Old 27th August 2016, 22:25   #61
Originally Posted by andescondor View Post
Gave the car. Reproduced the low oil pressure issue. Idling issue could not be reproduced as it occurs only during cold start. Also, the chief technician wasn't there. I might need to come here tomorrow if needed.
High idling rpm issue seems to be resolved. Culprit was weak battery. Since the battery was needing to be charged frequently, the idling rpm was shooting to 1000 at times. Replaced battery and engine is back to regular rpm. Issue was fixed today. Need to monitor. KR Puram ASS told me there are some issues with server and hence they are unable to update the software. I believe there are a bunch of 2012 cars awaiting software update as per the insider birdie. Expected ETA is 15 days. Waiting with clenched fists.
andescondor is offline   (1) Thanks Reply With Quote
Old 28th August 2016, 08:49   #62
hrman's Avatar
Thanked: 396 Times
Default Re: Skoda Rapid Diesel: Cold start issues
What is faint loss of oil pressure?
Sutripta
I experinece it in the morning during cold start. When you switch on the ignition and slot it into first gear, the car sometimes comes to a stop.(torque does not take over and move the car ahead).This does not happen during the day.
hrman is online now   Reply With Quote
Old 28th August 2016, 19:35   #63
Thanked: 2,374 Times
Infractions: 0/1 (4)
Now I'm totally confused. What does this have to do with oil pressure.
What I initially anted to know was what was 'faint loss of oil pressure', and how did you detect it?
Sutripta
Old 28th August 2016, 19:38   #64
hrman's Avatar
Thanked: 396 Times
Sutripta
Hi, I never mentioned anything about oil pressure. Was talking about loss of power (if its easier to understand) during cold start.
Old 28th August 2016, 19:49   #65
Oh OK!
Since your post was in between other posts, and in reply to other posts talking about loss of oil pressure, sure got the feeling that the 'pressure' you were also talking of was oil pressure.
Sutripta
Black Beauty, Skoda Rapid - 20,000 kms & Overheating Issues rapidrahul Test-Drives & Initial Ownership Reports 44 17th October 2014 18:41
A red hot rapid install in a red hot (Skoda) Rapid Samridh In-Car Entertainment 28 18th August 2013 00:49
Skoda Rapid Warranty Issues: ICE blamed for Power Window Failure veeru27 In-Car Entertainment 93 23rd June 2013 12:14
Karizma Cold Start Problem jazzy_2cool Motorbikes 18 19th May 2010 18:07
Cold start vs warm start, is there a difference? Shan2nu Technical Stuff 6 18th May 2010 18:32
