| Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al). |
| View Poll Results: I have TRIED IT and have found that ... | |||
| It works wonders for my car/bike. I highly recommend it. | | 15 | 36.59% |
| Slight improvement, but I recommend it. | | 7 | 17.07% |
| No difference at all. Don't bother trying this non-sense stuff. | | 11 | 26.83% |
| It screwed my car!!! Stay away from all boron compounds!!! | | 8 | 19.51% |
| Voters: 41. You may not vote on this poll | |||
| | Thread Tools |
| | #136 (permalink) |
| BHPian Join Date: Jul 2006 Location: pune
| hi i put 50g rams of boric powder in palio gtx gear box. it runs really smooth . silky smooth .............. ummmmmmmah! while crusing it feels as if its in neutral !!! then i added 125 g of powder in m800 engine. the avrage shooted up by 4 kmpl!!! but the oil pressure warning indicator stopped working!!!!!!!!!!!!!!!! as it is a november 86 engine am pushing it with lpg tank and 13 inches alloys +165 falcons in the rear and 145 in front> still getting 18 kmpl!!!!! thanks fine tuning . i have completed 5000 kms on boric powder + mobil 1 which is used in my palio for 10000 kms already. so used mobil 1 +boric acid powder +5000kms .... still going great 16 kmpl in ac ha ha ah ah ![]() |
| | #137 (permalink) |
| BHPian Join Date: Mar 2006 Location: Mumbai
| Hi TURBOSAM, Since you completed 5000 Km with this treatment its advisable to replace only oil filter as most of debris will, be collected here.Also if you find oil too much black then can replace it with new oil filter.Removal of old carbon layers from cylinders restores original compression.This can be felt with improvement in running charecteristic of car. As this is one time metal treatment there is no need to repeat this.Until engine is opened boron particles will stick to inside parts of engine. My Esteem has completed 17000Km with this treatments. Recently I travelled 2000Km with family towards Gujarat in just Rs 3000 as the cost of Fuel(LPG) resulting into Rs 1.5 per Km with 4 persons and with 80% a/c. Enjoy.... Last edited by finetuning : 3rd June 2007 at 17:18. |
| | #138 (permalink) |
| BHPian Join Date: Dec 2006 Location: Bangalore
| Hi, Here is a link and article on boric acid as a lubricant. 5/00 m.e. marketplace: tech focus, pt. 2 However, the following statement from the article makes me to think, whether the boric acid will act as lubricant only when ICE compartment temp below 250 degreeC? "Boric acid dissolved in water can be sprayed on a surface. After the water evaporates, a thin layer of boric acid film remains, bonded to the oxidized layer. After the forming operation, the boric acid can be washed away with water, and even recycled, said Erdemir. He expects boric acid to remain lubricious in temperatures up to 200 or 250°C." regards, -manju |
| | #139 (permalink) |
| Hi manju, Boric acid as solid particles has certain temperature restriction but when it becomes boric oxide in the presence of temp. and pressure inside engine cylinder its different.This oxide layer is very hard & resistive to high temp. and pressure & corrosion.This is the wonderful ability of this particles making it so suitable for engines.This oxide layes is is so hard infact much harder then metal beneath it making it an excellent protective layer. |
| | #141 (permalink) |
| BHPian Join Date: Aug 2005 Location: Kalyani, West Bengal
| Boron additive has been used by Cheveron in their Delo range of gear oils, it proven to be a far better alternative than sulphur based corrosive EP additives, trannies that have soft metal sync rings benefit hugely from this oil, it gives you GL-5 and beyond protection minus the EP damage. Sadly Cheveron India doesn't see the logic of bringing this oil to India.
