| Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al). |
| View Poll Results: I have TRIED IT and have found that ... | |||
| It works wonders for my car/bike. I highly recommend it. | | 15 | 36.59% |
| Slight improvement, but I recommend it. | | 7 | 17.07% |
| No difference at all. Don't bother trying this non-sense stuff. | | 11 | 26.83% |
| It screwed my car!!! Stay away from all boron compounds!!! | | 8 | 19.51% |
| Voters: 41. You may not vote on this poll | |||
| | Thread Tools |
| | #271 (permalink) | |
| BHPian | Quote:
I guess you were already using acetone and that should have worked out fine. No where in the entire thread did i see mention of adding BA in the fuel.And when changing engine oil, the oil from the engine sump also gets drained. So if there are any larger particles of BA, they will drain up with the used oil.
__________________ AbhiK D shortest way b/w 2 points is a straight line…what's the fun in that? Straights R 4 Fast Cars, Turns R 4 Fast Drivers! | |
| | #272 (permalink) |
| BHPian Join Date: Apr 2005 Location: Bangalore
| finetuning sir, is this you, supertuner, there, why have you not updated there your complete findings ? mpg Research • View topic - Boric acid and derivatives....?? anyways hats off to your patience here, anwering everyquery.. FIAT,always.... |
| | #273 (permalink) |
| BHPian Join Date: Mar 2006 Location: Mumbai
| Hi Sanjay, Infact I shared most of my thoughts in that forum...but since "what happens inside engine" is such a topic which always keeps us guessing based on different results..... I have taken further steps in this fields which I will share at appropriate time.... If anybody reads all the information available about boric acid as a lubricant then one can easily come to conclusion about its potentials. I always looked at all criticism/feedback in positive manner....I know that all are my dear friends & such questions are bound to arise sooner or later....I too am constantly on learning curve... so opinion changes.... Enjoy... |
| | #275 (permalink) |
| Hi, Dissolving BA with hot water works. In any case we want to have reduced particle size of boric acid by our own method. Solubility of boric acid is highest in methanol then ethanol and acetone and water if I remember correct but with this method there is no considerable difference noted.Boric acid has to be well dispersed into oil. In the same manner these solvents can be used. Methanol too will evaporate but I found it unpracticable. Methanol in oil makes it like curd. Not desirable. Keep on sharing new ideas. |
| | #276 (permalink) | |
| Quote:
yes, you have shared with us all the info you have & really appreciate your tenacity & perseverance.. & you have backed your claim by both experimenting on your own prized possesion ( maruti esteem & scooty) & technicalities.. really appreciate your patience.. yes i would like to try this on my FIAT 1.2 ( run around 17K) & also on my new Glatiator type RS ( got it last week) once it crosses 5K kms.. i for one do not doubt the capabilities of Boric oxide or its ill effects if any.. i will send you a PM before actually preparing the mixture.. thanks once again, FIAT, always.... | |
| | #277 (permalink) | |
| Senior - BHPian | If my grey cells serve me well, I recall FT mentioning that BA could be added to fuel too by premixing it with acetone.. Finetuning: can you corraborate that? Agreed, while draining the sump nearly gets empty, but I've seen some diesel engines opened up for overhaul and their engine sump was full of sludge, that needed scraping to remove. Quote:
__________________ Royal Enfield Bullet 1962 All Black 1998 Safari 4x4 All Black 2004 Scorpio GLx | |
| | #278 (permalink) | |
| BHPian Join Date: Dec 2007 Location: Mostly Mumbai
| Quote:
__________________ Dream as if you'll live forever, Live as if you'll die today !! | |
| | #279 (permalink) | |
| BHPian | Quote:
FT only mentioned BA to be dissolved with acetone to be added to THE ENGINE OIL. So that BA particles breakdown completely and mix with the oil well. Guess you confused it with the acetone in fuel funda. ![]() Lets wait for FT on the clarification though.
| | #280 (permalink) | |
| BHPian Join Date: Nov 2007 Location: Bangalore
| Quote:
My Experience Of Adding Boric Acid In Petrol by finetuning http://www.team-bhp.com/forum/techni...id-petrol.html (My Experience Of Adding Boric Acid In Petrol) | |
| | #281 (permalink) | ||
| Senior - BHPian | Quote:
I for once, after reading your post, thought that old age has caught up and meomry is failing me as grey cells are probably the last to surrender. While the rest of the body was functioning in top condition, this couldn't have been true and that set me worrying. I also checked with wifey if the almonds that she buys for me were from the same shop or was changed recently? All parameters are ok. We'll discuss this in details on 21st..![]()
__________________ Royal Enfield Bullet 1962 All Black 1998 Safari 4x4 All Black 2004 Scorpio GLx | ||
| | #282 (permalink) | |
| BHPian | Quote:
![]() My appologies GD sir, i forgot with age comes experience!! ![]()
| | #283 (permalink) |
| Senior - BHPian | Does anybody know if this is available in India and/or anyone used it? If so, the results... Automotive lubrication products with Boron CLS Bond™
| | #284 (permalink) |
| BHPian | Adding BA to fuel seems wierd if we are stressing on lubricating properties of BA and the fuel(petrol/diesel) have opposite chemical qualities and also the fuel systems(carb, injection, crd) do not have any moving part requiring lubrication unless the motive is to add boric oxide layers in the cylinder using fuel as a medium. Anyways dont think i am going to try that, better off trying BA with engine oil, which i will do on sunday most probably.
| | #285 (permalink) |
| BHPian Join Date: Oct 2007 Location: Mumbai
| i have also added BA in my engine oil but first experiment on my pulsar and then if i find good results then in my car. as of now it has done only 15kms after the treatment but yes there is smoothness in the drive. After adding it as per procedure said by FT i drove it for 12kms on trot. So lets see after about 100kms the review. but looks like it is good. i have used his experiment of acetone in petrol and has worked to a great extent in my bike as well as car. Thanks for sharing these experiments for better car performace. |
« Nissan Quest - Intermittent air-con blower speed
Different Service Schedules for Different Cars »
| Thread Tools | |
Similar Threads | ||||
| What happens to the engine oil when the Oil cap and/or dipstick is opened and engine? | D.V.R | Technical Stuff | 22 | 10th November 2009 22:31 |
| My Experience Of Adding 2T Oil In Fuel | finetuning | Technical Stuff | 107 | 29th May 2009 23:06 |
| Adding Engine oil with Diesel. | chanapli | Technical Stuff | 39 | 18th August 2008 21:35 |
| My Experience Of Adding Boric Acid In Petrol | finetuning | Technical Stuff | 50 | 24th June 2008 22:27 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
