Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al).
View Poll Results: I have TRIED IT and have found that ...
It works wonders for my car/bike. I highly recommend it. 15 36.59%
Slight improvement, but I recommend it. 7 17.07%
No difference at all. Don't bother trying this non-sense stuff. 11 26.83%
It screwed my car!!! Stay away from all boron compounds!!! 8 19.51%
Voters: 41. You may not vote on this poll
Thread Tools
Old 3rd September 2007, 12:20   #196 (permalink)
cypher's Avatar
Originally Posted by TURBOSAM View Post
just opened the m 800 engine for the overhauling . there was no sludge formation containing the boric powder ,
it was completely suspended /coated on the engine parts!
@Turbosam, can you please post some pics of the engine, if you have taken any.
__________________
"Aerodynamics are for people who can't build engines." - Enzo Ferrari
cypher is offline   Reply With Quote
Old 6th September 2007, 17:04   #197 (permalink)
I am a new member to team bhp site and registered only after reading finetunings experiment with his car and immideatly applied his theory adding boric acid to engine oil in my decads old Rajdoot. I found dramatical change in its performence (acceleration & gear shifting very smooth).
But i think it may give better performence if used in Four Stroke Bikes where the crank is dipped in engine oil where as in Bikes like mine Two Stroke the crank is dry and lubricated by the oil mixed with fuel only.
Thus i tried his Boric acid in petrol but found no such remarkable change as i noticed earlier Boric Acid in engine oil, may be i have just riden my bike only 1 or 2 km. may be i found it better in the long run.
In future if i got good result (which seems to be obvious) i will apply this in my car zen lxi 2004.
Thanks to finetuning and others who had voted and quoted only after doing this experiment.
sudip is offline   Reply With Quote
Old 7th September 2007, 13:30   #198 (permalink)
Default If i am not wrong i thinl answer to your question lies in this link
Yes 2fast, its true. Some very old engines have carbon and other deposits seated into the seals. Removing them could lead to failure. Thats why you have these flushes which say "For engines older than 50,000kms" and some which say "For engines newer than 50,000".
Boron is not a detergent, it forms a bond with the metal when available in free form.
However Boric acid(H3BO3) is soluble only in water.
When heated to 170 degree C it dehydrates forming HB02. This metaboric acid is slightly soluble in water with melting point at 236 degree C.
You do not want Metaboric acid in your engine, trust me. However if your engine oil temperature goes to 170 degree C there are bigger problems than just metaboric acid.
Though I believe addition of boron is good, I cannot see (by way of chemical reactions) that how is it possible for boric acid to release free boron to form a bond with the metal.
Also all commercial regarding this method involve free boron to get the bond, not boric acid.
Now suppose even if your boric acid released free boron, the Hydrogen and oxygen will have to go somewhere, it cannot vanish (poof). So in that case you have Water in your engine oil. A happy thought aint it?
BTW the seive in the oil filters catches all things such as boric acid. A member found the white powder in the engine oil filter.
I am all for DIY stuff, but when the actual chemical reactions are missing and instead you have statements like "Revolutionary way etc., etc.," it leads to skeptism.
Advanced Lubrication Technology, Inc. - Technical Specifications
Old 22nd September 2007, 19:24   #199 (permalink)
Default No need to change your habit
Hi elf,
Thanks for sharing your reading difficulties but I think what you mentioned is very different from my style of writing.....I used to go this way only after a sentence is over like we do when we talk normally.....pausing in between.....I think when we read very long para we used to miss many words & lines if reading fast.....this way I think we can avoid it.....what can I say more?...anyway I will try to change this habit....
Enjoy...[/quote]
Dear Fine tuning,
its bit late but what the heck....By the way this is Off topic..
Your posts in fact are much easier to read.The ...does give a pause to the sentence and emphasizes it more. Keep it up and dont let anybody encroach in your individuality. if people are irritated the way you write then its time to contemplate on their own mind frame and conditioning to get stuck onto ancient habits..
As far as grammer is concerned the rules are any way changing so fast....SMS and lingo used on the TV....or the chats...teanagers talking in cafeterias. What can you do about it................
premchetan is offline   Reply With Quote
Old 23rd September 2007, 11:57   #200 (permalink)
So I am unable to find where the chemical reaction takes place where Boric acid is converted to boric trioxide.
