Thread Tools
Old 22nd May 2006, 14:26   #1 (permalink)
dev
Angry Power Steering oil Leak
Dear BHPians,
My Ford Ikon had Power steering leakage and the entier oil is gone. It is giving lots of noice, since oil is not available. I approaced garage and they told, oil seal was hit and got damaged. Oil leaked from there and need replacement. He is asking for Rs.1500 as labour charge as he needs to remove Steering completly and set the oil seal kit.
And the spare part (oil seal) will be costing 2000+.
So, totally Rs. 3500/-
Is the above price correct? My close relative drived for a long distance with this problem. I am really sad it happened to my vehicle.
I referred to the below link, but of noty much use..
http://www.team-bhp.com/forum/techni...rsteering+leak (Power steering noise)
Any ideas and suggestions are welcome..
thank you.
dev is offline   Reply With Quote
Old 22nd May 2006, 14:50   #2 (permalink)
nitrous's Avatar
Now, why is this posted in the Shifting-gears section???
__________________
Maruti - Everyone comes home with rattles!
nitrous is online now   Reply With Quote
Old 22nd May 2006, 19:28   #3 (permalink)
Are you sure that your mechanic is reliable? It could be just a cut in your hose. Anyhow, 3.5k sounds cheap as a friend had his rack & pinion unit serviced at a ford dealer for about 8K!
__________________
Live Life King Size!
jyobeb is offline   Reply With Quote
Old 23rd May 2006, 13:24   #4 (permalink)
dev
I am not sure how the mechanic is. This is the first time I am approaching this person. Today I got info that I need to change the entire Steering kit as it is linked to OIlSeal. Any repair to Oil Seal is not given warranty as it is not a permanent solution. The entire kit costs around 20k and we are looking for a used kit which will come with warranty. I have given this vehicle in Kormangala 3rd block.
Old 23rd May 2006, 17:36   #5 (permalink)
dev
Dear BHpians,
It is surprising nobody is providing enough info. Looks like I have fewer options left. Either go for a used kit or get Oil Seal fixed taking risk.
what you people say?
Old 23rd May 2006, 18:54   #6 (permalink)
dev
I have given my vehicle at Haymond Automobile Centre, BLR.
Is this a good garage?
Old 23rd May 2006, 20:43   #7 (permalink)
drifter's Avatar
I cant really comment about the problem because have never faced such a failure.
But i suggest you get an opinion of a second mechanic.
By the way, havent you tried the authorised service centre.
Drifter
__________________
Slow Everything Down And Feel Like God - Tata Safari
drifter is offline   Reply With Quote
Old 24th May 2006, 14:30   #8 (permalink)
dev
Drifter,
I have approaced Authorized service centre and they recommended to change the entire Kit which costs 18-20k.
A used one is costing 8k.
Old 24th May 2006, 14:34   #9 (permalink)
You're taking a risk with a used assembly. Remember that its going to be removed from a car only if there is a problem with it, or if its from a total loss accident car. Either way, dicey.
__________________
Old 24th May 2006, 14:45   #10 (permalink)
dev
That's why I told to fix the existing one for the time being and if it leaks, I will approach Service Centre for replacing with a new one. I will get the Timing and others fixed by them.
Thread Tools
Power steering oil leakage in Santro Sush Technical Stuff 2 18th November 2007 10:33
Maruti Esteem - Non Power Steering to Power Steering udit78 Modifications & Accessories 9 1st October 2007 16:27
brake oil leak and Fiat parts sreenivass Technical Stuff 8 23rd January 2007 09:08
Oil Leak on my bike abdriver2000 Motorbikes 9 7th December 2006 18:59
ohc power steering oil leakage vinodbijlani Technical Stuff 10 10th August 2006 17:22
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
