Old 26th April 2013, 10:24   #1
Thanked: 39 Times
Default Trouble with the Zen's ECU
Im trying to fix low mileage and erratic idling problem with my Maruti Zen 2005 MPFI model. (i have been trying to troubleshoot the problem for more than a year).
After replacing, IAC value, TP sensor, Throttle body, gaskets..etc..
I have finally narrowed down the issue to incorrect and fluctuating TP sensor Voltage
The voltage keeps fluctuating on its own.
I followed the troubleshooting steps given in the service manual.
Please refer to the attached image for my observations.
The test involves disconnecting TP sensor connector and measure the voltage from the ECU end.
Im observing 2.5V instead of 5V specified in the manual.
Is the replacement of ECU the only possible solution?
or
My half baked knowledge says i can connect a pull up resistor outside the ECU between terminal 'a' and 'b' to pull up the voltage to 5V.
Will this solve my problem?, in that case what should be the resistor value?
Im looking for an alternate solution, I dont want to spend on money on a new ECU :-(
T1000
T1000 is offline   Reply With Quote
Old 26th April 2013, 11:24   #2
n.devdath's Avatar
Thanked: 1,714 Times
Default re: Trouble with the Zen's ECU
or
While repairing an ECU is possible, it is very tough to get such expertise in India unless you are willing to take the risk.
I would suggest you get in touch with someone who is good in FMCG electronics since they function in a similar manner and see if that person can check the resistance required and source it.
Since you will anyway need a new ECU, you will not lose anything if you end up blowing your existing one. For all you know, you might be able to get it repaired.
Keep us posted.
n.devdath is online now   (1) Thanks Reply With Quote
Old 26th April 2013, 11:35   #3
DerAlte's Avatar
Thanked: 2,876 Times
How did you check "incorrect and fluctuating TP sensor Voltage "? At which point? Using what instrument?
There are 2 possible reasons - and they are mentioned in the table under NO.
1. Disconnect the connector near ECU (careful - don't pull the wire harness), and inspect the pins. Don't use any abrasives - use a typewriter eraser (those old round ones) to remove dirt from pins. Make sure all pins are straight (use forceps if they aren't) and reconnect the connector
2. Check the harness wires for obvious signs of cracking or fraying. Use electrical tape to cover those areas
"can connect a pull up resistor outside the ECU between terminal 'a' and 'b' to pull up the voltage to 5V": No you shouldn't - you will make the problem worse.
* 'a' is the supply point, and it reads 5.20V - that is what it should be
* Voltage at 'b' should vary with demand. If it is varying with pedal at rest, quite likely the position sensor is at fault (dirty wiper inside the pot), especially at either end of travel.
You can check this by checking resistance, with ignition switch off, between points 'b' and 'c' with and analog multimeter (DMM has higher time constant) while moving the vane - you should be able to detect jitter
DerAlte is offline   (1) Thanks Reply With Quote
Old 26th April 2013, 12:27   #4
Thanked: 39 Times
Keep us posted.
True, Thats the motivation to play with ECU, you dont get many chances :-).
BTW, Im mentally getting prepared to buy a new ECU, the cost is Rs 12700.
Old 26th April 2013, 12:52   #5
Thanked: 39 Times
Well, Ive been driving with a digital multimeter connected to various points at the ECU harness side for the last 15 days.
Im cross checking the values with the service manuals.
The multimeter probe is connected to ECU end.
Its like for two days i monitored O2 sensor values, then another two days with TPS sensor.
The tps sensor value is within range when the ignition is ON and engine is OFF.
The voltage fluctuates when the engine is running even with no movement in accelerator pedal.
While driving everytime the pedal returns to idle position the voltage read is anywhere above 0.8 to 1.2 where as the manual says the it should be 0.78 to 0.83
The connectors at the ECU looks clean and straight.
Wiring looks clean
Agreed. As per the manual when you disconnect the sensor and measure the voltage from terminal 'b',(ECU harness end) the voltage should be 5V.
My understanding is, this means the line is internally pulled up using a resistor to maintain 5V and the voltage reduces as the pedal is moved.
Is my understanding correct?..is it worth to take the risk?
I changed the throttle body and TPS sensor yesterday. The resistance values are within range.
Im going to check the ECU for visible damages during my lunch time, will come back if i find anything interesting :-)
Old 26th April 2013, 13:34   #6
DerAlte's Avatar
... The multimeter probe is connected to ECU end. ...
Connected how?
... The voltage fluctuates when the engine is running even with no movement in accelerator pedal. ...
Shouldn't you be also observing whether the throttle valve is moving or not (in the TB)? It is controlled by the ECU (drive by wire?), and may be continuously positioned based on situation. The TP sensor only senses the throttle valve's position.
... While driving everytime the pedal returns to idle position the voltage read is anywhere above 0.8 to 1.2 where as the manual says the it should be 0.78 to 0.83 ...
So what would be the inference?
... Agreed. As per the manual ...
Is my understanding correct?..is it worth to take the risk? ...
What if it was a "Pull Down resistor"?