__________________ 1999 Trax Gurkha 1996 VFJ Jonga 1995 Accord V6 1995 Honda RC 45 |
| | #142 (permalink) |
| Hi abhibh, In your Maruti 800 you can add 100gm pure powder blending it with at least 300 ml engine oil that you are using.You need to use any kind of mixture/blender so that powder mixes well.Then need to filter it with cotton cloth to make sure only fine particles are in oil.You can add this directly into engine oil.If your car has covered more then 60,000Km then carbon accumulation will be high.Within few hours of running carbon layers will start getting piled off.So we need to replace oil filter for safety reason after 100 Km so that carbons gets removed.No need to change oil.You can change oil after 2000Km or more depending upon condition of oil.Normally after using such additive oil becomes dark. Enjoy... |
| | #144 (permalink) |
| Senior - BHPian | Very simple Swathyd. Take a blender and pour half of gear oil that is required in your gearbox. add the requisite amount of boric powder in one teaspoon measurements while the blender is running. When you have completely added the powder, run the blender for 10 minutes. Now mix this boroil shake with the rest of the oil and pour in the gearbox. After filling the gearbox, take the vehicle out for a spin for about 10 kms. And that's it.. Better still is if you can immediately go for a very very long drive. After you come back while the sytem is till hot, drain the gearbox and fill with fresh oil minus the powder. Happy gearing..
__________________ Royal Enfield Bullet 1962 All Black 1998 Safari 4x4 All Black 2004 Scorpio GLx Last edited by gd1418 : 6th June 2007 at 12:03. |
| | #145 (permalink) |
| Team-BHP Support ![]() | Sorry to spoil the party, but I remember reading somwhere that if Zinc and Phosohorous levels in the oil is less than 0.10%, Boron will not have much good effect, unless used in larger quantities, which will ruin filters. Since API recommended that API-CJ4(Latest diesel) and API-SM(Latest petrol) oils have much lower levels of Zinc and Phosphorous, all you may be doing is waste. One option is to fill in API-SL or lower standard cheap motor oil to reap benefits of Boron, but API SL oil contains enough boron already. Boron may be a lubricant, but you will need to change your oil filters more often.
__________________ Reclaimed, wrung dry and recycled....! |
| | #146 (permalink) |
| There is nothing like waste in case of adding boron.....even if oil contains lubricant like phosphorous and zinc they themselves deteriorate with chemical reactions....boron is inert solid lubricant which sticks to metals....its always beneficial and it retains its property in tough conditions....not to forget its excellent friction reduction ability......I think in strict emission norms this plays a very important role apart from lubricating benefits.... |
| | #147 (permalink) |
| Team-BHP Support ![]() | @finetuning, I am not questioning boron's properties. All I am saying is that API laid down standards, and if you compare API-SJ to API-SM oils you will see that the amount of Zn, P and B has been significantly lowered. Reasons could have been emissions, but it means to give same lubrications the manufacturers must be using different things now.
| | #148 (permalink) |
| Agreed tsk but my point is that even if manufacturer are adding something against zinc & sulfer even then adding boron to that makes so much difference....there is no biodegradable lubricant right now available which can perform consistantly.......so I think in future most manufacturer has to adopt this method in any manner till new such wonderful friction reducing technology is discoverd.....also adding nanosized boron is most beneficial but is out of reach of we people... |
| | #149 (permalink) |
| Today's oil, specially the HDEO have excellent base stocks which are shear stable as well as formidable additive package so zinc etc. is no longer necessary, however, one of the favorites of oil treatment, the STP oil treatment has good amount of zinc and is still an allowed additive by the EPA, for long drives in Rajasthan heat, I add it to my crankcase as an extra protection along with Delo 400 or Delvac MX.
| | #150 (permalink) |
| Team-BHP Support ![]() | Gurkha, the delo 400 has 3600+ detergent content compared to castrol GTX, so I think oil drain interval will be less with delo? If I flush before filling will it help in keeping the drain interval long? I am scared of seals going kaput because suddenly you have so much detergent flowing in!
« Nissan Quest - Intermittent air-con blower speed
Different Service Schedules for Different Cars »
| Thread Tools | |
Similar Threads | ||||
| My Experience With Adding Acetone in Petrol | finetuning | Technical Stuff | 453 | 6th August 2009 20:51 |
| My Experience Of Adding 2T Oil In Fuel | finetuning | Technical Stuff | 107 | 29th May 2009 23:06 |
| Adding Engine oil with Diesel. | chanapli | Technical Stuff | 39 | 18th August 2008 21:35 |
| My Experience Of Adding Boric Acid In Petrol | finetuning | Technical Stuff | 50 | 24th June 2008 22:27 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599
so how should i go about it ????
