Old 21st June 2006, 21:30   #16
I found the following links for motoreco products....its a part product of A9 technology......this techlology when used inside engine makes a parmanent layer of lubricating film once engine becomes hot & remain thereafter....there are many products under this technology.....
http://www.technologie-a9.com/ANGLAIS/dindex.htm
Enjoy.............
finetuning is offline   Reply With Quote
Old 21st June 2006, 21:41   #17
Originally Posted by revvhed
hi guys
i've also just added motoreco to my esteem .. also suggested by my mechanic .. and stocked by him .. hmmm kaizer who's ur mechanic .. is he the same as mine .. i wonder .. well even i found an immediate diffrence in the engine note . smoother and more muted .. don't know about the enhanced mileage claims though .. will figure that out and post later
cheers
Hi revvhed,
Do keep us updataed about ur experience using motoreco product.....did u notice drop in engine temp.?
Enjoy......
Old 22nd June 2006, 23:44   #18
killjoy's Avatar
Thanked: 191 Times
ya, that sounds about right, i was worried that you were getting fleeced.
killjoy is offline   Reply With Quote
Old 28th June 2006, 14:30   #19
Thanked: 21 Times
hi finetuning
i can't say that i've noticed any drop in engine temperature .. why ? .. have you ?
revvhed is offline   Reply With Quote
Old 23rd July 2006, 23:40   #20
yogi1771's Avatar
Originally Posted by Kaizer Sozay
I finally did an oil change on saturday, In the past i have only used synthetic oils or castrol magnatec.
My mechanic asked me to try this stuff called motoreco, which is a 250 ml bottle that he put in the engine along with the new oil ( this time i just put a normal grade engine oil). Today while driving i noticed a marked difference in the engine performance.
Drive was a lot quiter, & engine smoother.
Will keep you all posted as i have only driven 50 kms today going for a long drive tommorrow
hi whats the present report after adding motoreco and can u tell where to get it or atleast pm me thanks in for a oil change
yogi1771 is offline   Reply With Quote
Old 24th July 2006, 21:45   #21
Kaizer Sozay's Avatar
Report is that the engine runs a lot more smoother. My personal opinion is that it is equivalent to synthetic oils like Shell utlra helix only much cheaper.
The address is Kuber plaza, Link Road, Andheri (W) opp fame add labs mumbai.
Sorry guys no phone number available.
Kaizer Sozay is offline   Reply With Quote
Old 18th August 2006, 11:42   #22
n_aditya's Avatar
Thanked: 2,780 Times
Hi Kaizer,
I would like to buy the Motoreco next time i need to change the engine oil....
Could you post a picture of the motoreco container and/or logo so that some of us dont end up with fakes...?
Thanks pal.
Old 18th August 2006, 21:31   #23
Default Pic of Motoreco
Done chief,
I will be visiting my mechanic on the 23rd will click a photo & post the same. Will also post an enlarged image of the address.
Old 24th August 2006, 22:57   #24
Originally Posted by n_aditya
Hi Kaizer,
Thanks pal.
Ok here goes Two photographs with all the details
[img=http://img88.imageshack.us/img88/1908/dscn3797wp6.jpg]
Old 24th June 2009, 17:03   #25
ibm_jennifer's Avatar
Thanked: 7 Times
Default Motoreco - Any feedback on this Additive?
Guys,
Got an email from the distributor of a product called Motoreco.
It doesn't seems to be another ADDITIVE to my eyes:
Technologie A9
'MOTORECO VL' PRICE IS RS 2410 + VAT 4%.
MOTORECO: VL: VU: PL60S: PL
MULTI-PURPOSE, MULTI-PERFORMANCE, ANTI WEAR & ANTI-POLLUTION ENGINE TREATMENT FOR ALL TYPES OF 4 STROKE ENGINES
■ PETROL, DIESEL, GAS, CATALYSED OR NOT, TURBO, COMMON RAIL,
MULTI- VALVES, ETC.
■ IDEAL FOR BIG ENGINES, BOATS, LIGHT AVIATION, AGRICULTURAL
MACHINERY, INDUSTRY, PUBLIC WORKS, COMPETITION VEHICLES.
