Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al).
View Poll Results: I have TRIED IT and have found that ...
It works wonders for my car/bike. I highly recommend it. 15 36.59%
Slight improvement, but I recommend it. 7 17.07%
No difference at all. Don't bother trying this non-sense stuff. 11 26.83%
It screwed my car!!! Stay away from all boron compounds!!! 8 19.51%
Voters: 41. You may not vote on this poll
Thread Tools
Old 26th June 2007, 15:57   #166 (permalink)
Ravi Yadav's Avatar
Thanks, finetuning for the update.
Ravi Yadav is offline   Reply With Quote
Old 26th June 2007, 18:03   #167 (permalink)
tsk1979's Avatar
Some Israel university did some research on the MotorSilk product(Which is effectively Boron in a more palatable form)
http://evergreenamerica.com/resource...nionReport.pdf
It works according to them and benefits are due to more wear and tear, but if you want to remove carbon deposits I think a high detergent oil will do the job better.
__________________
Reclaimed, wrung dry and recycled....!
Old 26th June 2007, 21:29   #168 (permalink)
Hi Tanveer,
Removal of carbon through boron treatment is parmanent unlike high detergent engine oil......this is because of aggressive nature of boron particles to stick to metal surface under pressure and temperature making fine layer on surface which during this process itself removes carbon....after this layer is formed there is no chance that carbon gets accumulated.This is the benefit we get apart from very low friction.Research has proved excellent ability of boron in many areas in automobile application.......this technique is so new yet so revolutionary.....
finetuning is offline   Reply With Quote
Old 27th June 2007, 12:24   #169 (permalink)
tsk1979's Avatar
Nope not new, the company has been making motor silk(Boron additive) since 2002.
Before the API-CI/ or SM specification came into force Zinc Phosphorous and Boron were used in engine oil. The new classifications restricted these quantities and these 3 were replaced by other additives.
API-CH oil has quite a high percentage of boron, Zinc and Phosphorous.
For example Mobil 1 super syn has 205ppm of boron, even though its the SL standard. In most oils when the standards got changed reduction in Z and P was also supplemented by reduction in Boron, but in many oils like Harley davidson and Kendell GT oil there is 250+ ppm of boron in oil.
__________________
Old 27th June 2007, 12:29   #170 (permalink)
But what about the people who has voted that boron screwed their engine.
swathyd is offline   Reply With Quote
Old 27th June 2007, 12:41   #171 (permalink)
ravi@64bhp's Avatar
Good question. We need to know what procedure they have followed in doing so.
__________________
03 HH Splendor - 28,000km
06 Kinetic Blaze - 10,700km
07 Kinetic Flyte - 8500km
06 HH Zma - 39,550km
07 WagonR Lxi - 36,500km
ravi@64bhp is offline   Reply With Quote
Old 27th June 2007, 12:41   #172 (permalink)
tsk1979's Avatar
this means that maybe boric acid is not the right way to add boron. When mineral oil companies or motor silk etc., add to engine oil, Boron is not in the boric acid form.
That said, in my opinion, using a good engine oil meeting latest standards is better than using an older standard oil and then putting in boron.
The price difference between a higher standard oil and an older oil is like 30-40rs/liter, which is not much I think.
__________________
Old 27th June 2007, 12:54   #173 (permalink)
2fast4u's Avatar
but getting carbon deposits off either flush or whatever method is better for new engines - older engines have seals which can give way and start a leak. can u let me know ur view??
__________________
332kmph 1999 unrestricted GSXR1300R
ROYAL ENFIELD MACHISMO 1992
636
RB20DET NISSAN
2fast4u is offline   Reply With Quote
Old 27th June 2007, 13:23   #174 (permalink)
tsk1979's Avatar
Yes 2fast, its true. Some very old engines have carbon and other deposits seated into the seals. Removing them could lead to failure. Thats why you have these flushes which say "For engines older than 50,000kms" and some which say "For engines newer than 50,000".
Boron is not a detergent, it forms a bond with the metal when available in free form.
However Boric acid(H3BO3) is soluble only in water.
When heated to 170 degree C it dehydrates forming HB02. This metaboric acid is slightly soluble in water with melting point at 236 degree C.
You do not want Metaboric acid in your engine, trust me. However if your engine oil temperature goes to 170 degree C there are bigger problems than just metaboric acid.
Though I believe addition of boron is good, I cannot see (by way of chemical reactions) that how is it possible for boric acid to release free boron to form a bond with the metal.
Also all commercial regarding this method involve free boron to get the bond, not boric acid.
Now suppose even if your boric acid released free boron, the Hydrogen and oxygen will have to go somewhere, it cannot vanish (poof). So in that case you have Water in your engine oil. A happy thought aint it?
BTW the seive in the oil filters catches all things such as boric acid. A member found the white powder in the engine oil filter.
I am all for DIY stuff, but when the actual chemical reactions are missing and instead you have statements like "Revolutionary way etc., etc.," it leads to skeptism.
