| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #17 (permalink) |
| Senior - BHPian Join Date: May 2006 Location: Chennai
| If the car is running in dusty conditions, it would help if the radiator is cleaned ![]() Also the use of genuine thermostatic sensors are necessary
__________________ When the going gets tough, the tough get going. |
| | #18 (permalink) |
| BHPian Join Date: Jan 2006 Location: delhi
| Went through the thread "800 consuming coolant" http://www.team-bhp.com/forum/techni...g-coolant.html (800 Consuming coolant) I have been working on the issue for long now. The issue disappeared for a couple of days after the main hose that connects the radiator to the engine was replaced and after that another hose that’s smaller than the main hose gave up . But after a few days the car started overheating again. I haven’t been driving for the last two weeks , have been out of Delhi . The last time i drove, the car got heated up and there was a whistling sound from the engine with engine misfiring. As soon as i opened the hood the reservoir lid was open and the coolant was boiling . I was on the Noida expressway hence getting coolant was impossible. Got some water and filled up the radiator-- it was empty . checked for leaks -- did not find any leaks this time. As soon as i started the car the car started missing and died at idle . any ways i drove and parked the car at my house and haven’t driven since then . Today in the morning i filled up the radiator with water again and started the car. The fan came up after some reeving and later it stopped after the radiator cooled I opened it again --- Surprise its empty again . No leaks at all. Going back to the thread looked for white smoke -- here we go the car is emitting white smoke and also dies at idle and is missing. Looks like a perfect example of head gasket leak . Will take the car to MASS on Thursday . Is there anything else that I should see and will it be ok to drive the car for 10-15 km . will cool it at every 5-7 Km . also once I am at mass what all things should be changed and checked . How much should replace the HG cost. Last edited by bhogalrajnish : 11th July 2006 at 23:50. |
| | #19 (permalink) |
| BHPian | Dude dont let your car overheat again and again.Will cause the cylinder block to crack due to the heat and dont know what not.Get it towed to a mass.Thats the perfect and easy solution rather than causing permanent engine damage and causing even more expensive repairs.
__________________ Life is a lemon and i want my money back!!!! |
| | #20 (permalink) |
| Well Finally on thursday I took the car to Mangalam Motors -- Noida. The car was still missing . As soon as the mechanic opened the Oil cap he found that there was water in it . Replaced the Head gaskit with completre service and oil change. mangalam motors took 7 hrs for everything but by the end of it the car looks and drives really good . The aceleration now is really good and the best part no overheating now. Hope it runs like this for long. The last thing on my mind was that they found that the Coolent Valve (Valve between the radiator and the engine)was jam they did not have one in stock and the guy removed the one that was there as it was intrupting coolant flow. Will it be ok to drive without the valve . The explanation for the valve given to me was that is used for cold starting so that the engine heats up fast. How true is that... |
| | #21 (permalink) | |
| BHPian | Quote:
Also the engine will take more than normal time to heat up while starting for the first time in the morning.Guys correct me if i am wrong
__________________ Life is a lemon and i want my money back!!!! | |
| | #22 (permalink) | |
| BHPian | Quote:
moreover u engine parts will start to WEAR OFF faster than normal. engine can fail too. ur mechs want to see u soon to get ur babe a complete overhaul and a Fatter bill. dude get it fixed asap it costs nothing more than 300 to 500 bucks i suppose for esteem. its such a small part but plays a significant role in operating temperature of ur cars engine.
__________________ 332kmph 1999 unrestricted GSXR1300R ROYAL ENFIELD MACHISMO 1992 636 RB20DET NISSAN Last edited by 2fast4u : 16th July 2006 at 01:01. | |
| | #23 (permalink) |
| BHPian Join Date: Aug 2006 Location: New Delhi
| Hi Bhogalrajnish,... I had similar problems with my Esteem. Initially got the Head gasket changed 2 times within 8-9 months span. Then because of over heat the Head's layout didn't fit on the block. So I had to get it phased. Next time (after six months) Got the cylinder block phased out to match the head. NEXT I replaced the head with a new one. It would have continued if I had not sold it off. Some tips:- To check if its happening again ...open the lid of the radiator (obviously when engine is cool) and see if it has some oil content mixed up with the coolant. (Your fingers will feel slippery) If you find no oil that's great!! But if you feel its there to verify it, keep the lid open of the radiator and ask some one to start the engine. Keep yourself at safe distance as the coolant can come up like a fountain.Ask the person to rev the engine quickly 3-4 times for from 1000 rpm to 3500 rpm. If you see coolant coming out with pressure it means that the head needs treatment again. But if not the car is good to drive.!! Avoid using A/C in traffic Jams (I know its not easy) Get the coolant pipes thoroughly checked. Sometimes there is a mild leakage at the O-Ring of the pipe on the back of piston cylinder and because cylinder is hot the coolant drops get evaporated and leaves no mark. Get the timing checked...even ask mechanic to tweak it so that engine don't get overheated. Increase the cooling capacity of the radiator fan by using a 6 leaf fan wing of Alto (You can get it for around Rs. 100-150 from Jama Masjid. ) Check the fan of A/C to confirm its not running reverse. Thanks Rohit Last edited by rohitbagai : 11th August 2006 at 18:19. |
| | #24 (permalink) |
| Senior - BHPian | guys, the esteem has an all aluminium engine, it will heat up in a few minutes to more than 50%, it is no cause for worry, as long as it does not get into the red zone. it will also cool down as fast as it heats up. so just relax & enjoy ur drive, people. p.s. if u still feel that it heats up too fast, contact MASS
__________________ R.I.P Islero |
« what should I use to calculate real speed of my Zen...
Can a service cause pick up to drop - Ford Ikon 1.6 ZXI »
| Thread Tools | |
Similar Threads | ||||
| Over heating ikon | govigov | Technical Stuff | 8 | 4th August 2008 11:56 |
| Scorpio's heating unit | gd1418 | Technical Stuff | 8 | 31st July 2008 12:07 |
| weird heating problem in accord | prateek | Technical Stuff | 23 | 22nd June 2007 16:29 |
| Over Heating Problem | lancer_maniac | Technical Stuff | 13 | 13th December 2006 19:32 |
| Over Heating Amp i Guess. HELP | saint_sinner | Ask the Gurus | 8 | 16th October 2006 14:20 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458
