Old 17th September 2013, 20:26   #16
Thanked: 2,072 Times
Default Re: Bosch develops new electronic clutch
Unless it is one part of a much bigger picture (which we don't know of yet), still don't see value in it. And no great shakes as far as engineering goes.
Sutripta
Sutripta is offline   (1) Thanks Reply With Quote
Old 27th December 2014, 14:14   #17
RavenAvi's Avatar
Thanked: 28,235 Times
Default Bosch's new eClutch AT (AMT alternative) in the Honda Brio!
Scheduled to be introduced in India by 2016, the new eClutch automatic system is an "attractive alternative" to the conventional Continuously Varying Transmission (CVT), which engages the clutch only, not the transmission.
Among the technologies that could hold sway is Bosch’s eClutch. Unlike a fully automatic transmission, the eClutch automates the clutch only, not the transmission. The cable-less clutch pedal transmits an electric signal to an actuator, which decouples the clutch. In congested traffic conditions, the eClutch allows the driver in a manual transmission car to use first gear without using the clutch.
SOURCE (and more details) - AutoCar Professional
RavenAvi is offline   (4) Thanks Reply With Quote
Old 28th December 2014, 02:35   #18
swiftnfurious's Avatar
Thanked: 6,429 Times
Just to understand better, we need to activate this eClutch when we need it to function and then switch it off (when we do NOT need it)?? As I understand, the vehicle will continue to have 3 pedals and this is NOT replacing anything.
swiftnfurious is offline   (1) Thanks Reply With Quote
Old 29th December 2014, 15:30   #19
adisag's Avatar
Thanked: 42 Times
Originally Posted by DerAlte View Post
A-ha! O-ho! Clutch-by-wire.
This has to be OE, and can't be retro-fitted - unless they give the potentiometer pedal as an aftermarket attachment which would also couple to the Master Cylinder. I would be too happy to give my Safari as a test vehicle if they bring this to India.
I thought (and am hoping) that this would be mostly targeted at the retrofit market.
Why would anyone who is clear that he/she wants the convenience of an automatic shift from day one not opt for something like an AMT instead?
I see a fairly substantial market for retrofits, especially from people currently driving 'heavy clutched' diesels who are not quite looking at an autobox, but would welcome a little respite in bumper to bumper traffic.
Just like you, I would be more than happy to give in my Yeti for the retrofit if possible
Sutripta
This does seem to be part of a larger picture, disconnecting the drivetrain at cruising speeds to reduce rolling resistance and improve FE, much better integration with Start Stop systems (al'a Mahindra Micro Hybrids) and of course the convenience of two pedal operation in traffic.
This video explains some of the same.
I see a lot of value in this, especially for folks not quite ready to trade in their cars, but at the same time looking for some of the convenience of an Automatic Transmission.
adisag is offline   (1) Thanks Reply With Quote
Old 29th December 2014, 19:40   #20
DerAlte's Avatar
Thanked: 2,876 Times
... "attractive alternative" to the conventional Continuously Varying Transmission (CVT), ...
Err ... Confusing. How does CVT find mention in this context?
... activate this eClutch when we need it to function and then switch it off (when we do NOT need it)?? ...
There is no "on/off" involved IIRC. One just presses the clutch pedal (which has a spring to give a feeling, like accelerator pedals today) to disengage clutch. Just that the (possibly electric) motor will position the clutch, instead of conventional wire or hydraulics connected to pedal. This will reduce pedal press effort, and also allow 'half-clutching'.
Originally Posted by adisag View Post
... targeted at the retrofit market. ...
Not the Bosch system, since it involves replacement of the conventional clutch pedal with a dummy pedal that has a potentiometer, which is not a trivial task.
There is a Korean system that has been available for more than 10 years now in India. In this system, a button is installed on knob of the gear shifter stalk. The (electric) motor unit mounts under the chassis, and directly pulls the clutch final lever with a flex cable. When one wants to shift, one presses the button and shifts gear, and releases button to engage clutch.
Comparatively, the Bosch system will disengage clutch proportionate to the clutch pedal position.
DerAlte is offline   (1) Thanks Reply With Quote
Old 29th December 2014, 20:26   #21
Very very much doubt if it is for the retrofit market.
It is a cog in a larger machine.
Some cars (Rover P4s, IIRC) did have freewheels. Find out why these were ultimately discarded.
As a standalone unit, I don't.
Sutripta
Old 30th December 2014, 10:11   #22
Thanked: 576 Times
The system looks good on paper but I can straight away imagine a situation where the lazy driver doesn't bother shifting gears appropriately and wears out the clutch very fast because of excessive slipping.
I feel that these halfway solutions create more problems than solving any.
Motard_Blr is offline   Reply With Quote
Old 1st January 2015, 11:50   #23
damager21's Avatar
Thanked: 2,392 Times
ACI video which shows the Honda Brio being tested with e-clutch
damager21 is offline   Reply With Quote
Old 2nd January 2015, 12:45   #24
ISO
Thanked: 55 Times
Will be much useful for the diesel vehicle where clutch is very hard to activate
ISO is offline   Reply With Quote
Old 19th June 2016, 07:57   #25
Any update on this ? Will Bosch release this for after market fitment in India ?
Regards!
nithi is online now   Reply With Quote
Old 6th December 2016, 11:57   #26
Thanked: 18 Times
Is Bosch e clutch or any other auto clutch available in the market? Especially Bangalore. I have Chevy Beat in excellent condition but is MT. In Blore traffic I'm facing left leg pain, so was thinking to buy an AMT car. I came across some info on auto clutches but nothing concrete or reliable. Any pointers would be helpful.
Thanks,
Sanjeev
SanjeevKalra is offline   Reply With Quote
Old 31st March 2017, 08:57   #27
FIAT3031's Avatar
Thanked: 83 Times
After reading through so many thoughts posted on this topic,
I am just a little curious to know which segment (compact car / sedan or SUV) would be best suited for e-clutch ?
( Company fitted similar to other Automatic Transmissions like AMT, AT, CVT, DCT )
My personal opinion is Compact Segment cars (Alto ~ WagonR/Celerio )
FIAT3031 is offline   Reply With Quote
BHPian HiSunil develops a remote-controlled Gurkha (AKA Tank) tsk1979 4x4 Vehicles 3 10th September 2013 12:24
Hella develops LED HeadLamps Stratos Technical Stuff 19 31st October 2010 18:43
Toyota develops their own flower species Bumblebee86 The International Automotive Scene 9 31st October 2009 14:46
Toyota develops rear window air bag kalpeshc The International Automotive Scene 3 1st October 2008 21:53
BMW develops automatic parking system nishantgandhi Technical Stuff 7 30th January 2008 13:38
