Old 22nd May 2006, 12:44   #1
Default Turbo emits lot of smoke and top speed has gone down
Hello All,
A problem cropped up with my Indica Turbo DLX during the past one week.
It has started emitting a lot of smoke and the Top speed has gone down drastically. Infact, in the fifth gear, the Top speed does not cross 85KM.
Also, I have to shift down to 3rd or second gear evertime I have to drive uphill.
Wondering what could be the problem.. Your help is greatly appreciated..
Heres a little bit about the car usage: I have bought the car 6 weeks ago, and it has travelled 1800KM so far. I take the car out 3 or 4 times a week, and adhere to the instructions like idling the car before shutting down.
Best Regards,
Rajkumar
RajTurbo is offline   Reply With Quote
Old 22nd May 2006, 12:50   #2
tsk1979's Avatar
Thanked: 15,638 Times
Get the FP checked. Most likely bad fuel screwed up some things. Since its a new car everything should be sorted out under warranty.
Also is the smoke completely black or you see blue smoke?
Old 22nd May 2006, 12:53   #3
karthik247's Avatar
Thanked: 16 Times
Hmm....two Indica Turbo damages in a small time. Both being sparingly used.
Maybe its just something wrong with TATA's turbo
karthik247 is offline   Reply With Quote
Old 22nd May 2006, 13:05   #4
Thanks Tanveer.. As I see it while I am driving, it is black. But I will double check and let you know.
Any other thoughts regarding what could be wrong..?
Raj
Hey Karthik. what is the problem with the other Turbo you mentioned..?
Old 22nd May 2006, 13:19   #5
karthik247's Avatar
Thanked: 16 Times
http://www.team-bhp.com/forum/long-t...-5000-k-4.html
Old 22nd May 2006, 13:27   #6
drifter's Avatar
Thanked: 13 Times
The other turbo had a leak in its piping if i remember correctly.
Drifter
drifter is offline   Reply With Quote
Old 22nd May 2006, 13:30   #7
diven_b's Avatar
hey raj
going uphill in 2nd or 3rd is ok.........but speed not crossing 85kmph in 5th gear is not ok.....usually diesel engines are sensitive to adultrated fuel.so that could be a cause.......did u get it checked with the service station?
diven_b is offline   Reply With Quote
Old 22nd May 2006, 13:57   #8
@Karthik, Drifter - Thanks guys, I have read thru the link provided.
@Diven - I have not had the car checked at service station yet. Will have it done this week. When I said uphill, I am comparing how the car used to behave a couple of weeks ago, and how the car is behaving now. There is a drastic difference in the pickup while going uphill..
Anyways.. After I get it checked at the service statition this week, I will let you all know how it went..
- Raj
Old 22nd May 2006, 14:03   #9
Psycho's Avatar
Thanked: 95 Times
The turbo exhaust oil seal is gone...
Old 22nd May 2006, 14:10   #10
himanshugoswami's Avatar
Thanked: 1,018 Times
Hi Raj,
As karthik had mentioned, I had a torrid experience with my turbo as well.
In my case it was abrupt cut off of oil ot the turbo due to plumbing leak, when the turbo was on full boost, thereby causing malfunction due to excessive heat build up.
as psycho said, your case seems o be an oil seal going kaput-hence the excessive smoke.
Also, get ur clutch cheked. Speed notcrossing 85 could also point to a clutch malfunction.
I am not too much of a mech guy- so these are a layman's observations.
If u plant to keep your car longterm, you MUST get extended warranty.
I sold mine off in sheer disgust!
himanshugoswami is offline   Reply With Quote
Old 22nd May 2006, 14:12   #11
diven_b's Avatar
[quote=Psycho]The turbo exhaust oil seal is gone...[/
just curious.how does that explain the smoke???
Old 22nd May 2006, 14:18   #12
Thanks Psycho and Himanshu.. I have made a note of your suggestions. They will be handy when I talk to the Tata service people.
Yes. I have taken extended warranty, and it will be handy for self or for better resale value.
Old 22nd May 2006, 14:20   #13
Psycho's Avatar
Thanked: 95 Times
Your engine oil is being vapourised in the exhaust housing of the turbo putting out smoke... It would be white if it was on your intake side, as it would lead to burning of the oil. (in this case your turbo is still working with a blown oil seal)
In the second case if your turbo has jammed and stopped functioning and if your oil line is still flowing properly then it would be that your engine is pumping in excessive diesel leading to the black smoke.
Easiest way to check is to see if you hear the turbo whine when you drive.
Old 22nd May 2006, 14:44   #14
Thanks Psycho..
I think it may be a problem with the Turbo.
Whenever the Turbo kicks in, I hear a small click from somewhere behind the steering, and then I see the car accelerating (earlier and now also).
Now - at lower speeds, I still hear the clicking, and the car accelerating (though with a good amount of smoke from exhaust). However, in higher gears (4th and 5th), I dont hear the Turbo click sound and also the car does not accelerate further. I am only able to maintain a steady speed in the higher gears.
I will try to hear in the Turbo whine when I drive tonight.
Raj
Old 22nd May 2006, 15:14   #15
drifter's Avatar
Thanked: 13 Times
Try driving with the AC off...and listen for the click. I suspect thats the compressor clutch making noise. Also check the EGR valve. One friend had a similar problem and was traced back to a faulty EGR valve.
Drifter
Pulsar 180 Engine Overheating, emits White Smoke - Please help para_7k Motorbikes 36 20th April 2017 20:38
Diesel Cars: Down, down, down! Market share = 34% S2!!! The Indian Car Scene 66 2nd June 2016 16:21
Crazy amounts of smoke and knocking after a high speed run (Logan Diesel) CrackedHead Technical Stuff 10 2nd April 2012 10:56
Hello... new user who has been around the forum a lot. Machine freak Introduce yourself 1 2nd November 2008 16:52
Top Gear 2006 Survey : Fiat zooms into top 10, Honda, Skoda top list. amit The International Automotive Scene 10 8th March 2007 12:31
