| Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al). |
| View Poll Results: I have TRIED IT and have found that ... | |||
| It works wonders for my car/bike. I highly recommend it. | | 15 | 36.59% |
| Slight improvement, but I recommend it. | | 7 | 17.07% |
| No difference at all. Don't bother trying this non-sense stuff. | | 11 | 26.83% |
| It screwed my car!!! Stay away from all boron compounds!!! | | 8 | 19.51% |
| Voters: 41. You may not vote on this poll | |||
| | Thread Tools |
| | #241 (permalink) | |
| BHPian | FT i have sat down and gone through the entire thread post by post and all that i can tell you is it is a very fine gesture that you intend to help others with your theory and those who have tried your theory must be praising you for your efforts and for those who have not benifitted from it, well all i can say is something might have gone wrong somewhere and it would be highly appreciated if you shared your experiences here. FT carry on the good work and keep us updated of any new additions to your theory and also take all the critisism in a positive manner and take to it as constructive critisism as all new theories are bound to get critisism as no two people will think in the same manner as thus opinions may vary from person to person. Quote:
Also there is no way to know that BA found of the counter is 100% BA, i am very sure a percentage of it might be chalk powder or other substances. Again looking at the sunnier side GD also expericed positive difference in performance with both his Safari and Scorpio.
__________________ AbhiK D shortest way b/w 2 points is a straight line…what's the fun in that? Straights R 4 Fast Cars, Turns R 4 Fast Drivers! Last edited by tsk1979 : 13th June 2008 at 17:43. | |
| | #242 (permalink) |
| BHPian | @tsk1979 Bro i am not from a science background but have my fair share of knowledge about chemical reaction so just a query or maybe a thought from my side. Your earlier posts on the reactions, that ideally boric trioxide is formed and that boron to effectively bond with metal needs temperatures beyond 300*C. But if you have considered temperature and normal atmospheric pressure for the chemical reaction then would'nt the high pressure inside the cylinders, when pistons are in the compression stroke, make the temperature higher than 300*C for the reaction to take place? And this will happen in intervals i.e only when compression takes place so that might explain the fact that the more the car is run the more effective the reaction/process. And also "pressure" also accounts for chemical reactions and their outcomes and in the compression stroke pressure also would be many times atmospheric pressure. Please explain and also tell if the above is correct or not.
__________________ AbhiK D shortest way b/w 2 points is a straight line…what's the fun in that? Straights R 4 Fast Cars, Turns R 4 Fast Drivers! Last edited by abhik : 13th June 2008 at 17:56. |
| | #243 (permalink) |
| Senior - BHPian | White gooey paste to be precise. I didn't continue this treatment after this, however have persisted with acetone. What I would be interested to know is that does some boric powder get dissolved in the oil? If yes, then probably it serves some purpose as some synthetic oils with boron do. If it does not, then are there some particles of very small microns that pass through the filter? That too would serve the purpose.
__________________ Royal Enfield Bullet 1962 All Black 1998 Safari 4x4 All Black 2004 Scorpio GLx |
| | #244 (permalink) |
| Senior - BHPian | Sam, I agree with your view point. Lets not exaggarate facts. Yes adding boric acid to gearbox acts similar to slick oil. But But... adding to engine! its a strict NO NO.
__________________ Save Money today for a Better Car Restoration Tomorrow ...:) |
| | #245 (permalink) |
| Team-BHP Support ![]() | @abhik, we are adding the boric acid to Engine oil, not inside the engine chamber. The engine oil temperature rarely goes above 200F(95 degree approx) If it goes above that the engine oil will burn. Hence my point. Also the engine oil itself is not subjected to high compression. High compression happens inside the combustion chamber where only fuel goes. If you read gd's post, he stopped using Boric acid, and he just uses acetone in the fuel.
__________________ Reclaimed, wrung dry and recycled....! |
| | #246 (permalink) | |
| BHPian | Quote:
__________________ AbhiK D shortest way b/w 2 points is a straight line…what's the fun in that? Straights R 4 Fast Cars, Turns R 4 Fast Drivers! | |
| | #247 (permalink) | |
| Team-BHP Support ![]() | Quote:
If any part of the engine oil meets pressure and temperature which can cause boric acid chemical reaction, that part of the engine oil will get burnt. In a healthy engine, the engine oil should never see those temperatures.
__________________ Reclaimed, wrung dry and recycled....! | |
| | #248 (permalink) | |
| BHPian | Quote:
Thats what we are looking for. (w.r.t reduction in noise/vibrations, cooler running temperature, smoother running.) You did'nt continue to use this treatment but is'nt this a one time treatment? Boron in microscopic particulate size might be soluble with oil and these particles should be the ones making the bond with metal. Again looking at the brighter side if particles are getting trapped by the filter then its good as this would ensure no foreign particles disturb working of the oil lines and path. Others that are smaller will help in the process claimed by FT.