Inside the ECU, one cannot get a reliable reading with ADC if a point does not have definite voltage, i.e. if in an input line is open. That high value (as compared to the TP sensor) resistor is only a protection to ensure one gets a reliable reading if the point is open, or senses an error if the wire shorts to ground (in which case the resistor will limit the short circuit current). You putting another resistance in parallel (effectively reducing that resistance) is going to do zilch - it will only make things indeterminate in the ECU, which will now read a different open state voltage corresponding to the TP input point. It may even declare that line faulty.
... Im going to check the ECU for visible damages during my lunch time, will come back if i find anything interesting
If the ECU has to go bad, LOT more stuff would have gone bad - to the point that the engine wouldn't be running smoothly, or it would have either gone kaput or running in 'Limp Home' mode. Anyhow, happy hunting.
DerAlte is offline   (2) Thanks Reply With Quote
Old 26th April 2013, 13:44   #7
hellmet's Avatar
Thanked: 637 Times
Sorry I don't know any of the technicalities, but a gone ECU is a gone ECU unless you can get someone to repair it, which will also be surely expensive as I had faced this situation with my car in the US. I ended up getting myself a refurbished ECU off of eBay that cost the same as the repair, which worked well until I sold the car away.
Since India's eBay hasn't matured, you might want to ask salvage yards or car mechanics to see if they have any ECUs from the cars they salvage from accidents. 12K is too much to pay for a chip.
hellmet is offline   (1) Thanks Reply With Quote
Old 26th April 2013, 14:24   #8
Thanked: 39 Times
Agree with you, 12K is too much and im not sure if it will solve my mileage problem.
Old 26th April 2013, 15:05   #9
Thanked: 39 Times
Post Re: Help needed from ECU gurus!
Connected how?
I just insert the positive terminal of the multimeter to the connector.
A crude way of doing, but i dont have a choice.
Throttle is controlled by mechanical linkage. TP sensor only senses the position of the butterfly value. ( i installed a new throttle body and tp sensor yesterday).
I ensured that the throttle is fully closed many times, i even checked it from the throttle body end.
My *Guess* is as follows,
When the throttle is closed , TP sensor value should be in the range of 0.78 to 0.83V
The values im observing are way above, in the range of 0.88 to 1.2V.
It makes ECU think that the throttle is open and uses incorrect fuel ratio and it may also affect fuel cut off operation or mishandles idle air supply.
This increases fuel consumption.
Few more observations,
- i get very good mileage on the highways, 22km/lit and 8-9km/lit in city(without much traffic). earlier i used to get 15km in city.
- No carbon buildup or oil observed in the spark plugs - i assume O2 sensor is working fine.
- Engine runs smoothly
My conclusion is, cos of incorrect TP sensor values, ECU gets confused during idling.
:-) This is again a guess, Pull up/down resistors are used to give a default value to a signal probe. When the TP sensor is disconnected the signal line must give 5V. if it gives 0V then we can assume its pull down.
Some info
http://www.seattlerobotics.org/encod...97/basics.html
http://cnmat.berkeley.edu/recipe/how...ontroller_i_o_
I got what you are saying, im not going to try it until im sure of what im doing.
Agreed. But my problem is even if i change the ECU there is no guarantee that my mileage problem will be solved.
I opened the ECU now, the circuit looks clean , no visible damages or loose connections.
Old 26th April 2013, 15:44   #10
Thanked: 152 Times
Infractions: 0/1 (5)
Default Re: Trouble with the Zen's ECU
As per my information during servicing my Zen at MASS Zen Euro II and Euro III had different setting/values for TP sensor .For Eg if you get a new TP sensor then they can program it via the Suzuki scan tool for different values.
Trust_In_Thrust is offline   (1) Thanks Reply With Quote
Old 29th April 2013, 14:29   #11
Thanked: 39 Times
An Update and sharing my experience with ECM!
I removed the ECM circuit and used my macro lens to get a closer view of the circuit.
I noticed lots of tiny metal dust particles(see attached picture) on the circuit, must be lead dust which wasnt cleaned after soldering.
I suspected these metal fragments have the potential to short circuits. I cleaned the circuit board with isopropyl alcohol using a tooth brush.
I quickly tested the cleaned ECM in the vehicle...It solved one of my problem!!!
TP sensor voltage which used to fluctuate on its own was stable and the sensor was behaving as expected.
Now everything seems to be normal, i'll have to check the mileage in couple of days.
Now the only pending issue is, As per the service manual, voltage level with the TP sensor disconnected should read 5V, but im still getting 2.25V. (Step 2 in the "trouble shooting TP sensor circuit" section )
Can this point be overlooked?
T1000 is offline   (2) Thanks Reply With Quote
Hyundai i20 ECU Trouble agg.arpit Technical Stuff 18 26th July 2017 00:07
New Hyundai I20 Petrol - Engine + ECU trouble - Car breaks down 1500 KMS maverick145 Technical Stuff 37 25th January 2012 13:30
Zen Fuel pump short - damaged ECU fiat_tarun Technical Stuff 8 31st December 2011 17:39
Power Steering fluid and ECU Zen Vxi nicejits Technical Stuff 5 11th March 2008 15:17
ecu mods in delhi for zen? rev_hard Modifications & Accessories 7 26th January 2006 04:11
