| Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al). |
| View Poll Results: I have TRIED IT and have found that ... | |||
| It works wonders for my car/bike. I highly recommend it. | | 15 | 36.59% |
| Slight improvement, but I recommend it. | | 7 | 17.07% |
| No difference at all. Don't bother trying this non-sense stuff. | | 11 | 26.83% |
| It screwed my car!!! Stay away from all boron compounds!!! | | 8 | 19.51% |
| Voters: 41. You may not vote on this poll | |||
| | Thread Tools |
| | #361 (permalink) |
| BHPian Join Date: Oct 2007 Location: Mumbai
| Does this helps in Cold start also. i was having a cold start problem in my P150 2004. But not in the morning but when bike is out in rain the whole day, it use to give me lot of problems for first 5 mins. of drive till it heats up. 3 days back i poured boric powder mixed in engine oil to the engine bay, also tuned a bit of more fuel flow. but now it is much better then what it was early. i doesn't give me starting problem now. it maybe because of Boric acid or maybe better tuning. But result is my problem is solved. i have used boric powder before also, so i know it works well. So i gave it a shot and problem solved. |
| | #363 (permalink) |
| Newbie Join Date: Apr 2008 Location: Johannesburg South Africa
| You people are very lucky that India is such a hot and humid place! Let me explain: Boric Oxide IS NOT A LUBRICANT!!!!!!!! Boric Acid is! Do the research. Boric Oxide (not lube) + Water = Boric Acid (excellent lube) B2O3 + H2O = H3BO3 WATER! Not acitone, or oil, or re-constituted dinosaur urine! There is a lot of water in the oil over there which increases as the oil gets older. This water reacts with the oxide you guys are adding to form Boric Acid which only then reacts with metal surfaces to give low friction. That is why it takes so long for you guys to get an improvement! Turn the oxide into acid 1st, by adding boiling water (oxide more soluble in hot water) and you will see a difference in about 3 KM! This stuff WILL BLOCK OIL FILTERS!! Change filter but not old oil. Drive 10KM to filter out anything; just in case. Add hot mixture 50ml at a time, every 3 - 5 KM, as it will thin your oil too much if you add too much. Add thick Diesel truck oil if oil light comes on. Change oil and filter 20- 30KM after no more improvement is noticed, but let the car stand overnight so that the stuff can get in under all the carbon etc. Then add some of the hot water after the solids have settled out. |
« Nissan Quest - Intermittent air-con blower speed
Different Service Schedules for Different Cars »
| Thread Tools | |
Similar Threads | ||||
| What happens to the engine oil when the Oil cap and/or dipstick is opened and engine? | D.V.R | Technical Stuff | 22 | 10th November 2009 22:31 |
| My Experience Of Adding 2T Oil In Fuel | finetuning | Technical Stuff | 107 | 29th May 2009 23:06 |
| Adding Engine oil with Diesel. | chanapli | Technical Stuff | 39 | 18th August 2008 21:35 |
| My Experience Of Adding Boric Acid In Petrol | finetuning | Technical Stuff | 50 | 24th June 2008 22:27 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