__________________ AbhiK D shortest way b/w 2 points is a straight line…what's the fun in that? Straights R 4 Fast Cars, Turns R 4 Fast Drivers! Last edited by abhik : 13th June 2008 at 18:57. | |
| | #249 (permalink) |
| BHPian | OT: Just to makes things a little lighter as things are heating up in this thread. ![]() @GD, @tsk I guess in the next Delhi meet we should make this thread a madatory topic of disscussion as after a few shots down it would be a real treat to hear wacky POVs and ideas on BORIC ACID ![]()
| | #250 (permalink) |
| BHPian Join Date: Mar 2006 Location: Mumbai
| abhik, Thanks for evaluating my experiments in the positive manner. Well,as time passes I m more inclined towards the benefits such simple yet effective method passes to every rotating parts and machinaries.I went further and used this in tractors,static generator sets(Kirloskar)) and not to forget in my jijaji's brand new wagon R.Result is same again & again.Precaution I took is to run engine instantly after adding this for at least 40 minutes at a stretch.And after 100Km replacing the oil filter and after 2000+ km changing engine oil. In tractors I found very smooth gear box & also lesser diesel consumption.Its running very smooth.Also in same manner diesel consumption is reduced in generator set.Indeed its passing desired result whether you people agree or not.My jijaji's wagon R is again running differently then normal wagon R in terms of smoothness & power.And beleive me its really a one time treatment. Most benefits I had seen are in pulsars and honda activas.They just love the these dose.There is marked improvement in smoothness & pick up. I firmly beleive its the lubricant of future.There will remain friction always that will eat the HP & fuels.This simple method will unlock this power without doing any work. Well,normally available powder do contain few very very small micron sized particles that helps us.Imagine if we are able to get right sized particle with 99% purity.If particle size is more then it can get trapped in oil filters.But in my all experiments I never found a single oil filter full of powders.These means with pressure inside engine they get carried away from filter membrane too. In case of gd1418,I think he got problems with fuel filters & not oil filters.And indeed this technique is not supposed to be repeated. |
| | #251 (permalink) |
| BHPian | @finetuning please check your inbox, i have PMed you a few queries and need your response asap. I am ready to "borify" my Ikon.
| | #252 (permalink) | |
| BHPian | Quote:
Sorry to enter so late in the day, but yes i second FT, coz i have done this on my zen, a year ago. and i Fully agree with what he says. Anyone is free to drive my zen and clear their doubts PM me. My Car Aint so good in Delhi now coz i dont have the time or a really good mechanic as i used to have in Bombay, Sigh! how i miss Bombay
__________________ "The greatest trick the devil ever pulled was convincing the world he didn't exist ." | |
| | #253 (permalink) |
| BHPian Join Date: Apr 2008 Location: Bangalore
| interesting. the only thing that remains unanswered as far as i can see is how boric acid is converted to boric oxide at a temperature of less than 100 deg C. i'm going to try searching for a preparation method done at high pressure which might cause the reaction to take place at this temperature. anyway, that apart, i have an old shaolin lying at home unused. i'm planning to give her a new piston soon. just wondering how long i should wait to run-in the new piston before adding boric acid to the 2T oil. |
| | #254 (permalink) |
| Few words of caution. Since boric acid is in powder form and contain micron sized particles too its very harmful to lungs.One must take all precautions for this while handling. How boric acid is converted into boric oxide?....do read this link & explore other articles too for WHAT..WHERE...WHY...HOW....& SO WHAT behind this theory...I hope this will help... EvergreenAmerica.com - Motor Silk and Lubri Silk Engine and Motor Treatments, Biodegradable, Boron CLS Bond, Lubricants, Greases, Fuel Additives, Gear Treatments, Aerosol Lubricants, Marine Lubricants, Hydraulics, Mold Release, Anti Corrosion Paint, |
| | #255 (permalink) |
| Piston oil rings are designed to strip off excess oil from chamber and to pass on thin layers to inside wall of engine cylinders for lubrication.Its this thin film thats important as most friction occurs near top of cylinder area.Boron treated oil makes very fine layers inside cylinder wall where rings works for sealing compression as well as stripping excess oil.This eliminates friction as boron layer is extremely slippery much more then best grade synthetic oil.This suddenly improves piston ups & down movement with very less friction.So we see no metal contact between rings and inside cylinder wall.This eliminates metallic wear & tear & rings then lasts so long with same compression as that of a new car.The real benefits lies here. This is the graphical illustration..... http://www.synergeticlubrication.com...cls%20bond.swf Also more about the oil lubrication inside engine,a tribological aspect is here... Combustion engine lubrication system. Last edited by finetuning : 13th June 2008 at 23:50. |
« Nissan Quest - Intermittent air-con blower speed
Different Service Schedules for Different Cars »
| Thread Tools | |
Similar Threads | ||||
| What happens to the engine oil when the Oil cap and/or dipstick is opened and engine? | D.V.R | Technical Stuff | 22 | 10th November 2009 22:31 |
| My Experience Of Adding 2T Oil In Fuel | finetuning | Technical Stuff | 107 | 29th May 2009 23:06 |
| Adding Engine oil with Diesel. | chanapli | Technical Stuff | 39 | 18th August 2008 21:35 |
| My Experience Of Adding Boric Acid In Petrol | finetuning | Technical Stuff | 50 | 24th June 2008 22:27 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
