| Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al). |
| View Poll Results: I have TRIED IT and have found that ... | |||
| It works wonders for my car/bike. I highly recommend it. | | 15 | 36.59% |
| Slight improvement, but I recommend it. | | 7 | 17.07% |
| No difference at all. Don't bother trying this non-sense stuff. | | 11 | 26.83% |
| It screwed my car!!! Stay away from all boron compounds!!! | | 8 | 19.51% |
| Voters: 41. You may not vote on this poll | |||
| | Thread Tools |
| | #211 (permalink) |
| BHPian Join Date: Aug 2006 Location: Bangalore
| Guys Not i m qiut qurious to know where do i get this Boric Acid that i can use in my car. My car is in due to change the engine oil. so was planning to add boric acid in the engine oil and the g-box. 2 question: Q1). what is the quantity of Boric Acid that i need to add in the engine oil. Q2). Where is this Boric Acid for cars available, and is there any specific brand available that is good. Q3). It needs manual mixing or its ok just to add??? Sorry, if my question is sounds stipid. but to be frank, i seriously dont know much about it. And i m happy that i am learning something new......
__________________ 2006Dec Santro Xing[160kmph] 2006 Honda Activa[85kmph] |
| | #212 (permalink) |
| Senior - BHPian Join Date: Sep 2007 Location: New Delhi
| kick.throttle, whoa there! Don't jump headlong into things. Little knowledge is a dangerous thing. No one is going to give you a clear go ahead with this boric thingy. There are practical problems that need to be sorted out. These are in fact about how to add it to your car to reap the benefits and not lead to problems. BA is not soluble in oil - just dumping macro size powder into your sump will cause problems with filters and perhaps also narrow oil passages. In fact the KEY to successful deployment by home users is what needs to be found. Do read up some more. That's my advice. Your car will run well without it for quite a few years, so don't be in such a hurry. |
| | #213 (permalink) | |
| BHPian | Quote:
__________________ "The greatest trick the devil ever pulled was convincing the world he didn't exist ." | |
| | #214 (permalink) | |
| Quote:
i been thru all the posts under this thread, and could gain only 50:50 knowledge. the remaining is like under confusion. thats the reason i narrowed it down to few questions.. Thanks
__________________ 2006Dec Santro Xing[160kmph] 2006 Honda Activa[85kmph] | |
| | #217 (permalink) | |
| Newbie Join Date: Dec 2005 Location: Bombay - Delhi
| The engine revving up at start is common to all MPFI engines. Generally - on cranking, it goes to around 1500, comes down to around 1100-1200 till the engine warms up. There sure is a problem is your engine rpm goes up and down on its own - check and replace the stepper motor. Also - using premium fuels instead of normal unleaded petrol helps. From your quote - it sure seems that the ECU / Engine management isnt all well in your car.. Get it checked Cheers..!! Quote:
__________________ The Uncredible Bluffer Uno.. Palio... next.. the Linea... | |
| | #219 (permalink) |
| Senior - BHPian Join Date: Jul 2007 Location: Dharamsala
| This is a standard petrol fuel additive introduced by refineries many years ago. It might be in your fuel already.
__________________ The only tyrant I accept in this world is the still voice within. -Gandhi |
| | #220 (permalink) |
| Senior - BHPian | Can you please elaborate on this piece of information? At one stage you say that it is a standard petrol fuel additive and at other you mention - it might... creating a doubt on your own statement. I don't think boric powder or boron is a standard fuel additive by the refineries world over. I only know of a specific engine oil brand Motosilk that has known boron content in it.
__________________ Royal Enfield Bullet 1962 All Black 1998 Safari 4x4 All Black 2004 Scorpio GLx |
| | #221 (permalink) | |
| Quote:
__________________ The only tyrant I accept in this world is the still voice within. -Gandhi | |
| | #222 (permalink) |
| BHPian | Guys, After reading this thread in its entirety, I decided to do this experiment with my 13 Months / 8750 Km old Avenger. I got 2 litres of engine oil. To about 200 ml of the oil, I added approximately 10 gms of Boric acid and stirred for about 30 mins. Then I drained the existing oil completely and filled 1.2 lts of fresh oil and added the 200 ml oil with BA mix. I immediately started the bike and went for a short spin of about 5 kms. No noticeable difference. Today morning, I took the bike to work, a distance of 25 kms. Here is what I noticed: 1. Gear shift was very smooth. 2. Low end Torque had improved considerably. 3. Engine was definitely quieter. I have not voted yet. Want to ride around first for atleast 300 kms and then see if these improvement are due to the addition of BA or due to fresh Engine oil. @Finetuning: When would you recommend I should change the Engine Oil again? Cheers, Rajan
__________________ ___________ No message. Here to learn... |
| | #223 (permalink) |
| Senior - BHPian Join Date: May 2005 Location: TRV
| Patchyboy, what if the new oil is making the bike ride smoother and gearshifts better? Ideally one should've tried this in the old oil itself to ascertain the difference it makes. I haven't tried this yet. And i don't refute the claims made because boron has lubricant properties. What i really would like to know is the % of difference boric acid alone causes. |
| | #224 (permalink) | ||
| BHPian | Quote:
I had clearly mentioned in my original post. If you really want ro find out the % of difference that BA alone causes, then I guess you will have to try it for yourself and find out. Cheers, Rajan
__________________ ___________ No message. Here to learn... | ||
| | #225 (permalink) |
| Newbie Join Date: Aug 2007 Location: Mumbai
| HI, I have tried on my bike (splendor) and my bike is giving me a very good FE....So i tried it on My OHC. I mixed the boric acid in the power steering oil.....dude the experience was bad....i am getting strange noises from the steering pump...think i have to replace it asap...getting KKRRRRRRR sound from the pump.....hehe i think i have damaged the pump i guess....Please advice.. |
« Nissan Quest - Intermittent air-con blower speed
Different Service Schedules for Different Cars »
| Thread Tools | |
Similar Threads | ||||
| What happens to the engine oil when the Oil cap and/or dipstick is opened and engine? | D.V.R | Technical Stuff | 22 | 10th November 2009 22:31 |
| My Experience Of Adding 2T Oil In Fuel | finetuning | Technical Stuff | 107 | 29th May 2009 23:06 |
| Adding Engine oil with Diesel. | chanapli | Technical Stuff | 39 | 18th August 2008 21:35 |
| My Experience Of Adding Boric Acid In Petrol | finetuning | Technical Stuff | 50 | 24th June 2008 22:27 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
