Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al).
View Poll Results: I have TRIED IT and have found that ...
It works wonders for my car/bike. I highly recommend it. 15 36.59%
Slight improvement, but I recommend it. 7 17.07%
No difference at all. Don't bother trying this non-sense stuff. 11 26.83%
It screwed my car!!! Stay away from all boron compounds!!! 8 19.51%
Voters: 41. You may not vote on this poll
Thread Tools
Old 21st August 2008, 18:35   #346 (permalink)
sameer_dg's Avatar
I think the mods should interviene and help. Am not sure but I just hope lot of newbies just don't blindly follow such things and cause damage to their vehicles.
Teambhp is a reputed forum and lot of suggestions on this forum is being blindly followed by a large community outside.
__________________
A nuclear bomb can shake my mortal frame, but nothing will stir my moral soul.
sameer_dg is offline   Reply With Quote
Old 21st August 2008, 18:48   #347 (permalink)
tsk1979's Avatar
Team-bhp does not endorse any such experiments. Whatever Team-bhp advises is in article section.
That said, this is a public forum and every member is free to offer their suggestions and advices. But following that advice is purely dependent on the member
__________________
Reclaimed, wrung dry and recycled....!
Old 1st September 2008, 13:34   #348 (permalink)
rakowli's Avatar
I have tried Boron treatment in the M800 gearbox also. at first not much of difference. but after 2-3 days the gear shift was very smooth. i could feel the difference. So again a big thanks to you.
rakowli is offline   Reply With Quote
Old 1st September 2008, 21:55   #349 (permalink)
Hi rakowli,
Keep on reaping unheard benefits through your guts & inclination towards science.That makes the difference.Your benefits in either pulsar or M800 is outcome of a technology of future and your faith & understanding.
I m so happy that this is passing tremendous benefits
You need not remove old gear oil till next 5000Km.This will improve your gear shifting,will reduce transmission losses,tooth drag & so on that we can never achieve with single click.As you drive more you will feel more benefits in the same manner as in engine oil.You might be able to shift gear if everything is finetuned with just a push of a finger.This has impact on engine performance too.
finetuning is offline   Reply With Quote
Old 2nd September 2008, 00:35   #350 (permalink)
Default Boric acid powder treatment
Hello FT and other friends,
I have been following this thread and I would like to try the procedure on my '02 pulsar and palio of the same year both have done good amount of mileage. Is the procedure as simple as buying Boric Acid powder off the counter and adding some 5-10% to engine oil and then using that engine oil in car or two wheeler ? How long does it take to get mixed in the oil. Is it recommended only to be used with synthetic oils or mineral oils can also be used, also please suggest the recommended percentage and procedure of mixing the BA powder with oil. Are there any pre-requisites for this treatment ?
DonnieDarko is offline   Reply With Quote
Old 2nd September 2008, 15:22   #351 (permalink)
In pulsar you can add 10gm pure BA with 100ml normal engine oil that you normally use.Mix it well if possible with mixer grinder or hand mixer.Add to engine oil directly from where you add fresh oil in hot engine.You need to bring engine at normal temperature before adding for best benefit.Instantly drive bike without delay for best result up to 30 to 40 minutes without stopping & much pulling.
In your palio you can add 80gm pure BA disolving/mixing with say 300ml normal engine oil that you use.Strill it well as above & pour in hotter engine.Star car & drive for 40 minutes minimum.
Make sure to buy BA from good chemist.Pure powder is very bright,slippery & very fine.
Old 2nd September 2008, 17:56   #352 (permalink)
Default Any suggestions
Thanks FT for your prompt reply. my wife will kill me if I use the mixer at home for this purpose and I don't want to buy another one specifically for this. Is it ok if I just mix it well by hand using a container and a spoon or something. hope it doesn't form small granules when mixed with oil like other powders do when they are mixed with water. Any other suggestions are most welcome.
thanks once again
Old 3rd September 2008, 01:03   #353 (permalink)
Ok
Mixing with mixture is only to make BA spreading evenly with oil and also to break down it into finest particle.If not using any mixture then make sure to break any lumps of BA first then use & stir by any means.If still you find small granuals(you probably will) then break it with spoon or by any means otherwise that will be trapped by oil filter & will be of no use.
All the best
Old 4th September 2008, 02:55   #354 (permalink)
thanks once again, will try the treatment and post the results soon.
Old 23rd September 2008, 19:51   #355 (permalink)
Hi There,
I have been watching this thread with great interest!
After reading through the mant pages about Boric Acid here i decided to give it a try.
I live in the UK and have an old Vauxhall Astra 1.4i car,i have had the car for approx 6 years.
The car had approx 50,000 miles on it when i bought it,now it has done approx 110,000+ miles.
I have regularly replaced the oil and filter,and used good quality semi synthetic oil.
The car runs well,the only minor thing is that of slight hydraulic tappet noise on startup when cold and when left standing for some days,within a minute or two the tappets are then fine,i have been told that this is quite normal.
Anyway i bought some Boric Acid 99.5% industrial/technical grade and mixed it with acetone as previously recommended.
I then took the car for a long run approx 100 miles,what i noticed is that the engine starting to run quieter and smoother,also i noticed that i needed a touch less throttle to keep say 50mph!
Now after running the car since (approx 300 miles more) the hydraulic tappets are now silent on startup,and the car feels smoother and seems to glide along!
