Old 17th July 2013, 21:30   #1
Thanked: 14,609 Times
Default The rear windshield's black border - What for?
Hello Guys,
Wanted to post this topic from long so started searching the forum to avoid a repeat but could not find any thread, so starting this new one.
I have seen many cars which sport a black border on the rear wind shield. My question and point of doubt is:
1) What is the use of this border (Aesthetically and Functionality wise)?
2) Why are there variations in it's size when seen in cars from different segments (Hatches, Sedans, UV and SUV etc)?
On what basis does the manufacturer design this border for a car and why not keep it at a minimum level so as to enhance rearward visibility.
I am uploading pictures of the various cars which sport the various sizes of the Black Border on its wind shield.
Hatchbacks
Maruti Alto K10
Maruti A-Star
Chevrolet Beat
Chevrolet Sail
Fiat Punto
Ford Figo
Honda Brio
Hyundai Eon
Hyundai i10
Hyundai i20
Mahindra Reva
Maruti Alto 800
Maruti Swift
Nissan Micra
Maruti Ritz
Tata Nano
VW Polo
Maruti WagonR
Sedans
Ford Fiesta
Honda Amaze
Hyundai Elantra
Fiat Linea
Maruti Swift Dzire
Renault Scala
Tata Indigo Manza
Note: Source of Images are from the Official Test & Review threads of the cars. Thank you!
Awaiting response from the gurus and all on this issue. Hope my doubt is not a silly one and want to get this cleared.
Thanks,
Anurag.
a4anurag is offline   (6) Thanks Reply With Quote
Old 17th July 2013, 22:17   #2
Default re: The rear windshield's black border - What for?
UV's/SUV's
Audi Q3
Chevrolet Enjoy
Ford Ecosport
Ford Endeavour
Honda CR-V
Mahindra Quanto
Mahindra XUV 5OO
Maruti Ertiga
Nissan Evalia
Renault Duster
Tata Safari Storme
Name:  Safari Storme.jpg
Skoda Yeti
Tata Aria
Toyota Fortuner
Observations:
1) The hatchbacks have a medium thick border on it is rear wind shield
2) The sedans sport the least thickness of the border and
3) The UV/SUV sport a thick border as compared to the rest.
What could be the reason for this?
Cheers,
Anurag
a4anurag is offline   (7) Thanks Reply With Quote
Old 18th July 2013, 11:03   #3
mobike008's Avatar
Thanked: 8,319 Times
Note from Mod : Thread moved to technical thread.
mobike008 is offline   (1) Thanks Reply With Quote
Old 18th July 2013, 11:09   #4
condor's Avatar
Thanked: 4,906 Times
Check the inside of the windhshield - the black border that you see from outside, acutally hides the frame of the door.
There are two ways a rear windshield is mounted.
1. Like the old SUV's (eg: Sumo) - the door has a cut-out for the windshield - this cut-out is surrounded by a metal border. The windshield is then mounted using a beading.
2. The cars that you have shown above :
The windshield is stuck on to the metal border, giving a more aesthetically pleasing look. The black border hides the metal frame of the door.
condor is offline   (10) Thanks Reply With Quote
Old 18th July 2013, 11:19   #5
Thanks Condor for the prompt reply.
If that's the case then why the size (thickness) must vary so much?! If it's stuck into the frame then you mean to say the frame is that thick? For example look at the Chevrolet Beat, Ford Ecosport.. They all have a thick border that hamper visibility and I don't think the frame would be so thick.
If the border is designed to hide the frame then Sedans have a low frame as many have a low border. Structural integrity is in question so nothing much can be done to decrease this birder issue. Right?
Cheers,
Anurag.
Old 18th July 2013, 11:30   #6
vikram_d's Avatar
Thanked: 940 Times
Most rear windshields these days come with electric defoggers. Some of them also have radio antennas built into them. So in my opinion another reason for the black border may be to hide the wire ends.
vikram_d is offline   (2) Thanks Reply With Quote
Old 18th July 2013, 11:35   #7
groom's Avatar
Thanked: 201 Times
I vaguely remember seeing this assembly process during Toyota Bidadi visit.
Behind the black border and the metal frame, there is also a some black glue which the operator applies (some greasy and rubbery glue), so it makes sense to make the black border more sensible and stylish to cover all these things happening behind it.
But mainly, i think that's what is holding the glass to the frame.
groom is offline   Reply With Quote
Old 18th July 2013, 11:41   #8
condor's Avatar
-If that's the case then why the size (thickness) must vary so much?! If it's stuck into the frame then you mean to say the frame is that thick?
1. The thickness of the border on each side - top vs sides vs bottom vs corner will depend on the thickness of the frame of the door on that side of the cut-out for the windshield.
