Old 28th July 2013, 22:00   #16
magneto's Avatar
Thanked: 46 Times
Default Re: Scorpio ECU Issues
My local mechanic has a contact with a breaker and arranged for a second hand ECU which we tried with total success . The car started perfectly in the first try and we drove around with no noticeable problem .
I have been given a replace warranty by the guy for a month .
So now I am going to have two ECU ,s in my car one which is perfect and the other as a standby in case of a failure .
magneto is offline   Reply With Quote
Old 28th July 2013, 22:04   #17
magneto's Avatar
Thanked: 46 Times
In both my cars, or Maruti cars in general, CEL light remains ON as long as engine is not cranked. It switches off once engine is running. The manual mentions there will be an issue if this light turns on while engine is on. In the ON position, it is done to verify that the lights are functioning.
Guess we must now have qualified engineers in service centers, in order to handle the higher amount of sophistication found in newer cars. Come to think of it, manufacturers employ well educated graduates in R&D and they churn out such products. And when they develop problems, repairs are attempted by mechanics, who have much basic knowledge about the working. Yes some mechanics are masters by experience but that is mostly related to mechanical stuff and not ECUs and the like.
Sir, if the immobiliser was a part of the central locking system, as said by the previous posts, I do not understand why the ECU would have to check immobiliser. The logic you stated is correct for cars which have a factory fitted immobiliser. Both my cars behave this way. If I use a wrong key, the immobiliser light will blink, and the car wont fire up on cranking. This is done by the ECU based on the signal from the key detector.
Suppose an after-market immobiliser was used, which came along with the central locking system, it should use a crude method to immobilise the engine, either by disabling the starter or preventing engine firing, ie to start. So, when wiring the central locking, I think they have made the central locking system control power to ECU. I feel it is done this way. At least going by the fact that another member has come across the same problem.
Originally Posted by SirAlec View Post
you are saying that, its cranking but not starting??
It cranks but will not start until the check light is seen on the console ,after which the car runs flawlessly ,till we need to switch off and on again same problem of switching the key on and off till the check light is seen
Old 28th July 2013, 22:09   #18
magneto's Avatar
Thanked: 46 Times
It cranks ok but will not start till I am able to get the check light after turning the key on and off couple a times
Old 28th July 2013, 22:10   #19
Thanked: 658 Times
It be something to do with your engine immobilizer. !??
please have a check with some key expert in your area.
Old 28th July 2013, 22:17   #20
magneto's Avatar
Thanked: 46 Times
Please refer to my earlier post , it was definitely a bad ECU ,the problem has been sorted .
Old 28th July 2013, 22:40   #21
Thanked: 658 Times
OOps ! i missed that post completely.
BTW! Immobilizer has everything to do with ECU. It will not allow the engine to crank. Try with a cheap duplicate key without RFID in it.
SirAlec is offline   (1) Thanks Reply With Quote
Old 28th July 2013, 23:17   #22
magneto's Avatar
Thanked: 46 Times
I am trying to figure out the manufacturing date , need to know the format such as dd/ mm/ yy , as I suspect that my ECU has been swapped by the service guy as my car is older than the ECU .and has never been replaced .
Old 29th July 2013, 09:17   #23
Thanked: 658 Times
6/8/2010 is the date i guess
Old 29th July 2013, 10:27   #24
magneto's Avatar
Thanked: 46 Times
The car has been registered in march 2007 and the ecu is from 2010.
Can I approach the company for investigating their records ,to find out the vin no and registration of the car on which this part was fitted ?
Old 29th July 2013, 11:34   #25
DerAlte's Avatar
Thanked: 2,876 Times
You should, immediately. But, that may not be the manufacturing date.
Talk to Bosch service and ask them to trace the label.
Old 29th July 2013, 12:11   #26
magneto's Avatar
Thanked: 46 Times
Today I called the authorised service centre which so far is the only place where my car has been repaired all these year and told them about this issue .
They have suggested that I bring in the car and they will check the vin and injector numbers on the ECU .
This procedure is done on manufacture of the car for purpose of theft security.
This can be erased by the authorised dealer only as the software cannot be changed by unauthorised people .
So I am now curios to know these facts ,and will keep you posted as this is getting more and more interesting by the day .
Old 30th July 2013, 12:35   #27
magneto's Avatar
Thanked: 46 Times
I have confirmed that the number is not the manufacturing date and the ECU does belong to this car .
One more interesting thing i scanned the lable with my cell and got the part number and when i did a search of the part number i managed to get the parts catalogue of the scorpio Try it on the picture its interesting .
Old 30th July 2013, 13:04   #28
DerAlte's Avatar
... i scanned the lable with my cell and got the part number ...
The bar code or the 2D code?
Old 30th July 2013, 13:08   #29
Thanked: 39 Times
Hi..
Good to know your problem has been sorted out.
you can try to play with your old ECU, try to identify the problem.
I did solve a problem with my zen ecu without replacement.
I scanned the ECU using a OBD scanner, it showed no errors.
I located the problem to a small capacitor in TP sensor circuit, but for me my problem has been solved without the capacitor replacement :-). So i didnt worry about the capacitor.
Just cleaning the ECU solved the problem.
Reference to my experience with ECU
http://www.team-bhp.com/forum/techni...ml#post3107952 (Trouble with the Zen's ECU)
All you need is a multimeter and the service manual to diagonse the problem.
Just measure the voltage at every pin and refer to service manual for known values.
This way you should be able to atleast locate the problem area.
Cheers!
T1000 is offline   (1) Thanks Reply With Quote
Old 3rd August 2013, 23:58   #30
magneto's Avatar
Thanked: 46 Times
The bar denotes the model number of the ecu.
Mahindra Scorpio : Issues & Solutions renamo Technical Stuff 4368 16th December 2017 11:38
Upgraded Scorpio ICE, Few nagging issues. agbenny In-Car Entertainment 2 24th July 2010 13:17
Scorpio vlx mhawk problem with ECU. desi_wananchi Technical Stuff 4 7th September 2009 08:30
