| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| Newbie Join Date: Jun 2006 Location: New Delhi
| Well guys I have got a Toyota Corolla (1984) model. Being 22 yrs old still its got efficiency to touch 160 (though not so easily) on speedways. Its in quite gud condition but 1 problem which i m facing is dat after exceeding 90-100 kmhr it starts emitting white smoke from behind. Wat cud be the possible reason for this and how can I stop this ?? PLZ ADVISE .... ![]() Note from the Team-BHP Support Staff : This topic has been moved to the appropriate section. We thank you for your thread, and would appreciate you taking the effort to post in the correct section. Last edited by tsk1979 : 12th June 2006 at 23:23. |
| | #4 (permalink) | ||
| BHPian Join Date: Oct 2005 Location: Bangalore
| Quote:
How many KMs has it Clocked ? So long.... Last edited by varunroy : 13th June 2006 at 20:17. | ||
| | #5 (permalink) | |
| BHPian | Quote:
if at 90 /100 u could see white smoke at the rear that means its considerable amount to be seen in mirror and based on this assume it could be piston rings. btw assumption is mother of all --- so get it checked soon and dont drive too fast. 160 is sucidal for this car even if u have restored it.
__________________ 332kmph 1999 unrestricted GSXR1300R ROYAL ENFIELD MACHISMO 1992 636 RB20DET NISSAN | |
| | #7 (permalink) |
| BHPian Join Date: May 2006 Location: Pune
Infractions: 0/1 (4) | HI.... Just to correct my brothers..... White Smoke..... shouldnt mean a Engine OverHaul when driven at high speeds..... BLACK SMOKE ( of same BLACK quality which you see coming out of DIESEL BUSES / TRUCKS) at Startup indicates ENGINE OVERHAUL..... Your cars Km readin would helps to track down the problem.... generally Toyota Engines go up till 4Lakh and above Other things which indicate Engine Overhaul are :- - Black Smoke from Exhaust (Biggest Indicator) - Spark Plugs getting Oil deposit - When you open the Engine Oil CAP..... and smell the cap (also smell ENGINE OIL STICK) .... if it smells BURNT.... and also.... ENGINE OIL IS IN BLACK COLOUR INSTEAD of DARK REDDISH COLOUR. - you will notice sluggish pickup and also low Fuel Mileage...... - Frequent Top Up of Engine Oil.... say per week of about 2~3 Liters and above. Thanks Last edited by passion4cars : 13th June 2006 at 23:30. |
| | #8 (permalink) |
| BHPian Join Date: Feb 2006 Location: Melbourne
| most likely the culprit is the piston rings. an engine overhaul is also a possibility but in most scenarios it can b set right by changing the piston ring. excessive white smoke usually means burning of engine oil. the car needs engine oil topup very frequently. |
| | #9 (permalink) |
| BHPian | Do you notice a drop in fuel effciency... I think its time to rebuild your engine... The piston rings and cylinder bores need to be changed.. This will give you better performance and fuel efficiency..
__________________ Anish a.k.a romy 1997 Maruti 800(Sold) 2001 Fiat Palio |
| Thread Tools | |
Similar Threads | ||||
| Info/Help Needed in importing a Car | raghuram.cg | Super-Cars & Imports in India | 18 | 23rd September 2008 10:25 |
| Paypal:- Info needed. | Gill | Shifting gears | 18 | 11th September 2008 09:23 |
| urgent info needed | dockap | Tyre & Alloy wheel Section | 7 | 11th July 2007 00:54 |
| Info needed about Lansdowne | ntomer | Route / Travel Queries | 11 | 29th March 2007 11:56 |
| Info needed about Shoghi | ntomer | Route / Travel Queries | 8 | 4th August 2006 13:04 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
