| Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al). |
| View Poll Results: I have TRIED IT and have found that ... | |||
| It works wonders for my car/bike. I highly recommend it. | | 15 | 36.59% |
| Slight improvement, but I recommend it. | | 7 | 17.07% |
| No difference at all. Don't bother trying this non-sense stuff. | | 11 | 26.83% |
| It screwed my car!!! Stay away from all boron compounds!!! | | 8 | 19.51% |
| Voters: 41. You may not vote on this poll | |||
| | Thread Tools |
| | #256 (permalink) | |
| BHPian | Quote:
This is what i actually meant when saying that some amount of oil enters the cylinder for lubrication and the oron would then get compressed and chemical reaction will take place inside the cylinders
__________________ AbhiK D shortest way b/w 2 points is a straight line…what's the fun in that? Straights R 4 Fast Cars, Turns R 4 Fast Drivers! | |
| | #257 (permalink) | |
| Senior - BHPian | Smoother running, better pulling power were observed. The performance was more pronounced in my TCIC Safari '98. This made me think as FT propounded that this treatment prolongs the older engines. There was no difference in the temperature for both - the Safari & Scorpio. It indeed is a one time treatment but effective for roughly 20K kms. Why I discontinued? Because when I saw the gooey white paste in the filter chambers, that set me thinking that similar deposit would also happen in the fuel tank (as I added BA in fuel as well) at rest as sedimentation. While the filter unit could be cleaned at every service, getting the tank and oil sump cleaned was an exercise that I was unwilling to take. Quote:
__________________ Royal Enfield Bullet 1962 All Black 1998 Safari 4x4 All Black 2004 Scorpio GLx Last edited by gd1418 : 14th June 2008 at 14:21. | |
| | #259 (permalink) |
| Senior - BHPian | There were white powder deposits on the oil filter fins of Safari, when removed after first treatment. I had not checked the fuel filters at that time since as suggested by you, I first tried to dissolve BA in acetone. It of course made a milky solution. But I thought that small quantity added to a large quantity of diesel would mix well. But the powder deposits were found in the fuel filter unit.
__________________ Royal Enfield Bullet 1962 All Black 1998 Safari 4x4 All Black 2004 Scorpio GLx |
| | #260 (permalink) |
| BHPian Join Date: Jun 2008 Location: Travelling Most of the time!!!
| So i guess that tommorow i'll be adding 200 gms of boric acid in 150 ml of acetone and then i'll mix it with 1/2 ltr, engine oil and mix that oil with the rest of the engine oil (4 Lts.) in my Indigo 2005 Model. I'm also willing to put it in the Gear Oil. Do i change the Oil Filters before i add boric acid and then change them again at 100 kms or do i keep running with my existing filters and then change them after 100 kms?? i know too many questions, but would appreciate if you guys clear the air and any specific oil to be bought i generally use Castrol CRB+.
__________________ The Man who smiles when something has gone wrong has already thought of somebody to blame it on :-)) |
| | #261 (permalink) |
| Senior - BHPian | Guys, Theres something that i am not understanding. How come you guys add the Boric Acid directly to your engine. I understand about the gear box thing. But engine. Any educated person on earth would understand that BA is totally harmful to engine. Ecperiments are good, but something that'll lead to fatal results have to be a strict no no. I have faced problems using BA in and internal combustion engine and found it totally sc****d up the engine. I want others to be really careful while attempting such folley. Mods: Why such thread that is misleading. i feel the Senior BHPians and Moderators should pump in few inputs on this.
__________________ Save Money today for a Better Car Restoration Tomorrow ...:) |
| | #263 (permalink) |
| BHPian Join Date: Dec 2007 Location: Mostly Mumbai
| Hi finetuning, Just went through this entire thread. It sounds encouraging to me. If there is something that can prevent damage while the engine is new then the time to try it is NOW. Can i try this in my new safari 2.2 ?? If yes, then please list the exact procedure for me to follow for 7.5liters of engine oil. The engine has done around 6000kms now and i will be doing a long trip of 7000+ kms shortly. Following are my questions: 1) How much boric powder to use? 2) In how much ml acetone should i dissolve this boric powder ? 3) Since my engine oil was changed @ approx 1000kms should i just pour this acetone boric concoction into the engine via the same inlet from where we pour engine oil? OR 4)Do i have to mix this boric acetone mix in engine oil and then pour it? (note my current engineoil dipstick shows max oil level) 5)After how many kms should i change the oil filter? 6)Is it possible to only change oil filter without spilling engine oil?? (I thought that the entire engine oil has to be drained to change the oil filter) 7)After how many kms should i change the boric treated engine oil ? (Note: next scheduled oil change is @ 15000 kms) 8) Does this solution have to be put in a warm engine or a cold engine will do ? If there anything else that I should know then please let me know. All the information is much appreciated. I have listed the questions in order for me to understand and follow the procedure correctly. Please feel free to add additional comments. Im sure it will help anyone else in 2 minds.!! Regards, J
__________________ Dream as if you'll live forever, Live as if you'll die today !! Last edited by jaysmokesleaves : 15th June 2008 at 00:56. |
| | #264 (permalink) |
| BHPian Join Date: Mar 2006 Location: Mumbai
