1200 to 1500 on 4th gear......I think kaizer pointed rightly on his zen...anyway your car is producing wonderful driving charecteristics which can only be enhanced with grooving.....beleive me it will be a great fun to drive grooved car.....Excellent DRIVABILITY is the main outcome of groove work apart from other benefits.....
Now after grooving with even full load you will be able to drive on 4th at idle speed......you can then simply accelerate from 20 to high speed without changing gear.......also after 40 kmph
we feel a kind of boost when we press acce. because of turbulence in combustion chamber......
Anxiously waiting for your groove work & results.....
Old 27th February 2007, 00:15   #130 (permalink)
NSF
Default Hi finetuning
As said grooving will impove the FE and also the torque.Is there only a marginal change in performance or much more than that.
cheers:
NSF is offline   Reply With Quote
Old 27th February 2007, 14:59   #131 (permalink)
Hi NFS,
I think you need to read thread carefully as everything is shared...
Now after grooving there is good amount of increase in performance....its not marginal.......
Enjoy...
Old 27th February 2007, 19:57   #132 (permalink)
Absar's Avatar
Hey everyone! This seems like a great thing to do! A great invention indeed. Hats off to him. So I was reading this thread. But I somewhat got confused. Someone here said that after grooving, the engine temperature decreases, and so the ecu gets programmed to provide more rich mixture. Wouldn't this reduce the FE? I know its a YES, but then how does the FE become better? Or after resetting the ECU, the ECU adjusts to the new low temperature as its normal temperature?
I have a Ford Ikon 1.6 2005 model. Whenever I try to go in 20 in 4th gear, it gives a force to get back to 1,000 rpm. No knocking tho. But I really like the thing of "full combustion" to get more mileage and torque.
On an earlier post, some one told that Mr.Singh would be stopping work and getting to concentrate on R&D.
If yes, then if I want to groove my Ikon 1.6, to whom should I go? I felt I should go to him only because he's the inventor for this and the pay should go to him only.
Still, is it possible to groove the Ikon 1.6? Would love getting more torque and mileage from it!
__________________
Ford Ikon 1.6 Nxt ZXi, 2005
I cried because I had no VTEC, until I met a person who had no 1.6 ROCAM.
Absar is offline   Reply With Quote
Old 28th February 2007, 09:07   #133 (permalink)
Nope my engine temp has not decreased I have an mpfi engine. The grooves can be done by any skilled mechanic, just call mr somender he will guide you.
__________________
Old 28th February 2007, 11:43   #134 (permalink)
Absar's Avatar
Hello Kaizer! Thanks for the update. I will contact Mr.Singh and get details from him. Thanks for the update on the engine temperature. However, has anyone already done it on a Ford Ikon 1.6?
__________________
Old 3rd March 2007, 14:38   #135 (permalink)
Absar's Avatar
Hello? This thread gone silent now..? I mailed Mr.Singh and I'm waiting for his reply regarding the grooving steps. I'm actually a bit impatient to do it for my Ikon 1.6. Btw, does this grooving job take a long time liek 3 - 4 days including the head removal, shaving, polishing/lapping, grooving and fixing the head back or is it possible in a single day? I might be travelling on a 800+ km trip next week (7/3/07-9/3/07) and I want to do it with a grooved engine.
__________________
Thread Tools
Max kmpl , and how to achieve it TURBOSAM Technical Stuff 199 25th November 2008 15:39
4 kmpl palio 1.6???? HELP!!! sajeeth Technical Stuff 66 6th October 2008 21:11
F.E. =150 Kmpl !! DCEite Shifting gears 12 30th March 2008 15:53
How to get 15+kmpl from a baleno ? Read on !!!! mclaren1885 Technical Stuff 133 19th May 2007 02:21
Grooved Maruti 1000 finetuning Technical Stuff 13 7th April 2007 02:38
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
