View Poll Results: What type of Gear Box do you prefer? (Tall / Short)
Short 51 53.68%
Tall 37 38.95%
Does not matter 7 7.37%
Voters: 95. You may not vote on this poll
Old 18th April 2007, 23:41   #31
V-16's Avatar
Thanked: 862 Times
well i responded to the poll but i thought of it as a short shifter
Well talking about gear boxes, i prefer a close ratio box with a tall 5/6th gear with a short shifter
V-16 is offline   Reply With Quote
Old 19th April 2007, 00:18   #32
sreenivass's Avatar
Default its not Petra limit
Originally Posted by Shan2nu View Post
You've got it wrong somewhere. 3rd and 4th maxing out below 100kmph????
PS : Do you drive a Petra 1.9 by any chance?
Shan2nu
Its not maxing out, Its more of how I drive it than limited by what the GB lets me do. Its a 1.6L. I occasionally redline only in 1 and 2 .
sreenivass is offline   Reply With Quote
Old 19th April 2007, 00:47   #33
esteem_lover's Avatar
Thanked: 451 Times
Originally Posted by turbo_c View Post
The tall GB lets me cruise at 100Kmph with the engine sedately purring away below 3k rpm.
2. I can do 120Kmph in 2nd without redlining!
Is it modded?? Cos, i know a few modded balenos which can't cross 100kph in second.
Nitrous old pal, i have consistently redlined my esteems in 2nd gear to touch 110 without any mods (both my esteems in question were the carb versions). Did someone say modded mpfi esteem & baleno ?? get into the club mahendra.
Old 19th April 2007, 02:02   #34
chetanhanda's Avatar
Thanked: 44 Times
short gears, love shifting..
chetanhanda is offline   Reply With Quote
Old 19th April 2007, 02:44   #35
razor4077's Avatar
Thanked: 258 Times
that answers my question!
razor4077 is offline   Reply With Quote
Old 19th April 2007, 21:46   #36
1100D's Avatar
Thanked: 2,503 Times
How about tall on the first three and shorter (still lower ratio-wise than the third) on the 4th and 5th. You could drive on the first three in the city and then onthe highways you can still have effective pulling power from cruising speeds.
1100D is offline   Reply With Quote
Old 21st April 2007, 00:56   #37
sreenivass's Avatar
Default still lose performance
Lost performance right, you cant go super quick to 4th & 5th through 1st, 2nd and 3rd. Overtaking a pain since you keep coming down to 3rd to overtake.
Old 23rd June 2007, 03:06   #38
Thanked: 20 Times
Whatever the ratio be its terrible to be in an 'adventure s' 4th gear, absolutely flat from 60 kmph onwards.
swathyd is offline   Reply With Quote
Old 24th March 2009, 11:35   #39
Mr_Bean's Avatar
Thanked: 142 Times
I am still not able to figure out the short-tall gear funda. Do you support the following:
Tall gearing means that we don't need to shift gears frequently in city traffic, the engine would not beg for mercy even at higher rpms at say 2nd & 3rd gears. So if the car crosses 100km in 2nd gear, does it imply tall gearing.
If someone could give an explanation comparing two cars, (e.g.) esteem (vs) zen, it would be enlightening.
Mr_Bean is offline   Reply With Quote
Old 25th March 2009, 01:28   #40
equinox22's Avatar
@Mr Bean: A short gear is one with a low gear ratio, and a tall gear is one with a high gear ratio. For example, a 3.267:1 gear is shorter than a 1.147:1 gear. A gear ratio of 3.267:1 means that the driveshaft rotates one time for every 3.267 rotations of the engine.
Ideally the gear ratios should be set up to use the full potential of the engine in each gear. A shorter final gear will allow the use of the highest gear at lower speeds. The opposite issue is reaching the RPM limit in the highest gear. A taller final gear will thus enable more high speed.
My car has a close ratio transmission with the following ratios:
1st: 3.267
2nd: 2.130
3rd: 1.517
4th: 1.147
5th: 0.921
6th: 0.659
Reverse: 3.583
Final Drive: 4.76
This means while cruising in 6th the engine is purring, while at the lights once I am past 1st, I can put up some stiff competition!
equinox22 is offline   Reply With Quote
Spider Diesel Tuning Box VS. Pete's Tuning Box - Spider Box feedback on pg 2 Endeavour333 Modifications & Accessories 130 11th September 2017 01:24
Wagon R Gear box problems prashantk007 Technical Stuff 37 23rd February 2017 18:32
Tall reverse gear in SUVs and MUVs... Why? tsk1979 Technical Stuff 41 30th September 2010 22:20
HELP...!!! Close-Ratio Gear BOX for RX 135 5spee malvechaitanya Motorbikes 0 1st August 2007 11:15
