Old 29th May 2006, 21:41   #16
revharder's Avatar
Thanked: 49 Times
anything less than p2w of 100bhp/ton is not so exciting!
OHC VTEC with 106 horses and weight of about 985 was giving 106/985*1000 = 107.6bhp/ton and this something really good.
it is not that cars with 95 or 99 bhp/ton are less exciting, but just to draw a line, imho, 100 is a minimum requirement for having a car which is real fun to drive!
revharder is offline   Reply With Quote
Old 29th May 2006, 21:53   #17
kpzen's Avatar
Thanked: 1,655 Times
Originally Posted by venkatrx
naveen, can u please explain the 'bhp' and 'torque' in layman
In simple words
BHP - Stamina
Torque - Strength
if i m not mistaken my 2002 baleno's specs read 860 kgs. will confirm again and get back on this forum. nyways, the true power of the car is not only BHP/TON but also the touque it produces. if u follow the link posted by GTO (http://www.indiacar.com/index2.asp?p...00_0/index.htm) u will see that there are cars which have lesser power to weight ratio but have better timings.
Hey Naveen..!!!
In the 0-100-0 test The Baleno has done 100-0kmph in under 4sec....Its hard to believe that it was done with stock 165 tyres If its true..!!! SUZUKI rullzzz....
KP
Old 29th May 2006, 22:48   #18
Venkat, there are many threads in "technical stuff" on this forum which discus torque,power & rpm etc. Torque and power are two sides of coin, which boil down to torque curve of the engine. Hope some of my old posts in this thread make it easy to understand:
http://www.team-bhp.com/forum/127414-post48.html
Regarding weights, you should use kerb weight (which is inclusive of full tank of fuel, if I remember correctly) + additional load . You had probably used gross weight specification initially which is actually max. allowed weight by the manufacturer.
santosh.s is offline   Reply With Quote
Old 29th May 2006, 22:55   #19
Ford Rocam's Avatar
Thanked: 16 Times
In simple words
BHP - Stamina
Torque - Strength
One of the Simplest & Best explanation i had ever seen, good one Kpzen
Ford Rocam is offline   Reply With Quote
Old 29th May 2006, 23:38   #20
Shan2nu's Avatar
Thanked: 89 Times
The Baleno was fitted with 185/60 R13 tyres.
http://www.indiacar.com/index2.asp?p...00_0/rank5.htm
Shan2nu
Matching HU amp power with Speaker power? hitra In-Car Entertainment 21 25th March 2015 16:18
Maruti Esteem - Non Power Steering to Power Steering udit78 Modifications & Accessories 14 4th May 2011 13:29
DIY: Testing/Measuring the true power output of your Amplifier. cvc2145 In-Car Entertainment 6 21st December 2009 05:37
subwoofer power and battery power requirement smats In-Car Entertainment 22 18th October 2006 11:51
Please suggest - power windows, power steering from one Esteem to another pramodkumar Technical Stuff 4 1st September 2006 09:19