__________________
Old 28th June 2007, 00:12   #175 (permalink)
What I mean by word Revolutionary was to have a new approach in lubrication technology blending solid lubricant in liquid lubricant...its indeed new....also as fas as I know this product was in testing phase by many leading companies till few years ago......
Now Boric Acid contain Element Boron and boron doesnt stick to metal surface......its boron oxide which forms a thin layer over surface in the presence of humid air....above this thin film there are plates of boric acid which gives very low friction......
The way boric acid works with moisture is a chemical reaction indeed.....what we get from these reactions is a full layered plates of boric acid above boric oxide film which sticks to metal......this plates are free to glide along the movement of pistons or any moving part but they are very hard if perpendiculer pressure is applied.....means they are extreme pressure resistance.....
My aim is to understand and share this novel concept.........in my view this is not DIY.....
Old 28th June 2007, 01:28   #176 (permalink)
tsk1979's Avatar
Umm some facts.
Till around 1998 Zn P and Boron were present in Large quantities in engine oil
Newer API standards restricted Zn and P contents. i.e. if you wanted your oil to be a new standard compliant, you had to reduce Zn and P. With Zn and P reduction, Boron quantity was also reduced, and while earlier oils had 250ppm and 300ppm of boron many new oils had 0 ppm of boron.
This was around 1998-2002 period when newer standards became more popular.
At this time companies marketing Boron CLS bond came into picture with their products having free boron.
Now coming to Boric acid
1. The Chemical formula of Boric acid is H3BO3
2. IF heated to 170 degrees or above, certain things happen. But engine oil temperature never crosses 170 degrees. If it reaches this level that means car is on fire and wear and tear will be the least of your concerns
3. So the other chemical reaction we have is reaction with moisture
4. For the sake of argument lets assume there is enough water in engine oil to react with Boric acid and reaction does happen
5.Then you will have B(OH)4^- ions not boric oxide(I think you meant Boric Trioxide)
6. B2O3 is boric oxide which is the magic material, but that needs 300 degrees+ temparatures. Now such temperatures will exist in engine bay, but your engine oil will never see temperatures even 1/3rd of this level
So I am unable to find where the chemical reaction takes place where Boric acid is converted to boric trioxide.
BORIC ACID
+1, and +2 Inorganic chemistry course also has these details.
Wikipedia has a basic article
Boric acid - Wikipedia, the free encyclopedia
I am not questioning boron but merely looking for a chemical reaction which will convert boric acid to boric oxide which can coat the metal.
__________________
Old 29th June 2007, 19:18   #177 (permalink)
bruty's Avatar
guys I have read this whole thred for 3 times, but I could not find any cooments from the bhpians who has voted t screwed my car!!! Stay away from all boron compounds. Some one can please show me where ar these comments.
__________________
SUCCESS NEVER ENDS, Failure is not final....
bruty is offline   Reply With Quote
Old 29th June 2007, 23:57   #178 (permalink)
tsk1979's Avatar
Why stay away from boron compounds, boron is good, but I cannot find any chemical reaction in any book where Boric acid converts to Boron Trioxide(B2O3) below 300 degrees. If your engine oil reaches 300degrees this means your car is on fire and you need to call up insurance.
Mileage and performance would be the last thing on your mind.
__________________
Old 30th June 2007, 15:15   #179 (permalink)
If we dont find any link in books about chemical reaction doesnt mean it doesnt takes place.....condition inside engine is so different....we are forgetting extreme pressure which is responsible for formation of oxide at lower temperature....all the experiments about boron were done at atmospheric pressure but inside engine its different senario altogether.....
Here is an extremely useful lik showing the use of boron as FUEL in the coming future.....
Boron: A Better Energy Carrier than Hydrogen? (12 June 2007)
Old 30th June 2007, 16:09   #180 (permalink)
Sam Kapasi's Avatar
I haden't commented so far because I had nothing constructive to add to your thread. So why say anything at all?
BUT
But the above statement is silly, to say the least. Almost all chemical reactions using all known compounds have been documented. In books.
Unless...
The only way to make your sentence ring true is to publicly declare that you have discovered a chemical reaction which has not been discovered so far.
Is this impossible? No, every chemical reaction has been discovered once. If you truly have discovered an undocumented chemical reaction, especially one that is of such obvious help to the automotive world, I suggest you write a documented white paper immediately, backed up with facts.
A white paper on how B2O3 is created using boric acid. If this is indeed true, I can even suggest a thesis on the conversion.
It could change your life. And many others.
__________________
“I am matter and you are matter, but it doesn’t matter.” – Captain Beefheart
Thread Tools
What happens to the engine oil when the Oil cap and/or dipstick is opened and engine? D.V.R Technical Stuff 22 10th November 2009 22:31
My Experience Of Adding 2T Oil In Fuel finetuning Technical Stuff 107 29th May 2009 23:06
Adding Engine oil with Diesel. chanapli Technical Stuff 39 18th August 2008 21:35
My Experience Of Adding Boric Acid In Petrol finetuning Technical Stuff 50 24th June 2008 22:27
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