That's why you will see the sides and/or bottom to be thicker
2. The corners show more border, partly for aesthetic reasons. In some cars like Santro / A-star, the rear indicators bulge into the winshield area, and hence the corner looks thicker.
- Yes we do complain of thick pillar areas that hamper visibility. Would be a trade-off for this type of windshield mounting - which gives a better mounting than in the case of beading mounted windshields.
(compare the older cars with the newer cars - Amby / Padmini / 800 vs any of the cars you have listed here)
Not frame of the car, but frame of the door where the windshield is.
Not much, for this type of economy designs, IMHO.
condor is offline   (1) Thanks Reply With Quote
Old 18th July 2013, 12:05   #9
vinair's Avatar
Thanked: 976 Times
Rear glasses are not mounted on the main structure for all hatch backs and SUVs. Its different on a sedan and hence you will find lesser black material used on the rear glass. The black material is vinyl with industrial glue to hold the glass in place. Earlier thick rubber strips around used to do the work.
This is done more from a aesthetic point of view (to provide a flush fit) and also to save cost.
vinair is offline   Reply With Quote
Old 18th July 2013, 12:21   #10
mpksuhas's Avatar
Thanked: 4,130 Times
It depends on a mix of parameters -
1. To hide the metal frame, glue used to fix the wind shield.
2. To avoid de -fogger metal strip heads being visible from outside
3. Aesthetic appeal.
mpksuhas is offline   Reply With Quote
Old 18th July 2013, 13:08   #11
Soumyajit9's Avatar
Thanked: 1,680 Times
I would beg to differ from everyone who feels that it is there to hide the connection of Electric Defoggers. If you see the LS / PS model of Chevrolet Beat, even they have this black border, whereas these variants don't come with defoggers. Same with LX model of Alto, or any car's lower variant without defoggers.
I would more likely agree to Condor's first explanation - It hides the ugly looking metal frame + Aesthetic appeal (as mpksuhas mentioned).
Adding to this, my Chevy Beat has this black frame even on the front windshield !!! And I don't see any defoggers here. So I can bet, that it is purely to hide metal frames and make the car look stylish and beautiful.
Soumyajit9 is online now   Reply With Quote
Old 18th July 2013, 13:19   #12
The black border on the Front Wind Shield is there on all cars but the point is it is uniform thickness on the front in all cars but not the same on the rear wind shield.
I too feel condor has explained the point well and seems mainly for aesthetic appeal and to hide the frame below.
Anurag.
Old 18th July 2013, 13:40   #13
Skyline GT-R's Avatar
Thanked: 219 Times
It is there to hide the black adhesive (tar like) which holds the glass to the frame. The adhesive, since applied manually will not have an even finish & spread when the glass is pressed to the frame. It needs to be hidden. Difference in width between car models is because of the difference in door frame designs and aesthetics.
Sedans generally will not have any door design interference or tail lamp design aesthetics under the glass & hence less width.
Skyline GT-R is offline   Reply With Quote
Old 18th July 2013, 13:41   #14
Soumyajit9's Avatar
Anurag.
Exactly, that is what I am trying to put forward. There is no special reason for putting up those black borders, except covering up the ugly metal frame + black adhesive. For the front windshield, most have a fixed design, mostly rectangle. So the border is uniform. Coming to the rear windshield, the structure varies. So the width of the border varies. If I make the rear border width for my Beat, a little thinner, I am sure it would expose the rear speakers a bit. So the border is wider in my Beat.
Old 18th July 2013, 13:41   #15
Reinhard's Avatar
Thanked: 1,212 Times
I believe the thickness relates to the width of frame / monocoque that will be exposed when the hatch is opened. So its closely related with the hatch / rear door design. In case of the sedans, design is such that there are no hinges nor are their any other parts like struts / AC vents behind the rear windshield on the C pillar. So there is not much to hide, and thus the black border is the thinnest. In cars where there is a rear hatch / door that takes the rear windshield along, the black border will be thick.
In UVs / hatches, these parts come into picture along with inner body panels & plastic moldings which are broader than the door border besides the cut-out area. So these have to be hidden using the black border.
Reinhard is offline   Reply With Quote
Rear windshield broken on brand new DZire ZDi windsurfer Technical Stuff 33 9th October 2011 17:01
Swift LDI - Rear windshield judder IndrojitSircar Technical Stuff 17 21st June 2011 15:25
Rear windshield wiper queries. arpandiv Technical Stuff 7 5th June 2009 09:59
rust in border of Lancer's windshield rajivanoj Technical Stuff 12 3rd December 2008 17:00
Effect of solar film on the rear windshield (with Defogger) hbaruas Modifications & Accessories 1 11th March 2008 14:44