CHARACTERISTICS AND PERFORMANCE
■ ANTI-WEAR: Considerable reduction of friction coefficient on moving metal
Parts by avoiding hard metal to metal contact, responsible for
Over 70% of engine wears (Car Manufacturer’s Statement)
THEREBY INCREASING MECHANICAL LIFE SPAN
■ CONSUMPTION: Proven reduction of fuel consumption by 5 to 10%, thanks to
Fuel savings. You can obtain 120 miles /200 km extra
Distance per full tank or 2additional hours for fixed engines
And oil topping up by 70 to 100%
■ TEMPERATURE: Reduction of oil bath temperature by 20%
■ OILLEAKS: Protection of joints and gaskets through improved tightness
■ COMPRESSION RATIO: Equalizes and increases compression ratios once
remnant film is in place. Considerable increase in
power output because of reduced friction,
■ NOISE LEVEL: Engine noise levels and vibrations considerably reduced
■ LUBRICANT BEHAVIOUR: Thanks to the remnant film, the lubricant maintains its
design properties between oil changes
■ SAVINGS: Self-financing, savings exceed the cost of the next oil purchase
■ STORAGE: Once the remnant film is formed, engines can be stored
indefinitely, without corrosion, gumming up or binding
MOTORECO: Is NOT an additive and does not contain any solvents. It is neither
a thickening nor re-metallizing agent. Not soluble but MISCIBLE
Does not alter the design characteristics of the lubricant. Highly
resistant remnant film, which is fully formed after a few hours on all
metal surfaces at 43°C/110°F, thanks to A9 TECHNOLOGY
The 36 Exclusive Advantages
STARTING
: less running time required
SAVINGS: oil changes are self-financing
SPARKING: substantial increase in spark plugs life
RACING: residual oil film is boosting performance
VIBRATIONS: decreased, resulting in quieter engine
LEAKAGE: better gaskets protection & reduced leakage
STARTER: thanks to easier cold starts, starter wear is halved
OIL MAKEUP: reduced by 70% to 100% for 4 stroke engines
COLD START: much easier with cold engine thanks to the A9Remnant Film
BATTERY: the overall electric load reduction is extending the battery lifetime
CYLINDER PRESSURE: optimization & automatic balancing among cylinders
TEMPERATURE: at steady state, the oil temperature is reduced roughly by 20%
ANTI-CORROSION: the residual oil film (A9 Remnant Film) is fighting rust & corrosion
PICK UP: the engine has stronger pick up, especially at low RPM due to boosted torque
FILTER PARTICLES: increases its efficiency in the long run thanks to a better combustion
MILEAGE: reduced fuel consumption is increasing mileage up to 200 kilometers by tank-full
ANTI SEIZING: seizing is prevented on 2 stroke engines in case of icing of the filters & interruption of fuel flow
TURBO-COMPRESSOR: expected lifetime of the system is maximized due to 20% temperature drop at steady state
LUBRICANT BEHAVIOR: every multi-grade oil acts as 0 W 60 in 4 stroke engines due to the residual oil film (A9 Remnant Film)
CONSUMPTION: consumption is reduced, 5% to 10% in city driving, may reach 30% if all the kinematics chain is treated with A9 Remnant Film
ANTI-POLLUTION: gasoline engines: up to 75% reduction of toxic gas (CO) at idling & 20% to 30% in city driving - Diesel engines: 40% smoke reduction during acceleration
CATALYST: the protection of the “lambda probe” extends the lifetime of the catalytic converter & [COLOR=black]assists it in fighting pollution during cold phase in city driving. In addition, it prevents fuel waist & power degradation[/COLOR]
PROTECTION: 4 stroke engines: A9 Remnant Film prevents gunk, tar & carbon deposits - 2 Stroke Engines: prevents gum, varnish, fuel & deposits on pistons & carbon deposits in the firing chambers & intake/exhaust ports
So my question is, Anybody tried this before? Seems to be overpriced for Indian market, Any feedback?
ibm_jennifer is offline   Reply With Quote
Old 24th June 2009, 17:20   #26
Thanked: 49 Times
There's a 3 year old thread about this additive - team-bhp is an encyclopedia of sorts!
http://www.team-bhp.com/forum/techni...-motoreco.html (Product Review on Motoreco?)
Seems that it was "450 bucks for a 250 ml bottle" back in 2006.
CrackedHead is offline   Reply With Quote
Old 24th June 2009, 17:43   #27
Thanked: 7 Times
450 bucks? Seems to be a duplicate product for me, the picture is also different.
I am sure 60ml cost around 2500 as I am dealing with the distributor in India.
Our official importer for India, Mr Mukund Deodhar whose whereabouts are : Mukund Deodhar – OM-SOHAM – C9 Spring Flowers – Vrindavan Society – Panchvati off Pashan Road – 411008 Pune – Maharashtra Sate - India.
Hervé de Bona - Service Consommateurs - International User Service - B.U.T SA - OFFICIAL WEBSITE A9 Technology / Technologie A9 - Martigny - Switzerland - a9two@technologie-a9.com - skype : butsamartigny
3M Nomad Foot Mats : Product Review KarthikK Modifications & Accessories 80 22nd November 2017 14:48
Toyota Qualis - Product Review / Discussion v12 The Indian Car Scene 65 14th November 2016 19:47
Product Review: Pete's Digital Diesel Tuning Box Rtech Modifications & Accessories 239 4th March 2016 13:38
Product Review: Philips Crystal Vision Halogen headlamps Rtech Modifications & Accessories 308 13th March 2007 13:38
