Old 25th April 2013, 16:11   #1
Thanked: 25 Times
Exclamation Eliminating Wind Noise
I find a lot of wind noise(howling) inside the cabin when driving my Skoda Laura at 120 kmph and above. I noticed this especially when I drive on the Mumbai Pune expressway. The moment I decelerate below 120 kmph the noise stops. Also when i floor the accelerator and touch 160 plus the noise stops.
I have checked if Bonnet was not shut properly, windows if left cracked open, rubber beading on all doors appear OK and not torn, worn or broken.No protrusions which may cause the sound. Cannot feel the ingress of any air past the windows or doors
Recently my Aircon compressor was replaced. Could there be some link here ?? if so what should I get checked out.
How do I isolate and identify the source. Takes the pleasure out of driving.
Any feedback welcome
regards,
Seacat
Seacat is offline   Reply With Quote
Old 25th April 2013, 16:41   #2
Thanked: 1,172 Times
Default re: Eliminating Wind Noise
Is it surely wind noise?
What if you drive with AC OFF and all windows rolled up?
What if you drive with AC OFF and all windows rolled down?
What if you drive with AC ON and all windows rolled down?
Any difference when you use fresh air mode versus recirculation mode?
How old are the tyres and how do they look?
anandpadhye is offline   (1) Thanks Reply With Quote
Old 25th April 2013, 16:57   #3
Thanked: 25 Times
Hi Anand,
many thanks for the fast response. To answer you;
1. AC OFF + Windows UP - Not tried- will do and revert soonest
2. AC OFF + window down - Not tried - scared to do this at 120 kmph !!- previous
experience on my Ford Fiesta blew my rear w/screen off on the E.Way :-). They said
it was air pressure but I think it was a bad piece... car was only 5 days old at that
time !!
3. AC On + Windows UP -
4. Tyres - good shape - car is a jan 2011 model
Seacat
Mod Note: Team-BHP strongly discourages unsafe driving practices that put yourself and other road users at risk. Please do NOT post about illegally high speeds on public roads.
Old 25th April 2013, 16:59   #4
Jaguar's Avatar
Thanked: 151 Times
This is a known issue. My friend also faces the same issue in his Laura especially after a wash. The source is front window beading. I remember him saying that the noise is reduced if you keep the front windows a bit open.
Jaguar is online now   Reply With Quote
Old 25th April 2013, 17:17   #5
VW2010's Avatar
Thanked: 2,124 Times
@Seatcat
Wind leakage either through beading or could be a design flaw of side mirrors. Try closing the mirrors and drive to see if the sound profile changes.
The side mirror and noise is infamous in some cars but not sure if laura is one of them.
The howling can also call for some mechanical problems. Check this link for other reasons why howling can happen.
http://www.2carpros.com/articles/car-howling-noise
VW2010 is offline   Reply With Quote
Old 25th April 2013, 17:23   #6
Thanked: 25 Times
Mod team note: Back to back posts, please wait for Mod approval of posts. Thanks
Hi Jaguar,
Cannot understand why a noise after a wash !!! Does your friend know the reason for this.? Is he 100% sure ?? Is it window or windscreen beading ? Should I change the window beading ?? Really want to know because you would appreciate that Skoda parts are EXPENSIVE so don't want to go by a trial and error method.
Seacat
Thanks VW2010, Yes I tried closing the OVRM's but no improvement. Will check out the link. Many thanks
Fellow BHPians,
I will be travelling out of India for the next 15 days so If I dont reply please excuse but please dont stop giving me all your suggestions . I really look forward to them
Last edited by Jaggu : 25th April 2013 at 17:33. Reason: Back to back posts, please wait for Mod approval of posts. Thanks
Old 25th April 2013, 18:01   #7
Thanked: 43 Times
Originally Posted by Seacat View Post
3. AC On + Windows UP - Wind noise starting at 120 kmph up till 160 kmph . Beyond
160 all is silent. Did not push beyond 165.
Is the AC in Recirculation Mode or Fresh air mode?
In my Swift if I keep the car is in Recirculation Mode Off + AC Off + Blower off, at high speed (above 120Kmph) I can sense the stream of air coming through the air vents inside the cabin. If I keep it in Recirculating mode then I donít feel the same.
abhijitvp is offline   Reply With Quote
Old 25th April 2013, 18:04   #8
time !!
