| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #31 (permalink) | |
| BHPian | Why only deduct??, why not add to get the real speed?... I meant how to decide, whether to deduct or add a percentage to get the actual speed of the car. Can anyone answer my question without any assumptions or guessing? Because, this would become important where speed limits are imposed. Quote:
What distance the GPS measure to calculate the speed? 1. Is it the distance travelled by the car's Center of Gravity? (OR) 2. The displacement from point A to point B. (displacement refers to shortest distance between A and B) I asked so because, i guess GPS uses satelites.
__________________ ....HINDUISM ........JAINISM .......BUDDHISM ......SIKHISM ........ISLAM CHIRSTIANITY Last edited by kkr2k2 : 8th January 2007 at 15:41. | |
| | #32 (permalink) | |||
| Distinguished - BHPian ![]() | Quote:
you have to have a 10-12% difference in rolling circumference, which translates to 10-12% difference in overall wheel diameter. This is IMHO a huge difference, which practically impossible in real life! Variations in tire size for any specific car are not that wild! With big cars it's impossible, but even if we calculate for the dimunitive Maruti 800, This will mean that for a positive error of 10%, the standard 145/70R12 tire tread is worn down by 2.5 cm which is preposterous! and for a negative error of 10%, the standard 145/70R12 tire is changed to 145/88R12 which again is preposterous! Quote:
or you're travelling close to the speed of light when the car length shortens (ref: Carl Sagan's TV show on Einstein's theory of relativity). Quote:
This makes sense in two cases. Case 1: You are travelling in an absolutely straight line between measurements. Then displacement is identical to distance travelled. Case 2: When the displacements measured are infinitesimally small. This will be the case if you have a high-end aircraft GPS receiver-computer, which costs as much as the car itself, or if the car is creeping at a speed below 5 km/h. | |||
| | #33 (permalink) |
| Newbie Join Date: Jun 2006 Location: New Delhi
| Is this error also found in imported cars or only in indian cars ?? And if yes den wat percent (like in indian cars it is usually 10-12%). I owe a Toyota Corolla 1985 model. My speedo shows 160 on full acceleration, so wats my actual speed at that time ?? Plz Advise . |
« k&n trouble over cng
traction »
| Thread Tools | |
Similar Threads | ||||
| Speed difference between GPS and speedo | rkbharat | Gadgets, Computers & Software | 9 | 12th March 2008 15:01 |
| difference between speed,power,xtramile,supershell and reliance petrols please? | rider60 | Technical Stuff | 4 | 28th April 2007 19:27 |
| Digital Speedo | naveendhyani | Technical Stuff | 31 | 25th December 2006 02:15 |
| my speedo ended !!!- zen needle crosses last point on speedo | speed0mania | Street Experiences | 81 | 11th August 2006 13:22 |
| Help with Rpm vs Speedo Speed | viper | Technical Stuff | 13 | 20th May 2006 18:56 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488
