Old 11th June 2006, 14:04   #1
Thanked: 11 Times
Default Blow Off Valve For Turbo
Guys,
I want to know what is Turbo Blow Off Valve?
How Does It Work ?
Can anyone please provide the picture of it ? Can it be fitted in Skoda/Merc?
I have heard, hissing sound of turbo is awesome,
and it comes from Blow Off valve, Is that TRUE?
Experts So Please Help Me Out..
Cheers,
Mugen_Power.
Mugen_Power is offline   Reply With Quote
Old 11th June 2006, 15:05   #2
Try this link
http://www.newton.dep.anl.gov/askasc...9/eng99202.htm
2L8uLoose is offline   Reply With Quote
Old 12th June 2006, 13:35   #3
turboindia's Avatar
Originally Posted by Mugen_Power
Guys,
How Does It Work ?
Cheers,
Mugen_Power.
The blow off valve is basically a diverter valve the only difference being that the Blow off valve exits the excess air into the atmosphere whereas the Diverter valve diverts the air back into the intake system.
Since you are looking for sound the bad news is you cannot fix a blow off valve on a Skoda or a Merc. The ECU will see it as a fault and will show up a CEL( Check Engine Light). The closest option for you is to use an aftermarket Diverter Valve like the Forge ones but again they can be used only for the Skoda Petrol 1.8T's. HOPE THIS HELPS
turboindia is offline   Reply With Quote
Old 19th July 2008, 01:26   #4
abhinav.gupta88's Avatar
Thanked: 310 Times
How much does a Blow Off Valve cost for a Skoda Octavia vRs
And Also the turbo timer.
Where can i get these things in Delhi?
Old 19th July 2008, 08:41   #5
turboindia's Avatar
Contact Arush (Autopsyche). I am sure he will be able to help you. +91 9810518681 / +91 9999037771
Old 20th July 2008, 00:59   #6
Thanked: 660 Times
Now why do you need to intstall that in a perfectly running car. just for the sound?
Old 20th July 2008, 11:44   #7
V-16's Avatar
Thanked: 862 Times
An RS uses a Diverter Valve and cannot be fitted with a BOV as both work in the same way but divert the excess air in seperate areas.
I think its a Japanese "thing" to use BOVs and an European "thing" to use a Diverter Valve.
V-16 is offline   Reply With Quote
Old 20th July 2008, 21:57   #8
binz's Avatar
Thanked: 412 Times
Ive seen and heard a couple of skodas with bovs in Bangy.It should be possible.
Old 20th July 2008, 22:20   #9
ananthkamath's Avatar
Thanked: 63 Times
All OEM installations (regardless of country of origin) use diverter valves (or compressor bypass valves) because BOV's dont make much technical sense. Its only for the noise. You get much better spool between shifts with a diverter than a BOV.
ananthkamath is offline   Reply With Quote
Old 21st July 2008, 00:37   #10
Thanked: 310 Times
What is the added benefit of Diverters . How much will it cost?
Old 7th August 2011, 16:53   #11
sajid33's Avatar
Thanked: 64 Times
Default Re: Blow Off Valve For Turbo
Guys , was just scrolling through threads when i came through this discussion , just want to ask , just finalized a deal on a skoda octavia vRS , and since i thought of getting one , i wanted to install a BOV in it , just to hear the whistle sound , i must confess i don't know anything technical about it , but can it be installed on vRS ? i think some BHPians already got their vRS cars fitted with a BOV , can anyone help me here please ?
sajid33 is offline   Reply With Quote
Old 10th August 2011, 15:43   #12
sajid33's Avatar
Thanked: 64 Times
Peter Sir , Can you please let me know about the cost of the aftermarket Diverter Valve you mentioned here , for my Skoda vRS ?
Old 10th August 2011, 17:00   #13
manishalive's Avatar
Thanked: 734 Times
I think the correct technical thing is Compressor By Pass valve. It simply releaves the excess boost pressure than what is required by the engine. And In a way is required in every installation. Has any body heard of Turbocharger surging? This device reduces the opportunity of Turbo Surge.
8 Valve SOHC vs 16 Valve SOHC shineshine Technical Stuff 6 12th February 2016 22:23
DIY: How to Block the EGR Valve on a Turbo DI svsantosh DIY - Do it yourself 42 19th December 2015 15:10
Blow-thru turbo on a carb engine:How do you do it? Sankar Modifications & Accessories 11 3rd October 2010 15:38
Blow Off Valve For Swift Diesel EvilxKnievil Technical Stuff 10 21st March 2010 23:48
Mercedes S69 AMG - News That Will Blow Your Brains Out!!!! GrimReaper The International Automotive Scene 19 28th March 2004 15:53
