| Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al). |
| View Poll Results: I have TRIED IT and have found that ... | |||
| It works wonders for my car/bike. I highly recommend it. | | 15 | 36.59% |
| Slight improvement, but I recommend it. | | 7 | 17.07% |
| No difference at all. Don't bother trying this non-sense stuff. | | 11 | 26.83% |
| It screwed my car!!! Stay away from all boron compounds!!! | | 8 | 19.51% |
| Voters: 41. You may not vote on this poll | |||
| | Thread Tools |
| | #151 (permalink) |
| BHPian Join Date: Aug 2006 Location: chennai
| hi, how can we use boric powder for bikes?. adding boric powder in the engine oil will cause slip in the clutch plates as cooled by the engine oil, this is the only reason though i am tempted but not attempting to use for bikes |
| | #152 (permalink) | |
| BHPian Join Date: Aug 2005 Location: Kalyani, West Bengal
| Quote:
Don't worry about seals, I have used Delo 400 in old JEEP engines as well, Arka from JEEP Thrills uses it on his Jeeps, as for Delo lasting less than GTX, let me tell you, Delo400 and Delvac are both rated to go 25000 miles on US trucks, 8000 will be peanuts for your car, just take a look at the UOAs posted at BITOG.
__________________ 1999 Trax Gurkha 1996 VFJ Jonga 1995 Accord V6 1995 Honda RC 45 | |
| | #153 (permalink) | |
| Team-BHP Support ![]() | Quote:
. I will get flushing done and then do a oil change at around 83000kms
__________________ Reclaimed, wrung dry and recycled....! | |
| | #154 (permalink) |
| BHPian Join Date: Mar 2006 Location: Mumbai
| Hi vijaycool, You are right in your observation but if you can try just 8 gm pure powder well blended in your normal oil of say 60 ml then I dont think there will be problem.....there is a trade off between using more amount of such dry lubricant and minimum beneficial one....I tested this with many many bikes with this amount.... Enjoy... |
| | #155 (permalink) |
| @finetuning: have you noted any slip in the motorcycle? i mean in the long run. i am planning to take my bike from chennai to bangalore. lots of high speed driving. will this affect my cylinder/piston coz of adding boric powder (i mean any blockage in the oil path) |
| | #156 (permalink) |
| Hi vijaycool, Sorry for late reply....actually I tried more in cars then in bikes but I used only little amount of just 7 to 8 gms and found no adverse effect.....infact engine runs smoother & there is increase in power too.....also there is increase in FE in bikes using this.... Enjoy... |
| | #157 (permalink) |
| BHPian Join Date: Jul 2006 Location: pune
| sorry for the late and in frequent updates.. in last 7000 +kms i changed oil filters every 2 000kms . my engine was on the verge of overhauling... the third connecting is so worn out it used to make banging noises till the oil pressure builds every morning..... then i added boric powder.............. the noise is gone .......... not evedient for last 7562 kms........................ thanks a lottt........... now the car engine runs bit cooler, so fan runs late and for lesser time ,,saving electrical and thermal loads ... saves energy ..... one more point .... the best improvements were felt when car was driven hard and long<458 kms in a day without stopping the engine> then the avrage increaced by 1 kmpl +car is noticable smoother even to every person who is not aware of my experiments......... and is not technically inclined... soooo long live boric powder, ft and kaiser.............<i will love to add acetone to it toooo ......... |
| | #158 (permalink) | |
| BHPian | Quote:
http://www.team-bhp.com/forum/techni...tml#post470060 (My Experience With Adding Acetone in Petrol) | |
| | #159 (permalink) |
| Hi TURBOSAM, I observed similar experience using wonderful boron in old maruti 800.....it was making engine noise & was drinking too much oil....also FE was just 8....I added in engine oil + gear box & within a month he found engine making very less noise & vibration and FE increased to 12 with smoothness of engine....this uncle of mine now loves to drive car faster as he was unable to do in past....he too had dediced to open engine for overhauling....but now enjoys.... My point is that if engine overhauling is due then why cant we try this to delay it and to rectify the underlying problem?Mechanical wear & tear are prevented to increase the life of engine is the main benefit apart from excellent friction reduction..... Enjoy.... Last edited by finetuning : 16th June 2007 at 16:34. |
| | #160 (permalink) |
| hi finetuning, made a trip from chennai to bangalore almost nonstop on 180ug3. 1. lubed chain and added carrom powder with bearing grease and applied on to the chain. 2, this is where my dilema. when i about to mix carrom powder with oil my dad questioned me how u know its pure boric powder? he is right there might be some chalk powder too mixed. so i went to medical shop asked for boric powder. when i opened the pack it was very coarse compared to carrom powder. i decided to filter out with a cloth. mixed with acetone then added oil acetone and powder settles down not mixing throughly with oil . filtered with cloth may be 3 gms are passed thru cloth rest not filtered. In my case i couldnt find any difference very windy cant hear engine noise came to bangalore 6 hrs flat and engine was relatively cool. top speed cant pass 106 due to wind. i will give another try. plz tell me is carrom powder is pure? |
| | #161 (permalink) |
