Old 13th October 2013, 23:20   #61
bikertillidie's Avatar
Thanked: 590 Times
Default Re: My very own Premier Padmini - Restoration in progress
Originally Posted by samsag12 View Post
The paint job seems really very nice & the various fittings are complementing it very well.
The brackets for holding surge tank, washer fluid & fuel filter look neatly fabricated & don't seem out of place, another great job done.
BTW Looking at the 8th pic (from top) there are 2 fuel pipes visible, one from Mech. fuel pump & other from fuel filter, am kind of confused, have you got the electronic pump fitted on the car or am I missing something ?
PS: Thanks for sharing that PVC idea for sealing the pedal surround I plan to do a similar setup on mine too as heatlon isn't holding well.
Hi Samsag12,
I have not used any electronic fuel pump. The plumbing of the fuel line was done as follows -
Fuel tank -> metal tubing -> double-walled silicone tubing -> fuel filter -> double-walled silicone tubing -> mechanical fuel pump -> double-walled silicone tubing -> carburetor.
13-Oct -
The front and rear bumpers were fitted today.
Tail lamp, reversing lamp and number plate lamp assemblies were fitted to the car today. Laying the new rear wiring harness plus speaker wire is now complete.
It was a real pain getting the wiring to pass through A pillar
Happy Dussehra to everyone.
More updates next week.
Last edited by bikertillidie : 13th October 2013 at 23:30. Reason: Adding one more pic
bikertillidie is offline   (6) Thanks Reply With Quote
Old 19th October 2013, 00:22   #62
Thanked: 590 Times
18-Oct-
Work on the car was on hold for the last couple of days owing to Bakri Eid. It will resume from tomorrow.
Attaching a few more pics showing new rear wiring harness and the fuel tank filler cap.
The rest show the C pillar, new monograms and the cover for the fuel level sending unit (scavenged by Wahid bhai @ Sion).
bikertillidie is offline   (8) Thanks Reply With Quote
Old 19th October 2013, 21:11   #63
FINTAIL's Avatar
Thanked: 1,110 Times
By far the best Premier Padmini restoration on Team Bhp. Where in
Poona is the work being done?
Top work. You have not overdone anything. Perfect and just right.:
FINTAIL is offline   (1) Thanks Reply With Quote
Old 21st October 2013, 10:50   #64
Thanked: 590 Times
Hi Fintail,
Thanks for your comments.
All work is being carried out at a friendly local garage @ Hadapsar owned by Raje Khan Pathan.
It makes it easier to oversee the work being undertaken.
Plus they have no past baggage of being the best in vehicle restoration.
The benefit is, they are a lot more receptive to what the customer wants and are willing to put in a lot of effort to put a smile on your face.
All electrical wiring is being undertaken by yours truly !
bikertillidie is offline   Reply With Quote
Old 21st October 2013, 12:48   #65
FINTAIL's Avatar
Anyway, this car seems to be MH-12-W registered. That would make it a what? 1995-1996 car. Anyway, top work. Kindly provide me with the address of the garage, as I might be restoring my Delight, sooner or later.
FINTAIL is offline   Reply With Quote
Old 21st October 2013, 18:06   #66
Thanked: 590 Times
Anyway, this car seems to be MH-12-W registered. That would make it a what? 1995-1996 car. Anyway, top work. Kindly provide me with the address of the garage, as I might me restoring my Delight, sooner or later.
Fintail,
You may get in touch with Javed Pathan @ 9860989119 for clarifications.
His garage is located next to the Hadapsar Gliding Centre approachable either via Fursungi/Sasane Nagar.
Old 22nd October 2013, 13:04   #67
Thanked: 590 Times
21-Oct -
The car is back home awaiting the upholsterer's arrival.
Windshields would be affixed once the roof-work is ready.
Rims would be painted in silver after all upholstery work is complete.
Bleeding of brakes, tune-up, paint touch-up would follow.
Attached are a few photos
bikertillidie is offline   (3) Thanks Reply With Quote
Old 27th October 2013, 20:55   #68
Thanked: 590 Times
27-Oct -
Upholstery is complete. Haven't been able to find the time to finish off the wiring but hopefully, Diwali holidays should prove handy.
