Old 26th January 2016, 20:55   #31
Thanked: 33 Times
Default Re: Honda Accord: AT gearbox problem
Thank you mods, for merging my thread with another T-Bhpian(virtualdanger).I should have been scrupulous enough to have searched for an existing thread instead of creating a new one. My Bad.
Nevertheless, the problem he faced is more or less similar to the one I faced, with my Honda Accord AT. The information shared across , in that thread is applicable to my issue as well,for example:
VeyronSuperSprt:
Here's what you need to do:
1. First check whether the D sign blinks on the dashboard when the problem happens.
Exactly the same thing I observed on HUD during the course of the issue.
d_himan:
my 2 cents: I drive an Accord with a refurbished AT.
1. I'm guessing this deterioration would have happened over time, usually it is never sudden. You would have noticed jerks during shifting, felt downshifts/upshifts especially while coming to a halt/N to D etc.
True, I had been observing the same for past 2 months , additionally a few days before the problem occurred , whenever I would pull the gear selector from "N" Neutral to "D" with the car standing still, the usual forward movement would simply not happen! I had to specifically push throttle , then it would start moving.
The ASC quoted a figure of INR 400,000 for the replacement job of the Automatic Transmission and 1 month time. Notwithstanding , the fact that there were other issues like Suspension and Steering OH, and other parts like a recurring steering pump issue, and replacement of radiator fan, starter motor etc , which required immediate attention ASAP,that the bill shot up to somewhere around INR 650,000.No wonder , My father and brother decided to let go of the car itself.
ritedhawan is offline   Reply With Quote
Old 27th January 2016, 02:35   #32
Thanked: 463 Times
Default Re: 2007 Honda Accord transmission issue(AT)
Originally Posted by ritedhawan View Post
Thanks for your response, Rahul Bhalgat, tj123
Rahul, you have answered the second question adequately, However, didn't answer the first.
" Did I brought irreparable damage to the AT such that the problem got out of hand and reached a point of no return?"
Or ,
" Whether, I followed the above 2 options or brought the car back to New Delhi, irreparable damage was anyway done at that point in Panipat. Therefore, whether I followed any of the above options, The damage was done, and the AT had reached a point of no return. ?"
Hi ritedhawan,
Sorry, your first question was skipped because I was thinking about the second question and drafting the answer.
Going by the logic that I have put, the cause of the AT malfunction is repairable. It did not reach a point of no return.
The AT gear train with its clutches and brakes forms the core of the AT box and this is pretty complicated to dismantle, troubleshoot and assemble back. As per my logic, the problematic elements were the pressure relief valve or the AT pump or the solenoid. These things are outside the complicated AT gear train with clutches / brakes.
Rahul Bhalgat is offline   Reply With Quote
Old 29th January 2016, 19:08   #33
SOS!! Desperately looking for a automatic transmission gearbox (yes, the whole thing) for a honda accord 2010 2.4. Someone please help. It is criminally expensive in the company. I dont mind a used one. But gotta get the wifes car sorted or she'll throw me out.
PLEASE PLEASE help with any leads.
Saakaar
Gandalf18 is offline   Reply With Quote
Old 6th February 2016, 16:59   #34
And the problem we also faced was exactly the same as faced by virtualdanger. The scan report of the car showed "Shift Solenoid valve A STUCK ON"
"A/T Clutch Pressure Control Solenoid Valve A Stuck ON"
We got a used gearbox from mayapuri. The issue remains. Now the mechanic is suggesting we convert it to a manual
Giving it to Honda wont work cuz its just way out of budget. I really dont know what to do. PLease advise. thanks
Saakaar
Honda City AT - Transmission problem amar_1422 Technical Stuff 10 15th August 2015 02:17
Honda Accord VTi vs Honda Accord V6 Dinesh99 Technical Stuff 48 9th March 2010 02:08
Honda Accord washer leak in gearbox issue hunt Technical Stuff 4 5th February 2009 22:22
Honda Accord Coupe Concept (Possible new Accord) amit The International Automotive Scene 3 10th January 2007 10:04
