| Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al). |
| View Poll Results: I have TRIED IT and have found that ... | |||
| It works wonders for my car/bike. I highly recommend it. | | 15 | 36.59% |
| Slight improvement, but I recommend it. | | 7 | 17.07% |
| No difference at all. Don't bother trying this non-sense stuff. | | 11 | 26.83% |
| It screwed my car!!! Stay away from all boron compounds!!! | | 8 | 19.51% |
| Voters: 41. You may not vote on this poll | |||
| | Thread Tools |
| | #332 (permalink) | |
| Senior - BHPian | Quote:
with you zak and i too cannot think of adding BA,ACETONE and all that stuff and definitely to improve engine smoothness Mobil1 Synthetic is keeping me happy @ the moment. All the best to you guys, but somehow i cannot dare do that.
__________________ SUCCESS is not FINAL and FAILURE is not FATAL,its the COURAGE to CONTINUE that COUNTS! | |
| | #333 (permalink) | |
Zak and VJ, I first both your thoughts. I can only see 2 or 3 people replying on this thread, what's the need to push it so hard. I somehow find these experiments so meaningless. No offences to anybody. But guys lets lead on maintaining our cars wonderfully NORMAL They are better that way.
__________________ Save Money today for a Better Car Restoration Tomorrow ...:) Last edited by PAVAN KADAM : 16th July 2008 at 17:36. | |
| | #334 (permalink) |
| BHPian Join Date: Oct 2007 Location: Mumbai
| Hey if this is the thing then why people fill premium fuel in their cars n bike. they should fill normal petrol and do regular servicing. No offence meant. and sorry if i hurt anybody. but just the way of thinking. i fill normal petrol with these experiments. |
| | #335 (permalink) | |
| BHPian | Quote:
What happens when an engine is overfilled with oil? So you topped up the engine when it was warm after getting a faulty dipstick reading, or you put too much oil in when you changed it yourself. What's the worst that could happen? Well the problem with this is that the next time the engine is run, the windage in the crankcase and other pressures generated by the oil pump, etc. place a great strain on the seal on the rear main bearing. Eventually, often much sooner than the ordinary man in the street might expect, the rear main bearing seal ruptures, and the engine becomes a 'leaker'. If you've got a manual gearbox, this means one thing: this oil goes right onto the flywheel and the face of the clutch disc. A lubricated clutch is A Bad Thing. If this still goes unnoticed, the front seal is the next to go, and the engine then becomes a 'gusher' (or to be more colourful, it starts pissing oil all over the place). As well as smothering the clutch with oil from the rear, the oil now coming from the front leak will be neatly distributed about the engine bay as it hits the front pulley - often propelling it out as far as the brake discs. At the same time as this Hollywood disaster movie is unfolding outside the engine, things aren't working out any better on the inside. As you can see from the diagram, the correct oil level is really close to the rotating crank. Overfilling will mean the crank dips into the oil and churns it into a froth. Froth is good on certain types of coffee but not good in an engine. The mixture of aerated oil will be forced into the bearings and in case you didn't know, air is not a lubricant. Typically this means that bearing damage will follow quite rapidly, especially if you are driving on a motorway. You'll know bearing damage when you get it. The engine smells like a garage mechanic cooking over an open flame and the noise coming from the engine is the sort of thing you'd normally hear in vaudeville plays when a piano is pushed down a flight of stairs. As if that all wasn't bad enough, the excess oil gets thrown up into the piston bores where the piston rings have a hard time coping with the excess oil and pressure. It gets into the combustion chamber and some of it will get out into the exhaust system unburned resulting in a nice patina of oil all over the platinum surfaces of your catalytic converter. This renders it utterly useless for good.
__________________ Longing for a long ride... | |
| | #337 (permalink) | |
| BHPian | Quote:
a simple solution.This happened to me last time when I gave my bike for servicing. I rode the bike for about 7kms to the service station. Oil change was due and so the mechanic did it.. maybe half an hour after the ride. Then after a few days, I noticed oil leaks from the left side of the engine so had to get the oil seals changed.
| | #338 (permalink) |
| BHPian | A very good friend of mine who sat through me in the entire experiment of trying BA with engine oil in my Ikon, was very eager to try it on his Opel Astra 1.6 1997model NZR engine which has done a total of 1,78,000 plus and runs on CNG. Due to lack of time and his busy schedule we couldnt fix up a meeting to try the BA experiment together so he decided to go ahead anyways. His car runs like a 11year old car slow, vibes at idling and rough. He follwed FT's procedure of adding BA and running the car for 100km continuously and he said that the difference in running was evident after only 5kms of driving and was getting better with every km he clocked. I drove the car after it had run 500km plus after BA treatment and the car actually felt smoother and lighter to run. I asked him if he had made any other changes to the car and he denied. So the car was as it was earlier and now the only difference was BA in the engine oil. Oil filter is still not changed. Idling vibes was now 95% lesser than earlier and when i drove it for about 6-7kms it felt a lot lot more silent and silky smooth than what it was before. The difference in performance was a lot more than what i experienced in my car and somehow with other people's experiences as well i can figure out that BA treatment is more beneficial to older engine with higer mileage clocked on them as the difference in performance noticed is more than engines with lower mileage but nevertheless difference in performance is there no matter how old the engine is.
