Old 29th May 2013, 11:46   #1
Thanked: 42 Times
Default Problem with Door Ajar Sensors
All,
In my innova, the 'door ajar' indicator on the dashboard keeps glowing, and cabin lamps remain on even when all the doors are closed. I checked the sensors on four doors, and they seem good to me. So the suspect is the rear hatch, but I could not locate any sensors on the door or on the frame. Does anyone know where the sensor is?
The indication goes off when I lock the car, or when the car is running, but I have to keep the cabin lamps in 'OFF' position at all times.
Before taking the car to the service station only for this problem, I want to see if there is an easy fix...
Mods: I tried searching for 'door ajar', but could not find a relevant thread. If a thread exists, please merge...
sschivate is offline   Reply With Quote
Old 29th May 2013, 13:30   #2
msaudf's Avatar
Thanked: 152 Times
Default re: Problem with Door Ajar Sensors
It could be a simple issue with the switches on the pillars (usually located at the bottom of the pillar or under the striker covered by a small rubber boot) . Try to isolate which door is causing the issue by pressing on each door which will deactivate the door ajar switch and the light will go off. It could be a case of one of the doors not closing fully. if all that doesn't work then the door ajar switches maybe malfunctioning.
cheers
Saud
msaudf is offline   (4) Thanks Reply With Quote
Old 29th May 2013, 13:33   #3
vikram_d's Avatar
Thanked: 940 Times
Some cars have switches for the bonnet also. Check that too.
vikram_d is offline   (4) Thanks Reply With Quote
Old 29th May 2013, 16:57   #4
Thanked: 42 Times
Default Re: Problem with Door Ajar Sensors
cheers
Saud
Saud, Thanks! I have already checked the door switches on the pillar. The indicator continues to glow even when I manually pressed the switches one-by-one. Hence I am suspecting the hatch door.. (and now bonnet, after reading Vikram's response!!)
Thanks, will check.
Onboard Tyre pressure sensors suren181 Tyre & Alloy wheel Section 121 20th March 2018 12:16
New MINI 3-Door & 5-Door launched in India @ Rs 31.85 - 35.20 lakh Tushar The Indian Car Scene 33 13th April 2015 18:00
5745.4kms, Door to Door, 4 States and 1 UT Judemayne Travelogues 30 23rd April 2011 21:56
Dumb question about sensors....but i gotta know rohan_fonseca Technical Stuff 6 19th April 2007 03:38
Read about how Oxygen Sensors work Rehaan Technical Stuff 2 13th March 2006 02:51
