Old 18th April 2013, 11:48   #91
ACM
ACM's Avatar
Thanked: 2,883 Times
Default Re: Engine trouble in Mahindra Ssangyong Rexton EDIT: Turbo replaced under warranty
Safari TCIC Turbo costed Rs. 33K - Including labour and fitting in an outside garage.
Laura 1.9PD Turbo costed Rs. 75K - Including Labour and fitting in an outside garage.It costed Rs. 1.3L with Intercooler in ASS.
Both are outside garage prices are with kaccha bill.
ACM is offline   (1) Thanks Reply With Quote
Old 18th April 2013, 21:46   #92
Thanked: 17 Times
Thumbs down Re: Engine trouble in Mahindra Ssangyong Rexton EDIT: Turbo replaced under warranty
Replaced a Swift Diesel Turbo recently and costed Rs 18 K. Mileage of 60000 Km. Maruti Service Masters was the service station.
The Rexton case is awful. It plainly goes out of my list for a buy. Pity, I was seriously considering owning one.
Hiteshs77 is offline   Reply With Quote
Old 18th April 2013, 23:22   #93
GunMo's Avatar
Thanked: 43 Times
Originally Posted by .anshuman View Post
They have changed the entire Turbocharger. They've also assured me this was one off case and this is not a known issue with the car.
Their response after matter got forwarded to the Seniors was top notch. Everything from sourcing the Turbo to co-ordinating the pick up and drop of the car was top grade. At the end Mr.Dheeraj from Regional office assured me that they will try to treat every Rexton customer this way.
Well, well, that's good to hear. I hope it stays that way for a long time to come. Thanks .anshuman for bringing out this story as well as the update.
I will be watching out keenly before notching up Rexton on my 'next car' shortlist.
GunMo is offline   Reply With Quote
Old 19th April 2013, 05:38   #94
shabash's Avatar
Thanked: 59 Times
After reading the posts in the Thread and having countless number of personal experiences, I feel our nation is a nation of escalations. We are a democracy on paper, but a monarchy by actual process. Can't believe that Anand Mahindra (or people reporting to him) has to get involved to fix the issue with one car, that too their premium offering.
I feel every company in India need to have a new post added, incidentally that will also be called CEO - Chief Escalation Officer
shabash is offline   (7) Thanks Reply With Quote
Old 19th April 2013, 07:12   #95
Thanked: 25 Times
It is true with many of the services availed in our country, be it automotive, or banking, or home appliances. One good thing with automotive sector is, QUICK RESPONSE. If issue escalates, like this instance immediate attention is ensured. But when it goes to banking or home appliances, escalation has little role per my experience.
Thanks to Mahindra to consider this problem like war front and as per one of the internal sources, TBHP thread had given heavy weightage and become a hot topic in their meeting! Thanks to TBHP team for making such prestigious reputation. Cheers!
sujithpnair is offline   Reply With Quote
Old 20th April 2013, 00:01   #96
rkbharat's Avatar
Thanked: 613 Times
good to see things getting resolved, and I hope no more niggles.
How about putting up a review now
rkbharat is offline   (1) Thanks Reply With Quote
Old 23rd April 2013, 00:23   #97
fine69's Avatar
Thanked: 877 Times
Though I'm happy that through t-bhp one car lover's problem got solved, I think this is an even serious issue. 'Unless Anand Mahindra tells us to, we won't solve your problem or take it seriously', that's what Mahindra is all about is what this thread tells me.
I feel bad about those non-members who love their cars equally dearly however don't have t-bhp to put pressure on these idiots who would promise you the moon while selling a product but won't budge unless the company Chairman tells them to.
The only thing that I've learned from umpteen such threads is that if I have to buy a Mahindra or Tata, that better be my second vehicle, I better have enough time (if not money) to spend on it and should be prepared to get shocked in the most unimaginable way possible, which shouldn't actually be shocking since I bought something from the biggest shockers of all (if Skoda isn't offended by this please).
fine69 is offline   (1) Thanks Reply With Quote
Old 23rd April 2013, 01:10   #98
Thanked: 1,415 Times
1.3 L for a turbo break-down? Two such break-downs in 2/3 years and all the diesel running cost advantage will be negated. It will be cheaper to run a petrol City/Civic.
pgsagar is offline   Reply With Quote
Old 23rd April 2013, 08:55   #99
sagarpadaki's Avatar
Thanked: 1,331 Times
Turbo's hardly fail early "if" they are looked after properly. They easily last for 1 lakh+ kms without needing any attention.All you need to do is put the right amount of oil and don't prolong oil change intervals. I have seen an innova @ 4,50,000 kms running on stock turbo.What you are projecting about 2 turbo failures in 2/3 years, i presume, is the worst case scenario, correct?
In this Rexton case, it was a manufacturing defect!
sagarpadaki is online now   Reply With Quote
Old 23rd April 2013, 09:34   #100
ACM
ACM's Avatar
The Laura is known to have early turbo failures (especially early units). I had the first failure at 31,000 kms and it was repaired within warranty .The second failure was at 68,000 units and this was repaired outside for about Rs. 75,000.