Despite my earlier reservations, the door-pads were screwed in place as the original clips proved next to impossible to source.
Windscreens have been fixed and no leakages were observed.
bikertillidie is offline   (7) Thanks Reply With Quote
Old 27th October 2013, 23:37   #69
samsag12's Avatar
Thanked: 200 Times
The interior design looks very nice, really like the pattern on seats & door pads though sad to know about the non-availability of clips.
Also I may sound harsh but the interior work doesn't seem very good, there's a fair amount of crease on seat joints, the door pad edges aren't smoothly folded & the roof lining boasts of chalk marks which should have been cleaned off before mounting it to the car ( high chances of sagging if cleaned while its on the car)
After the amount of body & mechanical work which has gone into this car, literally a nut & bolt restoration & your enthusiasm towards getting it restored in the best possible way, I feel the interior work isn't at par, I am really sorry to say this, please don't mind.
Other than that, the overall outcome is astonishing, hope you enjoy driving it.
samsag12 is offline   (1) Thanks Reply With Quote
Old 28th October 2013, 00:13   #70
Thanked: 590 Times
Dear samsag12,
Thanks for the upfront comments ! I really appreciate it.
The chalk marks/adhesive stains would be removed later with petrol. The creases are visible because I had been seated in the driver's seat immediately before shooting the photographs.
If the car were to be left parked for half an hour in the sun, the material would appear taut again.
A lot of work still remains, and it's really testing my patience.
Best Regards.
Old 5th November 2013, 12:22   #71
Thanked: 590 Times
05-Nov -
I have handed the car back to Javed for the wheel rims to be painted in silver.
The car would be polished and handed back probably by end of day tomorrow.
Valve clearance needs to be checked and rough idling/lethargic acceleration needs to be sorted out.
All electrical work was completed yesterday (the long Diwali weekend proved very handy)
bikertillidie is offline   (1) Thanks Reply With Quote
Old 5th November 2013, 13:00   #72
Karthik1100's Avatar
Thanked: 366 Times
Thumbs up Re: My very own Premier Padmini - Restoration in progress
Splendid restoration!! Hope the rest of the work is completed soon. If possible, share the restoration costs too.
Waiting for the final pictures and hope they will be from a scenic location aka a proper photoshoot!!
Karthik1100 is offline   (1) Thanks Reply With Quote
Old 5th November 2013, 16:12   #73
narendra.vw's Avatar
Thanked: 401 Times
The colour of the car's second photo 21-Oct before upholstery work, I would love to have my car that colour with your interior colour choice. I know it should be a shade of a wall reflecting on the car. Regarding work it has come out clean just like the car colour. Make sure to have light inside where foot rest (Driver side & passenger side.) Not to forget dickey light. They are very handy.
narendra.vw is offline   (1) Thanks Reply With Quote
Old 5th November 2013, 17:01   #74
Thanked: 590 Times
Karthik1100,
For a proper photoshoot, I guess there's a long wait involved till Christmas.
Shall attempt to share a few pics over the weekend.
Old 5th November 2013, 17:20   #75
Thanked: 590 Times
Hi Narendra.vw,
None of the photos are doing justice to the actual colour of the car.
It's a slightly creamish shade of white (for lack of a proper layman's description for pale lilac).
Shall try taking a few pics using a DSLR during the actual photoshoot requested by Karthik1100.
I have installed such a light at the front for the passenger's side & one for the trunk.
The driver's side was pretty challenging as the bonnet release lever left no room to manouvre a drill. Hence, this had to be omitted from the driver's side.
Restoration of Arun's FIAT - '91 Premier Padmini 'Economy' funkykar Technical Stuff 84 1st May 2017 14:55
Restoration of my Premier Padmini altoman Technical Stuff 38 26th March 2015 14:11
Restoration of Premier Padmini S1 (the Special one) samsag12 Technical Stuff 133 28th July 2013 22:18
Used Maruti800, premier padmini , premier 118ne ? sakharamcool Hatchbacks 8 27th May 2008 11:17