Interesting. I have driven at such high speeds (infact touched the top speeds as well )with all windows rolled down, many times. it may not be aerodynamically efficient, but other than that there should be no problem. Of course, if you roll down only the front two windows, there there is a lot of wind noise, and it reduces drastically when you roll down the rear two even by a few inches.
BTW, my Laura has not faced this issue yet (it's a Feb 2010 car), so I would say it's not a design issue (related to mirrors or anything)...
May be you can record the noise and upload the file here so that someone can crack the puzzle...
Cheers!
anandpadhye is offline   Reply With Quote
Old 25th April 2013, 18:08   #9
tbppjpr's Avatar
Thanked: 490 Times
Flip side thinking is that are you sure its wind noise and not the road/tyre noise? I am doubting on the tyre noise because you mentioned you feel the noise higher when driving on Mumbai-Pune E-Way and that is concrete road where tyres make more noise. If that is the case, you can play with different air pressure in tyres.
tbppjpr is offline   Reply With Quote
Old 25th April 2013, 18:17   #10
Thanked: 25 Times
Gents,
Thanks for the comments so far. to reply to all;
1. AC was kept in Recirc mode. I never put it on Fresh air. In Mumbai you will get
gassed otherwise :-)
2. This does not only happen on the expressway but I have also experienced it on Palm
Beach road in Mumbai at night with no traffic where I could floor the accelerator.
3. Tyre pressure - I have driven with diff tyre pressures but Yes perhaps i could retry
this one .
Old 25th April 2013, 18:57   #11
hey!! this is a known problem. I saw it first in my Skoda laura. I showed it to the A.S.S. but they couldn't identify the problem. However, it was rectified itself. After a month or so the same thing happened to my friend's Skoda laura. He also went to the service center but they still didn't have the solution. He waited for the sound to go by itself but it didn't so he went to the service center again but was shot down same as last time but this time he got angry and asked them for a written acknowledgement of the problem and the fact that they are unable to fix it. So the service adviser kept his car for another day and next day voila no noise. When he asked what they did, they replied that some nuts and bolts were faulty and they were replaced.
so now you can either go to the A.S.S. or you can wait for it to go away. Its up to you. In my case i heard the sound an year after buying the car. It went away after a month and i haven't got it back since 2 years.
cheers,
varun
varunsonu is offline   Reply With Quote
Old 30th July 2014, 14:18   #12
Default VW Vento TDi Windnoise
I need some help on this one, please. My Vento is about 6 months old, and I've been facing this issue from the beginning.
There is a distinct hissing sound coming in from all 4 windows - typically at the point where the door glass meets the door glass run. I've done about 4 trips to the VW Service Center and they've tried checking the door body alignment, door glass alignment, using some spray, etc. But there is no change to the situation. I had a Polo earlier, and it did not have this issue at all. Once the windows were up - it was only the engine noise and road noise that filtered into the cabin.
Furthermore, this niggling issue sets in at speeds > 80 kmph, and I'm not sure if I'm imagining - but I feel that the stability of the car goes down, as thought it gets buffeted by the wind (esp. on the E City elevated tollway in Bangalore). I can feel a light sway which needs a light correction to the steering wheel.
Any pointers / suggestions?
Thanks,
Vinod
vinodrkn is offline   Reply With Quote
Old 31st July 2014, 13:51   #13
cool_dube's Avatar
Thanked: 402 Times
Default Re: Eliminating Wind Noise
Tyre pressure - I have driven with diff tyre pressures but Yes perhaps i could retry this one .
When was the last time you got WA/WB done?
cool_dube is offline   (1) Thanks Reply With Quote
GreenLight: Reduce traffic jams by eliminating 'right turns' at signals D4D Street Experiences 47 6th November 2014 09:40
Windshield - Wind Noise bjawah Technical Stuff 4 11th September 2014 16:25
Wind Noise in Safari Ramkumar Technical Stuff 2 13th August 2007 17:58
Wind noise or Aerodynamic noise vivaid Technical Stuff 15 2nd July 2006 19:58