The Safari TCIC Turbo needed to be replaced around 160,000 kms - So that is quite fine. I believe the Safari Tubro would have lasted atleast 250,000 kms with any other driver, I tended to race the engine hard and did not bother to idle the engine before shut down in the Safari - the turbo anyways was just about Rs. 33,000 of so.
ACM is offline   Reply With Quote
Old 23rd April 2013, 10:03   #101
n.devdath's Avatar
Thanked: 2,090 Times
Precisely.
Also Anshuman, this thread should now be closed and it could be reopened as the mother thread for all Rexton issues, if and when reported.
Old 24th April 2013, 12:13   #102
mmanchanda81's Avatar
Couldn't agree with you more. It's quite unfortunate though. Have always had to escalate the matter to the top most authorities to get issues fixed...be it maruti, tata motors, Hyundai or Mahindra, my experience is the same...the degree of responsiveness varies though.
The latest was my buying experience with Mahindra wherein the company dealership- NBS tried to hustle a showroom display Rexton to me. Fortunately during one of the many trips to the dealership, my paranoia led me to note the engine, chassis no of this display vehicle and when I got the engine no etc details from the sales guy, it matched! It took an email to Mr. Mahindra to get the dealer activated and thereafter things fell in place.
Apart from this, my vehicle (like a few others), had alignment and balancing problems and I had a tough time getting this resolved as well.
After getting an appointment for getting this fixed, when I landed at the NBS' workshop, i had to wait for over an hour for the RM. Later I was informed that their balancing and alignment machine was out of order and that I will get the car the next day.
I fired those guys and got my RM changed and shifted to Infinity. There too the machine was out of order..though they didn't inform this to me.
Apparently on the pretext of understanding the problem and test driving the vehicle, (they were quite adamant to not allow me to go for the test drive) , they were getting this done from a nearby tyre shop! I came to know this as the TD lasted 45 mins and I was told the driver had gone till BKC (from andheri east) but when the car came back, the problem was resolved and the car had clocked just 6 km.
In another week I shall be going for my first service and hope I'm not in store for any more rude shocks. Having said that, I'm extremely satisfied with the vehicle and no issues so far...hope it stays that ways!
mmanchanda81 is offline   (2) Thanks Reply With Quote
Old 24th April 2013, 23:02   #103
GunMo's Avatar
Thanked: 43 Times
Originally Posted by mmanchanda81 View Post
...NBS tried to hustle a showroom display Rexton to me.
Oh oh! Another bad experience by a Rexton customer. So far there are only two or three Rexton owners here in T-BHP and already we are hearing horror stories. All this even before an official test drive and review is done.
Sad to see a nice and capable vehicle being tarnished due to unprofessional dealers and ASCs.
I'm extra sad as I am (was?!) seriously contemplating on RX7 as it was ticking lot of boxes for me. Well, I'll wait for couple of months to see if there's any improvement. As such I'm mentally prepared to let this go and wait for another ideal vehicle. Lets see if Mahindra really 'rise' and pull me in!
Old 25th April 2013, 07:11   #104
headers's Avatar
Thanked: 464 Times
But today almost anyone can repair a Turbo. - 1 Week is the reasonable time frame. Repairs that have to be carried out within warranty tend to take longer due to documentation more than anything else.
Yes, if it is a small issue such as plumbing, but replacing the bearings are a tricky job and best left to manufacturers' authorised shop as they have the requisite testing tools.
AFAIK Maruti and Fiat do not use the same turbo, hence there is difference in pricing. Please correct me if i am wrong.
Fiat and MUL have similar Turbos but not the same IMO, though the engine is the same, the ECM and other electronics are different.
headers is online now   (1) Thanks Reply With Quote
Old 25th April 2013, 09:44   #105
ACM
ACM's Avatar
My Take:
Actually though service center should have their own allignment equipment, it is quite common for them to get the work done outside either due to their machine not working at a point of time or if they have a high amount of load. Has happened to me a few times with various brands and I wouldn't even know how and where it was done at other times.
Yep we would hope for them to be transparent about this, but they rarely are and actually if one thinks about it, we would not really look at them in good light if we knew that they get the allignment and balancing done outside and further charge a higher rate from us so can't blame them hiding this fact from us.
Actually Infinity worked to get your issue solved (though they hid how they were going to do it) and valued your time while NBS did not value it and were prepared to call you on another day.
Mahindra launches the SsangYong Rexton @ 17.67 - 19.67 lacs parrys The Indian Car Scene 215 13th August 2016 11:58
Skoda Yeti. 4.5 lakh repair bill! EDIT: Fuel system replaced under warranty Catamaran Technical Stuff 148 21st February 2014 10:54
SsangYong (Rexton and more) @ Auto Expo 2012 Rehaan The Indian Car Scene 30 3rd October 2012 18:24
Updated SsangYong Rexton! raj_5004 The Indian Car Scene 43 4th June 2012 18:01
Ssangyong Rexton Stratos Super-Cars & Imports in India 2 3rd June 2004 15:46
