Old 16th July 2013, 19:29   #106
noopster's Avatar
Thanked: 9,194 Times
While the original question is straightforward, the ensuing discussion raises the very important question: why go even near the limit of toppling your vehicle?
After driving in India, one loses sight of a simple number that can save your life: the speed limit. The fact is that speed limits in India are so low as to be unrealistic so we tend to ignore them. But when I was driving in the US recently, I realised how scientifically those limits are calculated, on every stretch of at least the major roads. You may be "safe" till at most ten over, but by and large it's a good bet that you go any faster and you will end up endangering yourself and others.
Of course your vehicle may not even be able to stay safe at the speed limit. In which case I don't think any number of equations and formulas will be able to save you!
noopster is offline   (4) Thanks Reply With Quote
Old 16th July 2013, 20:11   #107
Thanked: 528 Times
Default re: Evasive manoeuvres & Rollovers?
Originally Posted by DerAlte View Post
Aren't you contradicting yourself here?
Both the suspensions allow the CG to shift, the softer one earlier and the stiffer one later (with respect to the point of time that the bump or swerve triggered mass shift). The 'softer' and 'stiffer' refers to the damping.
If what you say were to be true ("the stiffer suspension makes it behave like a single unit(relatively)"), wouldn't rally cars - with stiff suspensions and virtually 0 body roll under normal circumstances - be spending more time on their sides or roofs instead of wheels? Stiffer suspension allows the wheels to be on the road longer, even if the body rolls. At the tipping point, the suspension would be at the end of travel (compression in the side to which mass shifted, extension in the side that the mass shifted from). At this point the chassis, suspension and body are a single rolling mass.
I was taking the extreme (stiff) example to prove the point that flexing of the suspension is what allows the mass to shift without the wheel loosing ground. In realty the rightly sprung hold better while the softer suspnesions (which make people scary) are not as dangerous as they feel (as long as the rolling is progressive)
Guna is offline   Reply With Quote
Old 16th July 2013, 21:29   #108
Thanked: 2,071 Times
Originally Posted by Guna View Post
But in reality, when the tipping point is reached, it is the car with the stiffer suspension which is likely to topple (2 wheels up in the air). Car with the softer suspension, even though it leans dangerously, will still have all 4 wheels grounded for 'longer period' (till the tipping point is reached).
For same suspension travel?
What were the changes made to the A Class?
Sutripta
Old 16th July 2013, 21:34   #109
Thanked: 528 Times
A class was a tall boy and the stance itself was changed to make it low slung
Old 16th July 2013, 21:37   #110
By change of tyres.
ESP added.
Anything else?
Sutripta
Old 16th July 2013, 21:42   #111
Thanked: 528 Times
By change of tyres.
ESP added.
Anything else?
Sutripta
No idea. I know the previous generation was a tall boy car and the current gen is a low slung hatch
Old 16th July 2013, 21:46   #112
Was talking of MBs response to the original infamous A Class.
Amongst other things, the suspension was made harder.
Sutripta
Old 16th July 2013, 21:50   #113
Thanked: 528 Times
Sutripta
Did they stiffen the suspension on the tall boy version itself or in the subsequent design?
Old 16th July 2013, 21:55   #114
Original version. The one which had flipped over during the Swedish Elk test.
Sutripta
Sutripta is offline   (1) Thanks Reply With Quote
Old 16th July 2013, 22:13   #115
Thanked: 973 Times
The key difference is when the tipping point is reached. It will be at a higher speed with a stiffer suspension as compared to a softer one.
For any vehicle with a certain C of G, there will be a max lateral "g" force (directly proportional to the speed and inversely to the radius of the curve) that can be applied. A stiffer suspension allows the C of G to remain in the "safe zone" for higher values of "g". A softer suspension needs only a lesser force to be applied before the C of G topples over to the "unsafe zone".
This why "sportier" variants of the same vehicle does better in skidpad testing. For e.g., a GT versus a base Mustang.
Aint nuthin but a "g" thang, baby. (Purely coincidental )
gthang is offline   (4) Thanks Reply With Quote
Old 17th July 2013, 11:29   #116
saket77's Avatar
Thanked: 4,211 Times
And here a Land Rover spins out of control in Bangalore. The guy has killed 4 people too. Bad news, but as long as people don't come out of the mirage that SUVs mean a lot of speed and can handle well, I am sure, we will unfortunately have many more such links in future too.
http://timesofindia.indiatimes.com/c...w/21113208.cms
Edit: Does not mean that I am supporting rash driving by a sedan or a hatchback. Its a menace & must be curbed.
saket77 is offline   Reply With Quote
Old 17th July 2013, 11:41   #117
mallumowgli's Avatar
Thanked: 704 Times
Originally Posted by gthang View Post
American car magazines like Motor Trend, Road & Track, etc., used to test a car's "Lateral Acceleration", and the figures were calculated in "g" values. Generally a car with a higher "g" value could corner better, and hence offered better stability through turns. A high C of G vehicle like an SUV usually returned low "g" values.
Indian magazines don't do such useful testing unfortunately. But if you understand the principle, and get an open road which can be used as a skidpad, one can test for oneself their car's limit's.
Try this for starters:
http://www.mrwaynesclass.com/circula...orner/home.htm
Cheers.
I can understand why this is not a destructive test, though in the hands of a novice tester it can become a self-destructive test
But the Mr. Wayne's class link you have provided gives the logic in a twisted or rather inverted fashion. If the formula v(square)/R for calculates the curve's centripetal acceleration, then the car's v(square)/R should be within the above calculated value and not above for safely negotiating the curve. Else as the speed goes up, it becomes more safe to take the curve!!
