Old 3rd July 2014, 13:04   #16
arnabchak's Avatar
Thanked: 1,101 Times
Default Re: Spark Plugs for CNG cars
Originally Posted by suresh_gs View Post
For petrol engines, i guess the spark plug gap is around 1-1.1 mm. Too large a gap can lead to engine misfiring .For CNG/LPG the gap is to be reduced by 0.2 mm.
@ Suresh
Since the OP was was CNG, have quoted the gap for CNG.
Again, gap is different for different brands. In Ikon, the gap was 1.2 mm while the Petrol Zen at home has a gap of 1.0mm.
arnabchak is offline   Reply With Quote
Old 3rd July 2014, 13:46   #17
Thanked: 1,171 Times
Originally Posted by liv_2_drive View Post
I am not sure about the coil. Is it an expensive affair to get the same replaced?
The WagonR F10 had 2 ignition coils, one each for a pair of cylinders. These were mounted on top of the tappet cover, and had to be removed to access the spark plugs.
I remember paying about 1600bucks for one coil (it said TVS-Lucas, cant say if it was genuine) in the local market, about a couple of years back. I bought them from a trusted spare part shop, and didn't bother to check up MGP prices. It worked very well for me.
I was also facing this problem of spark plugs needing replacement very frequently and the engine stalling with a loud 'phatt' sound on gas at low rpm.
Shreyans_Jain is offline   (1) Thanks Reply With Quote
Old 3rd July 2014, 13:52   #18
Originally Posted by arnabchak View Post
@ Suresh
A large gap can lead to misfires. What happens if the gap is less than recommended value?
This is the exact problem that I am facing. Bang On!!
Looks like time to get the coil checked. Thanks
Mod Note: Please use the EDIT or MULTI-QUOTE buttons instead of typing one post after another on the SAME THREAD!
To know how to multi-quote, click here (How to MULTI-QUOTE (when replying to a thread) on Team-BHP).
We advise you to read the Forum Rules before proceeding any further.
liv_2_drive is offline   Reply With Quote
New WagonR Duo OR Chevy Spark LS LPG OR Hyundai i10 LPG? Oxy Hatchbacks 39 24th August 2014 08:02
Santro GL LPG or Spark LS LPG arunjeetsingh Hatchbacks 13 28th April 2010 14:37
Pulstar plugs! Are the spark plugs obsolete? Is it a scam? Sankar Technical Stuff 8 4th October 2009 01:58
Lasers Might Replace Spark Plugs In Cars! Abes Technical Stuff 5 17th July 2009 00:29
