Thread Tools
Old 23rd May 2006, 09:18   #1 (permalink)
Default matiz average problem
hi my matiz gives just an average of 8-10kmpl. I have tried replacing the injectors, cleaning the exhausts, getting the car thoroughly tuned, sparks plugs changed and whatever else goes into tuning. the average is getting worse day by day. you can actually notice the needle going down after drving fr 15-20 kms. please suggest something, I do not want to sell this car.
I have got this car serviced by three diff guys - authorized dealers in chandigarh and amritsar and other repair guys from outside. they offered me the injectors as the last resort, but the problem is still there after spending 6000 bucks on injectors.
Please suggest something !
zzzehar is offline   Reply With Quote
Old 23rd May 2006, 10:01   #2 (permalink)
drifter's Avatar
Check for fuel leaks. Do you smell petrol inside the cabin?
Clean or replace the airfilter if its dirty.
Drifter
__________________
Slow Everything Down And Feel Like God - Tata Safari
drifter is offline   Reply With Quote
Old 23rd May 2006, 10:37   #3 (permalink)
cheap_deal's Avatar
yo zzehar, i get about 9-10max with ac 100% on and driving with a medium heavy foot in chennai city traffic. i too tried fuel injector cleanin, oil change, spark plug cleanin, tyre pressure, checked for fuel leaks, got tuning done. airfilter is clean, checked breaks to see if they were jammed etc etc. none of the above helped raise the FE by even 1kmpl, so i guess we're in the same boat.
do lemme kno if u do manage to improve the FE
p.s wat year is ur matiz?? i got a 2001 model.
cheap_deal is offline   Reply With Quote
Old 24th May 2006, 01:55   #4 (permalink)
Note from the Team-BHP Support Staff : Personal attacks on fellow BHPians are STRICTLY prohibited on Team-BHP. All members are part of the Team-BHP family and any discriminating or derogatory comment is dealt with severely.
We advice you to read the Announcements and Board Rules section before proceeding any further.
Old 24th May 2006, 02:07   #5 (permalink)
thanks for ur concern...my matiz iz also 2001 model. I think ur still lucky to get 9-10 kmpl WITH A/C - mine gives 8-10 kmpl without A/C. I have tried everything possible now the only option left is to start driving my bike and let the car be a showpiece.
Like I mentioned, the car's been serviced properly, all the filters changes, timing belt set, rpm sensor checked, pick up decreased a bit (didn't help increase FE), oils changes, plugs changes, exhausts cleaned, injectors replaced, tyre pressure checked....I cannot think of anything else ? please suggest something that could be done to increase FE a bit.
Old 24th May 2006, 02:08   #6 (permalink)
Team-BHP Moderator
adya33's Avatar
First of all what methode are you using to measure fuel efficiency ?
Because relying on Matiz fuel gauge is a big No-No.
You can try fitting in K&N air filters which will give you some improvement in fuel efficiency.
My 2001 stock Matiz gives around 13.25KMPL in Pune city driving with 70% AC usage.
adya33 is offline   Reply With Quote
Old 24th May 2006, 02:31   #7 (permalink)
I get the tank full and then measure it till it shows me the reserve light again. I also tried filling just 4 lts of fuel and then checked It, same results. which one would you suggest?
how much does K&N filter costs and what does it do?
Old 24th May 2006, 03:02   #8 (permalink)
Team-BHP Moderator
adya33's Avatar
Sorry for misinformaing in my previous post.
AC usage was around 40% and not 70% as reported earlier.
For checking your fuel efficiency,
Fill up your car upto auto cut off. Don't fill up more even if there is space for more.
Note kilometer reading. You can reset trip meter too.
Use your car for some time with normal driving style (i use it for a week) then go to the same filling station and on same machine fill it up again upto auto cut off.
Note final reading and amount of fuel filled in.
From that you can calculate your FE.
This is the procedure I followed and from it got FE of 13.25KMPL (What is your Actual Fuel Efficiency?)
This thread (K&N Filters) should answer your question as what K&N does.
You make use of Search function on this forum to find various topics related to air filters.
Old 24th May 2006, 04:14   #9 (permalink)
thanks adya...but when I refuel the car after one week, do you want me to note the fuel needle? and how much km it ran ? or do you want me to empty the tank and then note the reading on the odo?
Old 24th May 2006, 04:21   #10 (permalink)
Team-BHP Moderator
adya33's Avatar
don't give much attention to fuel gauge.
My car ran about 150 odd KM in a week when I checked its FE.
You can fill in any time you want no need to wait until tank gets empty
Thread Tools
Matiz - SG 99 - Overheating problem deeps79 Technical Stuff 1 16th August 2007 18:45
Matiz Mileage Problem Kchittilla Technical Stuff 10 7th August 2007 10:16
Problem with Matiz silencer/muffler yeggina Technical Stuff 5 29th July 2007 07:08
Matiz engine oil problem ece2k2 Technical Stuff 0 17th July 2006 17:58
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