I am not questioning boron but merely looking for a chemical reaction which will convert boric acid to boric oxide which can coat the metal.
The conversion is probably not taking place.
The link here might be of interest:
ScienceDaily: Nano-boric Acid Makes Motor Oil More Slippery
Old 23rd September 2007, 21:28   #201 (permalink)
yasw_anth's Avatar
wont ther occur any chemical reactions my car's odo has clocked 2000km after changing the engine oil ... can i add boric acid now or during the next engine oil change ... ?
__________________
Cheeers
Yaswanth :)
yasw_anth is offline   Reply With Quote
Old 12th October 2007, 16:35   #202 (permalink)
In this case you need to keep adding Boric Acid every time you change engine oil.
srishiva is offline   Reply With Quote
Old 12th October 2007, 22:33   #203 (permalink)
Kaizer Sozay's Avatar
I got my car serviced yesterday and had clocked over 5,000kms with the boric acid treatment in the engine oil & gear box. I got both the oils changed ( no boric treatment this time).
I must say when i drove the car today the engine felt really very smooth.
Boric is a must do i am really impressed with the results
__________________
"The greatest trick the devil ever pulled was convincing the world he didn't exist ."
Kaizer Sozay is offline   Reply With Quote
Old 12th October 2007, 23:52   #204 (permalink)
Hi Just registered here after reading this AMAZING thread! So far, i guess no one has said that this has had a negative effect on the engine in any way.
Also another link to prove finetuning's theory: Click.
kalpik is offline   Reply With Quote
Old 13th October 2007, 12:44   #205 (permalink)
Okay, im ready to add boric acid to my bike. But just one problem, how do i measure 10 grams of boric acid accurately?
Old 13th October 2007, 14:33   #206 (permalink)
tsk1979's Avatar
Nano boric acid. Its very very different from nano boric acid. We are talking about particiles 10x smaller than those found in boric acid.
Please keep in mind that the researchers had to "do a 10X reduction" to get benefits.
If they had got benefits with just boric acid why would they bake so many poppadoms
__________________
Reclaimed, wrung dry and recycled....!
Old 13th October 2007, 14:41   #207 (permalink)
Sam Kapasi's Avatar
Boric acid is a very good cure for yeast infections and candidiasis.
__________________
“I am matter and you are matter, but it doesn’t matter.” – Captain Beefheart
Old 13th October 2007, 15:42   #208 (permalink)
Sam,
Lets not discuss where boric acid is useful on living organisms.Even if you stated this for fun its not good to discuss so.
tsk1979,
Why you look at this thread as an enemy of car enthusiast?
Nano particle reduction is indeed more beneficial but it dosnt mean otherwise.Intention of this thread is to pass on benefits at easily available resources.Technological upgradation is different thing.Why every time this things pop ups in your mind?
finetuning is offline   Reply With Quote
Old 13th October 2007, 20:59   #209 (permalink)
Finetunung, here's something to help what you are saying:
"But driven by a conviction that he could fashion boric acid into an even better lubricant, Erdemir continued to chase the ultimate frontier: a perfectly frictionless material. Glimpsing the potential of nanotechnology, Erdemir went smaller — 10 times smaller — and was astonished by the behavior of much thinner boric acid films. "If you can produce or manufacture boric acid at the nanoscale, its properties become even more fantastic," he said."
The rest of this article can be found here:
Old 15th October 2007, 16:56   #210 (permalink)
gd1418's Avatar
Boron treatment or adding boric acid to the engine oil is a one time treatment. The boron particles encase the moving parts by forming a film over it and that lasts for long.
pm fintuning and he would tell you exactly how it works.
__________________
Royal Enfield Bullet 1962
All Black 1998 Safari 4x4
All Black 2004 Scorpio GLx
Thread Tools
What happens to the engine oil when the Oil cap and/or dipstick is opened and engine? D.V.R Technical Stuff 22 10th November 2009 22:31
My Experience Of Adding 2T Oil In Fuel finetuning Technical Stuff 107 29th May 2009 23:06
Adding Engine oil with Diesel. chanapli Technical Stuff 39 18th August 2008 21:35
My Experience Of Adding Boric Acid In Petrol finetuning Technical Stuff 50 24th June 2008 22:27
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