I am about syphon out some gearbox/differential oil and mix some Boric Acid with some ep80 oil and then top up the transmission oil and give the car a good run.
I have also just mixed some Boric Acid with engine oil and put that in my friends old Ford Orion diesel car and see how that performs.
I have not forgotten to change my oil filter,or my friends,but the results look excellent.
In future i will mix the Boric Acid with oil only,and not acetone,as i noticed a small amount of Boric acid left on the inside of the cam cover,on the cam splash guard.
When i did my friends Ford diesel car the oil/Boric acid mix seems to not leave a slight boric acid residue on the cam splash guard,i think that is due to the heat of the engine vapourising the acetone quickly.
But all in all i am delighted with the results so far!
Thanks Finetuning top man.
Boardmaker is offline   Reply With Quote
Old 31st October 2008, 12:39   #356 (permalink)
I tried this method on my caliber 115. I took out about 15ml of , mixed 8 gms of boric powder in 15 gms of acetone till it formed a near-clear white liquid. Then added 100 ml of oil (Petronas 10W40 synthetic, used for some 500-800 kms) from bike. Kept shaking the bottle many times till next day. After riding the bike for about 1-2 kms, i added the mixture in the engine. And then...
No change! Initially I was feeling mentally that the change will occur now, no, bit later, no, maybe now.... it never came! In fact, I found the noise of bike to be increased! What can be the reason? What did I do wrong? It's almost 300 kms after that experiment, so enough time has passed by. But still there is not 'feelable' change in the engine. Additionally, the idling is not proper too, shooting way up to 2500 from it's default 1350 value by its own, not sure whether this experiment was responsible.
Finetuning, can you please guide me further?
ani_meher is offline   Reply With Quote
Old 19th June 2009, 04:36   #357 (permalink)
Hi all!
I am from South Africa, but this is one of very few forums where people have actually tried Boric acid/oxide in their engines, which is why I am reviving this thread.
I have done so also, but with a very different method to the way you people have done it.
The cars I have done this to with my method have all shown huge improvements within 2 to 3 km!
Except 2*
You do this by doing a bit of research and using your head:
Boric oxide + water = boric acid.
So rather than relying on moisture in old oil to react with the oxide; I added enough water to make it ... watery and poured it in!
I have many reservations about doing this.
Like the large particles blocking the oil filter... (20-45microns filtered)
What the stuff becomes when reacting with nitrogen and hydrocarbons at the temps and pressures found in engines etc.
(this was the subject of a lot of research for me)
How is everyones cars long term that have added Boric oxide?
It has been in my car for 8 months now.
*NB: the water thins the oil and can lead to the oil light coming on.
add slowly for really old engines and switch off immediatly if the light come on.
I look forward to hearing from long term users!
Logic is offline   Reply With Quote
Old 19th June 2009, 12:17   #358 (permalink)
All Right. I wanted to test it. After servicing and oil change,Today i have added aprx 15gm+Few ml acetone to my HH bike (11,000 Km).
Results, if any , will be shared shortly as i am planning a long ride this week end.
idea1979 is offline   Reply With Quote
Old 23rd June 2009, 19:09   #359 (permalink)
All Right. Results are in.
What i did: Added 15 Gm of Boric powder with some acetone to engine oil (Changed a day back) to my bike CD deluxe (11000 done).
I am also adding acetone to petrol for last 2 months.
Then i took bike for a long ride over weekend. Aprx 615 Km. And conclusion is
Avg: 54.89 KMPL (Generally i get 57-58)
Reason could be 70+ speed on highway and speeding at signals. Still 2-3 km drop per liter is huge.
I am not sure about smoothness of engine. Though it felt smoother, it could be due to recent servicing and or such a long ride.
So Conclusion : Neutral (Atleast no after effects as of now :-) )
Old 24th June 2009, 15:39   #360 (permalink)
Boric Oxide is not a lubricant idea1979.
Once it has reacted with water to form boric acid it becomes a lubricant.
B2O3 + H2O = H2BO3
Fortunatly there is some H2O 'dissolved' in all engine oil. (the older the oil the better/more water)
Especially in a humid place like India!
The Boric Oxide will slowly react with this water to form the desired acid.
I use water in stead of acetone
and then the results are almost instantanious.
NB: Adding water to oil temporarily thins the oil.
In old engines this can result in not enough oil pressure: the oil pressure warning light will come on.
Add the stuff a little at a time.
Add prefrably thicker oil if the oil light comes on.
In your case the effects will take a long time to become apparent as more and more water gets into the oil and reacts to form acid.
To speed up the process add a tablespoon or 2 of water and drive slowly to normally for 1 km then repeat.
As Boric oxide is only around 20% soluble in hot water you will need about 250 ml of water for every 50 g of powder added.
(the engine will heat the water)
ie:
20% is 1/5 of 100%
Therefore multiply amount of grams of powder added by 5 to work out water reqd.
(I add a bit more than that as the powder is more dense than water...)
This will dissolve the powder that is currently blocking your oil filter and put it on the metal surfaces where it belongs.
Thread Tools
My Experience With Adding Acetone in Petrol finetuning Technical Stuff 453 6th August 2009 20:51
My Experience Of Adding 2T Oil In Fuel finetuning Technical Stuff 107 29th May 2009 23:06
Adding Engine oil with Diesel. chanapli Technical Stuff 39 18th August 2008 21:35
My Experience Of Adding Boric Acid In Petrol finetuning Technical Stuff 50 24th June 2008 22:27
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599