| Hi jaysmokeleaves, Sorry for late reply.. Since you had recently changed oil+oil filter its not necessary to change it for this treatment In your 7.5 ltr engine you can prepare 150gm powder with 500 ml oil and mix it well in any mixture grinder available at our kitchen for at least 4 to 5 minutes.No need to dissolve it in acetone. You can add this solution directly into engine from where you usually add fresh oil. You need to run you vehicle instantly for at least half an hour or more for better result. More you drive say for an hour better will be result. You need to replace only oil filter after running first 100Km. This is a good safety measure which doesnt cost more. Bcz of removal of carbon & dirts oil becomes thick & black.By changing filter we eliminate most of dirt thats piled of from metal surfaces. Also if you change your oil filter again at 500Km then its best for your engine. This treatments works best within first 100 to 500 Km. Our aim is to allow boron treated oil to work & also to remove displaced carbons from oil. You can change engine oil after 2000km if you find it more black. Many times in diesel vehicles due to heavy accumulation of carbons oil becomes too black & looses its viscocity so early. However its not essential.It depends upon condition of oil.So if you feel its good then continue driving. You need to put this solution in hot engine. You can have a drive of 15 minutes to reach engine to its optimum temp. then add solution. You will observe silent running of engine,better in gear acceleration,improved power (can feel it easily with a/c on). |
| | #265 (permalink) | |
| BHPian Join Date: Apr 2008 Location: Bangalore
| Quote:
| | #266 (permalink) |
| Senior - BHPian | Silver shadow. Good you are experimenting things, i totally agree with your gearbox addition and suggest people doing so, as this combination of BA in gearbox runs 3 of my cars, but in an engine. BA is as good as a foreign particle in the engine oil and the compounds that BA is made up of creates friction(as we dont get pure BORON) BA is a coarse powder compound which we find easily. My friends old 800 engine was supposed to be removed to overhaul and as per this thread he tried BA, it ran well for 200kms and later the same old problems of misfiring, engine decompression and other related issues surfaced. This engine was a SUZUKI made and just because of using BA it further damaged the pistions, connecting rods and the oil pump in the car. The oil filter also had lot of deposits (Whitish) in it further reducing oil flow in the engine. Its a common sense. Any coarse particle in the engine oil is going to block the oil flow once it gets into the filter(as filter is choked). This is a live experience, and suggest people to ratify the same.
| | #267 (permalink) |
| Earlier i had thought of carrying out this procedure, but then i was speaking to my mechanic in the morning and he started firing me stating that if you want to take the risk but i am not going to do this for you (have been getting all my cars done from him from the days that even i dont recall) and he said that instead try using a synthetic oil in place of mineral oil and see the difference. I finally changed from mineral oil to synthetic oil and driving aound town like crazy so that i can cover at least 500 kms and start feeling the difference.
| | #268 (permalink) |
| It happens... Remember why are we adding this to our engines & gearboxex?.....If its to eliminate major worn out problems then this is not a majic potion.When there is mechanical tolerence/damage problem due to wear & tear which need nothing but major overhaul then how this thing can work. In those cases where it worked are having lesser severe problem. What can we expect from an already gone case.. engine demanding only overhauling. Look in this way.....you managed to run extra 200 Km without any problems...thats the grace period....replacing oil filter in very old cars is a must...not once but might be at two times.... |
| | #269 (permalink) | |
| BHPian | Quote:
The answer is manufacturers into mass production look at LONG-TERM RELIABILITY,OPTIMUM EFFICIENCY, VARIOUS COSTS to comply with and NORMS to MEET. The rest of the lot who have a performance division and manufacture performance street cars for a particular market niche like Nissan, Mitsubishi, Toyota etc (Lets leave alone the big boys for now) concentrate on known, tried, tested and proven on tracks mods on street cars and concentrate on a lot lot more other than lubricant. And none of these companies will go in for a technique/technology/theory which would be in testing/trial/experimentation phase or which is not proven on papers. Why? again the same answer:LONG-TERM RELIABILITY. Though performance oriented, these cars still need to be reliable enough to clock a good number of miles and end of the day get a happy customer. FT's theory on Boric Acid is a DIY based on properties of BA on metal upon forming Boric Oxide. He tried it, found it to be beneficial to his use. Then he just shared the same with us and never forced anyone to try it. IT WAS ENTIRELY UPTO OUR WILL AND WISH TO TRY THE EXPERIMENT/TREATMENT, and see if it benefitted us. The above is with a neutral POV and not unbiased towards anybody. Its just that the argument on the treatment/technique/experiment of adding BA with Engine Oil and Gear Oil can be carried on till someone put its down on papers officially and probably wins a Nobel Prize for it. So the best way to tone it down is:- TRY IT IF YOU FEEL/THINK YOU SHOULD FOR WHATEVER REASONS. DONT TRY IT IF YOU FEEL/THINK YOU SHOUL'NT FOR WHATEVER REASONS. If you have tried it then please share your experiences whether positive or negative. If you havent then give your viewpoints on your idea/theory on why it would not work. But we should keep the argument limited due to the uncertainity /lack of complete knowledge/ varied outcome/ no set procedure etc. which makes the argument never ending. PS: Sir Alec/Pavan this was not aimed at you directly but to all members as a whole as i thought the discussion was heating up on the argument and does'nt have a possible end at the moment ISSUED IN PUBLIC INTEREST ![]()
« Nissan Quest - Intermittent air-con blower speed
Different Service Schedules for Different Cars »
| Thread Tools | |
Similar Threads | ||||
| What happens to the engine oil when the Oil cap and/or dipstick is opened and engine? | D.V.R | Technical Stuff | 22 | 10th November 2009 22:31 |
| My Experience Of Adding 2T Oil In Fuel | finetuning | Technical Stuff | 107 | 29th May 2009 23:06 |
| Adding Engine oil with Diesel. | chanapli | Technical Stuff | 39 | 18th August 2008 21:35 |
| My Experience Of Adding Boric Acid In Petrol | finetuning | Technical Stuff | 50 | 24th June 2008 22:27 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