Actually the logic of the class is towards calculating the safe radius of a curve at a given centripetal acceleration (friction) and velocity of the car
mallumowgli is offline   Reply With Quote
Old 17th July 2013, 13:55   #118
Thanked: 9 Times
I also want to bring up another point related to high CG and rolling.
If you take 2 cars with identical ride height/CG, but with differently tuned suspension set ups, the car with softer suspension is (obviously)likely to roll more than the one with a stiffer suspension, and this is likely create some scare (with regards to the stability). But in reality, when the tipping point is reached, it is the car with the stiffer suspension which is likely to topple (2 wheels up in the air). Car with the softer suspension, even though it leans dangerously, will still have all 4 wheels grounded for 'longer period' (till the tipping point is reached). Softer suspension allows part of the mass to shift while the stiffer suspension makes it behave like a single unit(relatively).
Perfectly true. This is one pretty important point which was missing from the discussion till now I believe.
Both will shift CG at the same time. The difference is not of 'earlier' or 'later'. It is of 'more' or 'lesser'. Obviously, the car with softer suspension will have more shifting of CG. But it is not just about CG positioning. A softer suspension will tend to absorb a larger component of the lateral forces acting on the car as opposed to a stiffer suspension which will just transfer most of the forces onto the wheel components.
It won't be appropriate to bring race prepped vehicles into this. All that matters to racing driver is how quickly their vehicle responds to the steering inputs. Which is why they always prefer stiffer suspension. Besides, their cars are also tuned to generate much more than average amount of downforce.
Nope, for the same speeds.
Sutripta
Both stiff and soft suspension setups have their advantages and disadvantages. It depends on what the manufacturer thinks is important for their vehicle.
Hmm, this is new to me. If you have any reference for this, I'd appreciate the share of info.
Ah but does it?
What is a "safe zone" for CG? Since we are talking about toppling, obviously as low a CG as possible is "safer". So ask yourself this, what will happen to a car with softer suspension and being subjected to lateral forces? The suspension will deform by a larger extent. And by deform, I mean it'll go down on one side. Hence slightly lowering the CG.
Again, I do not think it is proper to compare race cars or "sportier versions". They usually include a lot of changes to cumulatively give better grip and better steering response.
Personally, I also do not agree with this Moose Test. Professional driver will never tell you to swerve your car (be it SUV or otherwise) if a moose wanders in front. You hit the brakes, and hope for the best. Swerving suddenly is a wrong driving practice. Especially if you don't know who or what is coming from the other side. Might end up saving the moose but killing a mother on her way to drop her kid to school. Best that you brake and hit the damn thing.
Just my opinions.
san_jayd is offline   (1) Thanks Reply With Quote
Old 17th July 2013, 14:50   #119
DerAlte's Avatar
Thanked: 2,876 Times
Originally Posted by san_jayd View Post
... Both will shift CG at the same time. The difference is not of 'earlier' or 'later'. ...
I am sure you will look at it differently if you look at the maths of dynamics of suspension. Suspension design is not done by hit and trial, right?
... It won't be appropriate to bring race prepped vehicles into this. ... Besides, their cars are also tuned to generate much more than average amount of downforce. ...
And why not? The physical rules / engineering stay the same, no?
Paris-Dakar Rally contestants use SUVs. And SUVs don't get significant down force at the speeds they travel.
Low slung Formula racing cars with purpose built aerofoils (not the garden variety show-off spoilers one finds on many cars) exert significant downforce when the car is travelling in excess of 200Kmph - yes, we are not talking of those.
... Personally, I also do not agree with this Moose Test. Professional driver will never tell you to swerve your car (be it SUV or otherwise) if a moose wanders in front. You hit the brakes, and hope for the best. Swerving suddenly is a wrong driving practice. ...
Do you know how much a Moose / Elk weighs, and how tall it is? If one is travelling at 100Kmph on the secondary highways in Scandinavia (that is the average speed on those highways) and hits a Moose / Elk straight on at 60Kmph (after braking), the moose - hit near the knees by the bonnet - will crash into the cabin through the windshield. One will certainly be crushed in the driving seat - airbag won't help. Quite different from hitting a dog, small deer or a donkey. Did you think the Scandinavians are dumb to conduct the Moose Test?
DerAlte is offline   (3) Thanks Reply With Quote
Old 17th July 2013, 21:03   #120
Thanked: 704 Times
Dont you think a shift of CG is detrimental to the dynamic stability of the vehicle? For a vehicle to be stable the CG needs to stay lower and also towards the centre of the axis the movement of vehicle. Else the moment of inertia will carry the vehicle off the line the curve. Basic physics
Consider the shifting of CG of a softly sprung vehicle. The CG will shift pull the weight of the vehicle towards the outside of the curve thus making the inside wheels to have a tendency to lift off the road
The only difference (as per the point made by you and Guna) is that a softly sprung vehicle would appear to topple in slow motion, whereas a stiff-suspension set-up turn turtle as a single mass!!
If you think about why vehicle with stiffer suspension responds faster to steering inputs, you would get the answer regarding why talking about racing cars is relevant here.
Really surprised to see this comment. Do you mean to say that softly sprung cars can take more speed into corners than cars with stiff suspension?? Can you elaborate? People from companies like Blistein would be interested in that.
As explained earlier, CG will not lower, but rather move towards the outer of the curve destabilising the vehicle
GM cars, price details, & How do dealers make money? chaxy The Indian Car Scene 16 3rd May 2006 14:08
Want to own a piece of Car&Driver and Road&Track ? Revvmaster Shifting gears 10 11th September 2004 15:25