| Hi Vijay, I m not sure about the purity of powder......its difficult to find so....pure powder is very lubricious & sparkling white and very fine....if you think powder you used was coarse then better try to get it from another place....you are right that anything can be added into it.....now we need to use any kind of blender to dispense powder into oil.......fine particles must be well dispersed in oil & that can be done by mixture......there after you can filter it with cloth......... Enjoy..... |
| | #162 (permalink) |
| new updates , as i told upals my m 800 has crossed 280000+kms nov 86 model. before the magic treatment the engine useto make con rod slapping noise if i cross 80 kmph in top gear............ after boric acid treatment.. i can effortlessly pull it to 135 kmph..... in ac one person on board. wow wow wow . the oil filter is not yet changed yet after 7300 kms..(mobil 1 total service life is @10,000 kms the low oil pressure indicator light stopped working the third day of treatment... the car is running 20 25 deg cooler(oil temp measured through the dip stick and the fan almost stopped functioning unless the ac is on (and its not mal functioning)---- what happens if while changing the engine oil i add boric powder again... (is more is bad! in this case??) |
| | #163 (permalink) |
| BHPian Join Date: Mar 2007 Location: New Mumbai
| After reading all the post on this thread about boric acid ,i finally gathered up all the much required courage to go in for this treatment. So here goes the observation that i have noticed. Vehicle details : M800 97 Model Carb Engine oil :Castrol Magnetic 3lites Mixed 150 gms of boric acid in 3 liters.Mixed it with the help of a mixer.The odometer reading was 800 km now its around 1800 km.So covered a distance of around 1000 km.Boric acid was also added to the gearbox. First 1300 kms ,i used only speed (no acetone mixed with the fuel).Overall observation. 1. Engine had become smooth and the pick up had also increased slightly. 2. Earlier second and third gear shift were a bit hard ,but now believe me the gear shifted like a "makhan". 3. FE that i got was around 17-18 (city+highway). 4. Engine was quieter and cooler . So after driving for around 500 kms ( after the oil+boric was put) on sunday i decide to check my engine oil.To my surprise i saw the oil had become black but was still quiet thick and few specs of carbon on the dip stick.Now decided will start adding acetone and see how the engine responds.So for the next 500 km drove the vehicle with acetone mixed.Now the observations. 1. Engine had now become even more smoother, vibrations hardly noticeable and had to get it tuned up again. 2. Pick up was awesome and feeling of the smoothness, hmmm just can't explain dear. 3. The most important FE .This time i got 19-20 /lt. All the figures are with out A.C and two people on board. Checked the oil again it was really black and had become really thin.Would be replacing it with the oil filter and putting in fresh dose of engine oil and boric acid but this time i am planning to reduce the amount of boric acid may be to 25 gms per liter. What do you say finetuning ? Should i reduce the amout of boric acid or continue the second oil treatment with the same amount. |
| | #164 (permalink) |
| Senior - BHPian | No you don't. This is a one time treatment till you open the engine for overhaul. After you overhaul, my suggestion is to add Boric Powder after 5000 Kms as by that time the vehicle would have properly run-in and all the moving parts would have seated well.
__________________ Royal Enfield Bullet 1962 All Black 1998 Safari 4x4 All Black 2004 Scorpio GLx |
| | #165 (permalink) |
| Hi Ravi & Turbosam, Its great to see you experimenting and getting desired result...... Now.....you must change only oil filter aeap as most of carbon layers that piled off with this powder are in oil making it thick and black.....changing oil filter is a must in older cars & after changing filter you will feel more difference in power & smoothness.......normally in older cars just after 100 km driving we need to change oil filter so that oil doesnt become too thick because of carbons,varnishes & and gunks....you can continue running without changing oil......it takes anything between 600 to 1500 km for passing full benefit with this hence we need to drive with boron treated oil for at least 1000 km..... Remember too much of this powder is not desirable as within oner treatment we get fine layer of boric oxides over metal surfaces so no need to repeat again........ 100 gm is more then adaquate for maruti 800 & other cars up to 3.5 ltr engine oil capacity.... In any case fine microscopic layers of boric oxides must not be disrturbed...so I think one time treatment is more then enough..... Ride & glide with boron at no extra cost.....this is the beginning of friction revolution......you can try using it in wheel bearing.....it works great.....together in engine+gear box+wheel makes a lot of difference in daily driving.... Enjoy..... |
« Nissan Quest - Intermittent air-con blower speed
Different Service Schedules for Different Cars »
| Thread Tools | |
Similar Threads | ||||
| What happens to the engine oil when the Oil cap and/or dipstick is opened and engine? | D.V.R | Technical Stuff | 22 | 10th November 2009 22:31 |
| My Experience Of Adding 2T Oil In Fuel | finetuning | Technical Stuff | 107 | 29th May 2009 23:06 |
| Adding Engine oil with Diesel. | chanapli | Technical Stuff | 39 | 18th August 2008 21:35 |
| My Experience Of Adding Boric Acid In Petrol | finetuning | Technical Stuff | 50 | 24th June 2008 22:27 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
in this case??)