__________________ AbhiK D shortest way b/w 2 points is a straight line…what's the fun in that? Straights R 4 Fast Cars, Turns R 4 Fast Drivers! |
| | #339 (permalink) |
| BHPian Join Date: Mar 2006 Location: Mumbai
| Hi abhik, Good to see people getting benefited.One thing is sure this affects engine in a better way.But its more pronounced in older car having run more Km.In newer car too this friction reduction & metal treatment method works but very silently. Look at my own jijajis new wagon R which now completed 16K km.The moment I drive another wagon R of same mileage I can difinitely feel the difference in terms of smoothness,pick up,in gear acceleration,reduction in vibration & engine noise(whatever it may be...its getting reduced). Now I can not say its an Experiment as that phase is already passed on for me.Experiment is meant to check long term effects/drawbacks and many other parameters with consistant use.I urge members to have a sceintific approach towards this ignoring me and my passionate words describing all these.Again I say even if a single member is getting benefited I m happy.There are numerous research papers & publiction available on internet.Dont get confused by word Boric Acid rather read how its useful as a lubricant on todays senario. For many this seems meaningless & waste of time considering cost of vehicles and so on...but thats their view and we are here to discuss ideas and thoughts so they are welcome.We keep on arguing till that PUZZLE which is there in our mind gets solved by knowlegde,direct experience,lapse of time and many other factors.And life is full of such PUZZLES which keeps us busy throughout life. |
| | #340 (permalink) |
| Newbie Join Date: Jul 2008 Location: BHOPAL
| Hi Finetunning, I had been on regular basis reading this thread,and went on putting the boric acid on my Yamaha 99 model 135cc, with the amazing results, this bike was almost finished as my servants at my village has misused it with kerosene for years,its working well again. Second one tried with my Esteem LX 1997 which had lost the power and the pleasure to drive, thanks F.T its once again back with that 85bhp power. Third and last was by ZEN2002 MPFI Euro II- and the results on this was far the best its almost like new back that peppy pickup is back, and there is improvement in FE too ,have droven it 1800km now 15% gain on FE,but just forget that FE the engine is absolute smooth and gearbox silky smooth. Thanks FT you have changed the way i use to ride on these car. Will keep updating the forum after few more Km are clocked.
__________________ The best is yet to be invented till then,keep experimenting. |
| | #341 (permalink) | |
| BHPian | Quote:
I am so happy about the fact that the engine operating temperature of my car car gone down considerably and there is overall smoothness. My friend's Astra has benefitted a whole lot more being run so much and has made him happy.
__________________ AbhiK D shortest way b/w 2 points is a straight line…what's the fun in that? Straights R 4 Fast Cars, Turns R 4 Fast Drivers! | |
| | #342 (permalink) |
| BHPian | What is required to understand by all here is that apart from text book knowlegde is that with a scientific approach one can physically make out why simple BA powder available off the counter can be used as a lubricating addon to the base lubricant i.e engine oil. Imagine having Mobil 1 Super Syn or Shell Helix Ultra which are one the best known lubricants and engine oil and then making them even better with this treatment to make an engine perform better. Just take carrom powder/Boric Acid in your hand and rub it against your fingers, it is so fine and slippery, what harm can it possibly do? And if not anything then just the slippery property will help the internals move smoother. I removed the oil filter and didnt find any deposits. There wer'nt any deposits in the oil that came out aswell and i carefully examined both. So wherever the powder might have dissapered it is surely working its magic.
| | #343 (permalink) |
| BHPian | I love my car and will think twice before doing anything to it. For every mod or addition in my car i go indepth of the pros and cons of it. So i did the same here aswell because Ikon is'nt a car to be messed around with too much.
| | #344 (permalink) |
| latest update on car response and FE figures as i was on a long drive to mu native place. Car on higher speeds was very responsive,smooth and ready to take more went upto 148 kPM (that to on lpg)but for few seconds only-- else my drive was steady on 70 to 90 mark.Earlier it never went over 120kph.Apart from that the car was very smooth no odd sound coming in. I reckon as exprienced by FT i am also finding it becoming much smooth as more and more km are clocked. Coming to the FE figures it was a surprise for me, i was taken aback--for the matter of comparison my earlier FE for 26 ltr of LPG at city driving used to be 260-280. Now for the condition in city is 310-320. Surprise pack is here friends at highway trip at decent speed of 70-90 apart from one high speed test 26ltr of LPG, my car has covered 368 km earlier it never crossed 300-310. It is significant gain making it more pocket/enviorment friendly-shall also help in conserving resources with we have in limited number/amount. Till now it has covered total of 3866 km after boric treatment. i have not changed oil as it was fresh Castrol Magnetic did open the filter no traces of any Boric deposit so didnt change the filter either. One change noticed that the sludge which was deposited on the tapid visible when open the oil inlet cover has diluted to an extend, where now metal is visible. Hope to ripe even more benefits from boric. Special thanks to Finetuning. Will keep the forum updated
| | #345 (permalink) | |
| BHPian Join Date: Nov 2005 Location: Mumbai
| Quote:
__________________ A nuclear bomb can shake my mortal frame, but nothing will stir my moral soul. | |
« Nissan Quest - Intermittent air-con blower speed
Different Service Schedules for Different Cars »
| Thread Tools | |
Similar Threads | ||||
| What happens to the engine oil when the Oil cap and/or dipstick is opened and engine? | D.V.R | Technical Stuff | 22 | 10th November 2009 22:31 |
| My Experience Of Adding 2T Oil In Fuel | finetuning | Technical Stuff | 107 | 29th May 2009 23:06 |
| Adding Engine oil with Diesel. | chanapli | Technical Stuff | 39 | 18th August 2008 21:35 |
| My Experience Of Adding Boric Acid In Petrol | finetuning | Technical Stuff | 50 | 24th June 2008 22:27 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
a simple solution.
