Old 10th June 2006, 02:02   #16
nevertouchme's Avatar
Thanked: 57 Times
Unhappy Well, there is a way to put it across...
Originally Posted by axcman
Hi Guys
Note from mod:
" Please use proper english ". There is something called punctuation.
Mistake is a mistake, irrespective who does it...
I really do not appreciate this.
'aint that rude???
nevertouchme is offline   Reply With Quote
Old 19th August 2011, 00:24   #17
knob's Avatar
Red face Heart transplant (Engine Change) for an old lady (Maruti 1000)
Hi everyone, I am now a proud owner of a Maruti 1000. It has run 46000 kms in 17 years, really in stock form without any kinds of mods or aftermarket fittings. It is not so noisy as the newer esteems are and I need to take care of some serviceing and replaceing of rubber parts and deal with a few rust spots here and there.
While using in the city or highway the 40 bhp engine starts to show its inadequacies, extremely slow acceleration, a/c is weak etc etc... I have been reading up on all the engine plonk stories and the idea came to mind- I should put in a bigger engine in there or make it a bigger heart. I have the following things in mind:
a- Enlarge the existing engine and plonk bigger pistons in there.
b- Put in a esteem 1.3 engine in there.
c- Put in a zen 1.0 engine
d- Put a baleno 1.5 engine.
I heard that carberated engines are better to plonk in my car because my car is already a carberated one.
This is where I need your help expert members, which is the best option from above and how to do it without damaging the existing structure of the car.
Also I need the Kollam or Trivandrum members to help me find used engines in good condition or
tell me some good garages where I can do the enlargement and overhole of the engine and
a good body shop to dent paint and repair the body very well.
Budget is not an issue, but I want to do a quality job for my baby.
Thankyou eveyone.
Mods please move to apropriate thread if this is the wrong place.
knob is offline   Reply With Quote
Old 19th August 2011, 00:57   #18
dhanushs's Avatar
Thanked: 4,505 Times
Default Re: Heart transplant for an old lady
If you are ready to go for a baleno engine, why dont you look for an all better Fiat Palio 1.6 GTX. You will get plenty good of examples for under 1 lac.
The money involved, the paper work headache, and the reliability after the swap is not worth half a GTX.
Old 19th August 2011, 01:51   #19
Technocrat's Avatar
Thanked: 2,589 Times
Default Re: Heart transplant (Engine Change) for an old lady (Maruti 1000)
Some quick inputs on your Options
a) Can be done at the hands of a good tuner to a tune similar to that of an esteem & probably the most hasselfree option(no sourcing of engine, RTO issues etc etc)
b) Tt will merely make it an esteem, not worth it considering the hassles with RTO etc.
c) Why? It has practically the same engine
d) Makes sense will give you real good power to weight ratio but do remember you will have to spend on better brakes & tires & might be suspension too
Technocrat is offline   (1) Thanks Reply With Quote
Old 19th August 2011, 02:47   #20
SCORPION's Avatar
Thanked: 399 Times
Infractions: 0/1 (9)
Default Re: Engine Transplant For 1000
If you really want to replace your engine, then I think the esteems would be the best fit. The Baleno engine, I am not sure if it can be shoe horned into the engine bay. Besides modifications to your suspension set up, you may also have to change the gear box. The whole job has to be done by a highly skilled mechanic or else you will end up with a white elephant. The cons of an engine replacement far outweigh the cons.
The safest option is to retune your present engine. Carbureted engines are far easier and cheaper to tune than their modern counterparts. You can also try changing jet size and putting in bigger ones. Or the whole carburetor itself can be replaced, put in performance air filter, cams, free-flow exhausts etc. The old gyspy MG 410 came with the same 970 cc engine, and was modified extensively for rally use. So if you can find some one who can do that, I think it would be the best option.
SCORPION is offline   (1) Thanks Reply With Quote
Old 20th August 2011, 13:27   #21
knob's Avatar
Thankyou for the suggestions.
If you are ready to go for a baleno engine, why dont you look for an all better Fiat Palio 1.6 GTX. You will get plenty good of examples for under 1 lac. The money involved, the paper work headache, and the reliability after the swap is not worth half a GTX.
I already have bought this car and would like to keep it till it crumbles, and the hassles of getting parts and good service for palio is too much. This will be used as a weekend drive and so paper work and all wont be an issue.
a) Tuner is a problem, I also think this is best option, but I dont know any tuner kind of people. Also this is an F10 engine. So which pistons from the G series engines will suit best for this and to what size should i enlarge the cylinders?
b) Yes esteem like but esteems have loads of power.
c) I read the carbs have 50 hp and mpi's have 64, so I considered them as I only have 40 hp.
d) For this again I need to know some good guy who can do the modifications at my place.
Gyspy esteem etc had new g seris engines and i have old f series. Also I am wanting mpi engine as they can make much Hp, but I dont know what kind of parts are needed for converting it to mpi. If i cannot do it I will stick to carb esteem engine only if enlargement is not possible on my f10.
Requoting my old request:
Kollam or Trivandrum members- help me find used engines in good condition or tell me some good garages where I can do the enlargement and overhole of the engine and a good body shop to dent paint and repair the body very well. I need to buy some used alloys- please direct me to this dealers also. Is there any clearlens lites available for my car?
Thankyou.
performance mods for a lancer... MIVEC engine transplant drunk.monkey Modifications & Accessories 21 17th June 2008 13:28
Engine Transplant in Baleno Lxi 2006 premdiv Technical Stuff 35 21st December 2007 18:12
HELP Transplant Petrol Engine In TATA SIERRA malvechaitanya Modifications & Accessories 3 16th February 2007 22:20
Engine Transplant in the Sierra sunith Modifications & Accessories 18 24th June 2006 08:08
Alto - Engine Transplant!!! urdudesamy Technical Stuff 6 2nd June 2006 23:36
