Old 8th October 2016, 05:52   #106
Slick!'s Avatar
Default Re: Fiat Palio S10 - Now, Restoration Complete!
Hey mate, I just went through the entire thread in one sitting. Awesome effort to get your S10 back to its former glory. I've got a S10 that I am considering getting freshened up. I know its been a while but would it possible to share details of garages and parts stores that you've used to get the job done? PM is fine too.
Thanks.
Slick! is offline   Reply With Quote
Old 14th October 2016, 02:58   #107
lucifer919's Avatar
Thanked: 307 Times
Thanks.
Hi There,
The S10 was worked on in Bangalore at BugStop. Its a garage in Jakkur, managed and run by Pavan Kadam. All parts replaced on the car are OEM and ordered through 99rpm.com.
Hope this helps.
Kiran.
lucifer919 is offline   Reply With Quote
Old 29th October 2016, 17:26   #108
lucifer919's Avatar
Thanked: 307 Times
Quick update on the car:
Have done 20k kms now with the restoration complete. Car also completed 2 years post finishing. Got the clutch changed as the release bearing was on its way out. On getting the clutch out, found that the plates themselves were almost worn out. Good thing I bought the whole kit. so now the car has new clutch plate, pressure plate and release bearing. Have replaced engine oil, oil and fuel filters and gearbox oil as well.
Clutch is much lighter than before. Happy about this by-product
The alternator bearings started making a racket and were whining for the past 10k kms or so. got new bearings from SKF and replaced them, with no change in noise. Got OEM bearings and replaced but the whine continues. the noise is quite irritating. Got an alternator off a scrapped car and that one whines too. fml! The noise is much lower than my alternator though. so currently running with it till the mech is able to fix mine.
Overall, car is running just fine. no breakdowns or complaints, except the alternator.
lucifer919 is offline   (1) Thanks Reply With Quote
Old 29th October 2016, 20:45   #109
Thanked: 613 Times
Are you sure the whine is coming from the alternator? It could be a different source such as the water pump or the power steering pump. Alternatively, if the alternator is definitely the culprit, try to have it bench tested and dynamically balanced. It's possible that in the process of replacing the bearings, the shaft and or the bearing housing was bent slightly.
Congratulations on your beautifully restored Palio! It makes me very happy to see so much hard work and passion going into a restoration.
Motard_Blr is offline   (1) Thanks Reply With Quote
Old 31st October 2016, 14:08   #110
lucifer919's Avatar
Thanked: 307 Times
We know its the alternator because when we disconnect the aux belts, which go to the water pump and power steering pump, the noise still exists. This would eliminate the other pumps on the car.
I do agree and did suspect myself, that the rotor seems to be the culprit here and not the bearings itself. Do you know where in Blr we can get the rotor balanced?
Old 31st October 2016, 15:14   #111
Thanked: 613 Times
I know that there are a few companies in Peenya industrial area that are specialised in rotor dynamic balancing. I will find out and let you know once I'm able to get touch with a friend who has some knowledge in quality inspections.
Old 1st November 2016, 08:37   #112
Thanked: 613 Times
Hi Lucifer 919.
Try this place below. They do rotor balancing.
Giliyal Industries
Plot No-3, 5th Cross, 1st Stage, Peenya Industrial Estate, Peenya Industrial Estate, Bengaluru, Karnataka 560058
080 2837 2001
https://g.co/kgs/xUrPNl
Old 12th September 2017, 00:59   #113
lucifer919's Avatar
Thanked: 307 Times
Hey All, for anyone following this thread, the car is now for sale. Ad posted in the classified section if you would like to take a look.
My quest for a hot hatch!! Palio S10 EDIT : Now Another one; the mods have begun JayD Test-Drives & Initial Ownership Reports 156 22nd April 2014 14:30
Restoration of 1971 VW Baywindow Microbus: Restoration Complete PAVAN KADAM Post-War 576 20th July 2013 19:35
Fiat Palio S10. Now updated to 72,000 kms! amit Long-Term Ownership Reviews 110 25th July 2012 19:53
Fiat Palio - S10 - The legend lives on ! EDIT - Now Sold karizma_devil Test-Drives & Initial Ownership Reports 88 20th November 2011 20:02
Paid advance for Palio S10 in a hurry. Now in 2 minds! rock18 Hatchbacks 34 7th September 2010 20:54
