Old 9th August 2013, 13:21   #16
Rajith's Avatar
Thanked: 407 Times
Default Re: Maruti Swift 1.3L DDIS engine overhauled at only 78,000 kms!
55k/ 3 Years engine needs overhaul? Let us know the whole story and the problem you are facing. Repair cost looks on the higher side as half-engine kits are cheaper and easily done.
There was rough noise from the engine all of a sudden, given to asc. They have dismantled the same and given report as engine failuer.Need a rebuilt.
Rajith is offline   Reply With Quote
Old 9th August 2013, 13:25   #17
saket77's Avatar
Thanked: 5,039 Times
Looks like it was running low on engine oil or the engine oil leaked. BTW, why 1.35 lacs for a rebuild?
saket77 is offline   Reply With Quote
Old 9th August 2013, 13:40   #18
Thanked: 687 Times
@Rajith : Shocked at this failure... this is why I fear diesel engines. I just dont believe diesel in India as it is delivered today is as clean a fuel as in Europe/US, unlike petrol.
gsurya is offline   Reply With Quote
Old 9th August 2013, 14:31   #19
saket77's Avatar
Fuel adulteration is rampant for sure, but I believe other reasons behind the failure too. Rough noises from the engine, in this case, IMO point to lack of lubrication/ engine oil.
Old 9th August 2013, 14:34   #20
drsingh's Avatar
Thanked: 484 Times
My regularly serviced 3 year old swift with vdi engine conked off. Done 55000kms. Now repair cost is quoted @ 1.35lacs.
I have taken only 1 year extended warranty and same has expired by last march.
Is it because of trying to get too much from a small engine !!.
This is definitely premature failure of a critical component. I had come across a 33k run safari with failed crankshaft leading to engine failure just after warranty. They had sued tata and the dealer and we're confidant of winning the case.
drsingh is online now   Reply With Quote
Old 16th November 2014, 07:19   #21
fireblade007's Avatar
Thanked: 56 Times
Does maruthi sell refurbished ddis engines or half engine kits for ddis?
fireblade007 is offline   Reply With Quote
Swift DDIS SVS Light turns Off only after engine starts(ECU records immobilizer code) tush Technical Stuff 58 10th November 2014 20:51
Problem in partly overhauled 5 speed maruti 800 ramkris Technical Stuff 19 3rd August 2010 13:25
economy diesel duel: Maruti Ritz DDiS vs Suzuki Swift DDis vs Vista quadrajet aura. s_pphilip Test-Drives & Initial Ownership Reports 25 29th October 2009 09:43
Swift DDiS vs Ritz DDiS vs iKool ? anoovis Hatchbacks 1 21st October 2009 13:09
